Question about Zoom (56600000) Router
What is the ip address for the zoom router - Zoom (56600000) Router
    Problem Solver:
  • 16 Answers
The default IP address for Zoom routers is 10.0.0.2. If you have everything plugged in correctly then you will be prompted for a username and password to access the Home Gateway realm, these are admin and zoomvoip respectively.
Posted on Feb 04, 2010
How do i make my zoom internet connection secure
goto http://10.0.0.2
this is the routers IP address, it will open the setup screen for the router.
From there goto security options and set it up with the security features you want active.
Sep 06, 2009 | Zoom (5590-00-03) Wireless Router (G66115)
Router works but internet to computer does not.
Your pc might be using a static IP address. Make sure its on automatic. Go to Control Panel, Network Connections. Right-click on Local Area Connection and click Properties. Look for Internet Protocol TCP/IP and double click it. Select Obtain an IP Address Automatically and Obtain DNS Servers Automatically. Click OK all the way out. Also disable any firewall you have like Norton Firewall, McAffe, Zone Alarm and the likes.
Jun 22, 2009 | Zoom (56600000) Router
ADSL Zoom x6 5590 DNS 360 Problem
Yes the router assigns an internal IP address. connect it up then using your PC go into the configuration of your router (http://10.0.0.2) and look under system status, scroll to the bottom and under DCHP status you will see a list of all clients connected. Your Xbox will be listed along with its internal IP address.
Jan 04, 2009 | Zoom X6 (5590) DSL Modem (55900003)
Connecting a second pc to a router
First step is to restart the router, power off then on.
That will restart the DHCP server on the Router.
If the above fails, check below.
Make sure you are getting a IP address from the router.
- Start - Run - cmd - ipconfig
If not check that the DHCP service is running.
- Start - Run - services.msc
If you find that dhcp is working a your have a vaild ip address 192.168.1.2 or 192.168.2.2 something thing like this,
then go to cmd again, and try to PING the default gateway.
Hope this info helps.
Best of Luck.
Jun 08, 2008 | Zoom ADSL 5554 X5 Router (5554-00-00)
Zoom X6 Adsl Router
You must assign a static IP address on the Xbox 360 that it is outside of the Zoom X6 router's DHCP pool. Also, the Xbox 360 must be in a DMZ. This will prevent the firewall of the router from blocking connections to the Xbox 360.
  1. Assign a Static IP address on the Xbox 360 console:
    • Power on your Xbox 360 and go to the System area.
    • Select Network Settings and then Edit Settings.
    • Select IP Settings. The Edit IP Settings screen opens.
    • Select Manual and then enter the following settings:
      • IP Address: 10.0.0.150 (or any 10.0.0.x IP address, where x is between 100 and 250)
      • Subnet Mask: 255.255.255.0
      • Gateway: 10.0.0.2
    • Select Done, to go back to the Edit Settings screen.
    • Select DNS Settings. The Edit DNS Settings screen opens.
    • Select Manual and then enter the following setting:
      • Primary DNS Server: 10.0.0.2
      • It is not necessary to enter a Secondary DNS Server.
    • Select Done.
    • Power down your Xbox 360.
  2. Access the Zoom Configuration Manager:
    • From a computer that is connected to the Zoom X6, open a web browser and type http://10.0.0.2 in the address line and then press Enter (or Return).
    • Enter the User Name and Password (in lowercvase letters):
      • User Name: admin
      • Pasword: zoomadsl (where "l" is a lowercase letter L)
  3. Create a Virtual Server rule to put the Xbox 360 on a DMZ:
    • In the Zoom Configuration Manager, click on the Advanced Setup icon at the top page.
    • Click on the Virtual Server/DMZ button.
    • On the Virtual Server/DMZ page, enter the following settings:
      • Internal IP Address: 10.0.0.150 (or whichever Static IP address you selected per Step 1)
      • Protcol: DMZ
      • Start Port: 0
      • End Port: 0
    • Click Save Changes
    • Click the Enable box, if you have this option.
    • Click Write Settings to Flash
  4. Plug the Xbox 360 Wireless Networking Adapter in to the Xbox 360 console. If you are not sure how to do this, please refer to the manual that came with the Adapter.
  5. Select the Zoom wireless network on the Xbox 360. (Note: The following steps assume you have a working wireless network with WEP or WPA security enabled and you know the Key and SSID of the network. If you have not done this, please refer to theFAQ on setting up a wireless network with the Zoom X6.)
    • Power on your Xbox 360 and go the System area.
    • Select Network Settings and then Wireless Network.
    • Enter the SSID of your network
    • Enter the Security Key for your wireless encryption. This must be either WPA or WEP. If you use WEP, you must enter the HEX digits for the Key you are using.
    • Power the Xbox 360 off, wait a few seconds, and then power the Xbox 360 back on.
    • Go to the System area.
    • Select Network Settings.
    • Select Test Xbox Live Connection. If everything is configured correctly, all the tests will show Pass.
  6. Congratulations! You can now enjoy your Xbox 360 with Xbox Live.
May 23, 2008 | Zoom X6 Adsl Modem/router Rohs...
Xbox
Heres a link to a guide which should guide you step by step to obtaining an "OPEN NAT" status
yeh guide.
otherwise purchase "Compatible Xbox 360 Live " Hardware which will give you a Open NAT
list here
To be honest i think this NAT status is a marketing idea on MS part as NAT is Network address Translation , which is the ability to supply computers on the network a Private IP address using the same Public IP Address , and this sounds like port forwarding, but nonetheless goodluck :)
Mar 31, 2008 | Zoom X6 Adsl Wireless Gateway Rohs Router
Zoom x6 model 5590 wireless router
Make sure the Connection Type is set to Static IP on the setup page of the router
Mar 10, 2008 | Zoom X6 Adsl Wireless Gateway Rohs Router
Zoom adsl x6
If the Internet light is off it means you are not either authenticated at your provider or your configurations are wrong on the modem. If you go to your command prompt and type ipconfig and check your IP address and your default gateway. The IP address on your default gateway would be your router put that IP address on your browser and should be able to see your modem setting and any error messages that could help resolve your issue
Feb 18, 2008 | Zoom X6 Adsl Modem/router Rohs...
The routers I P address
set your ip setting to "Obtain an IP address automatically", then plug your ethernet cable to your system, once connected, open a command prompt then type 'ipconfig' (w/o ""). your IP add, subnet mask & default gateway will display. take note, the default gateway is the ip address of your router.
Dec 04, 2007 | Zoom X6 (5590) DSL Modem (55900003)
Zoom (56600000) Router Logo
586 people viewed this question
Top Zoom Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
