Question about Mustang 1940's White Tractor 1:160th/ N Scale Die Cast
1991 2.3 mustang no spark
My mustange was running went to start back up and nothing, I check it out and found i have no spark, i replaced the ignission mod and still, it's a 1991 2.3
    President:
  • 1,851 Answers
There are several relays on your car and all must be in working order.
Also there is a 'fusible link' that must be in working order.
1- be sure the fusible link is good.
standing on the driver side front by the wheel you will see the battery. -
2 -just behind the battery you will see the Solenoid
The solenoid will have the RED- HOT Wire on it going directly to the batter.
3- the OTHER side of the Solenoid will have a large wire and --- two three or even more smaller wires.
4 SOME - usually 2 of the smaller wires are most likely burnt in two - separated or both.
5 these wires are more rubbery and stretchy --
6 - replace with the SAME kind if wire., BE WARNED -- if you put too heavy of a wire here you can BURN UP YOUR CAR. So just do not put any old wire in here. It is best and not too costly to have an experience mechanic come in if you do not get it going at this point,
I hope this helps - please vote me high if this helps
RICESKI
Posted on Mar 18, 2010
1991 ford mustang
Start by checking for vacuum leaks, compression then a scan for fault codes. One of those should turn up a problem
Dec 14, 2013 | 1991 Ford Mustang
I am having trouble starting my 1991 ford mustang lx 4 cyl 3.2 l when it dose start it runs really ruff and when i put it in gear and press on the gas pedal it does not accelerate but acts like it is not...
I would check the timing could have jumped a tooth on the timing belt/chain. Also check the rotor in the distributer make sure that it is not worn out. I have also seen a plugged catletic converter cause big time power loss and really strange problems
My 1991 ford mustang has fire at the coil and the distributor but it will not start
You said,"My 1991 ford mustang has fire at the coil and the distributor but it will not start".
But, you did not mention what size Engine your mustang has nor the method you used to Check [said 'fire']
If the spark gets that far (to the distibutor) it is of no matter-IF it doesnt continue on from there then, OF COURSE it won't start. You started off on the right track, now all you need to do is Keep on going! What we need to find out is:
Is the 'fire' getting to the sparkplugs?
If not, then you will NOT HAVE combustion which is absolutely Necessary to 'fire off'/start your engine.
Also, you didnt mention what the 'fire' (i.e. spark) looks like. What color is the spark is it yellow-orange or cold hot blue white? Is it Well defined or sloppy and wide? Is it constant or is it erratic?
Sep 23, 2013 | Ford Mustang Cars & Trucks
Not all spark plugs firen
You check the right firing order?
1991 Ford Mustang 2.3 liter SOHC L4
1991 Ford Mustang 5.0 liter V-8 HO
Also, need check the PCM for someone short; sometimes this is the reason it wasn't sending a signal to the coil. You have constant power at the coil but the ground signal doesn't fluctuate from on to off while the engine is cranking. If the hall effects switch in the distributor is bad it won't tell the PCM when to fire the coil and the hall effect switch also operates the tachometer. So if this switch is bad the tach and the coil would not work.
Good luck.
Feb 09, 2010 | 1991 Ford Mustang
My headlights won't come on. I replaced the headlight switch about a month ago. I went to Autozone to see if another switch would work and it didn't. What could I do to fix the problem. I have a 1991 Ford...
Did you check the wiring when you replace the switch? Some times the plug that you plug into the light will be melted or burnt. I know cause I had 2 - 5.0 stangs and both did the samething. Is the car equip with fog lights? If so I would disconnect them. I found that the fog lights on my 89 gt cause the head light switch to over heat and melt. On both I had to repair the wiring at the plug.
Oct 30, 2009 | 1991 Ford Mustang
Car repair
i had the same problem just a little bit ago with my 91 mustang lx 2.3L. b. If you are not getting and sparks from your coil packs then im going to guess this is where the problem is. start by replacing all spark plugs and wires. if this does not work it most likely the coil packs ,But if there is spark then its your timing belt.
Oct 13, 2008 | 1991 Ford Mustang
91 Mustang GT running Hot
does the fan come on when supposed to? you could hook your fans to a toggle switch and run them manually from start to finish this may help. also did you bleed the system after replacing these parts and purge all air from cooling system? is the coolant coming out of the resovoir hose?
Sep 22, 2008 | 1991 Ford Mustang
Mustang 1940's White  Tractor 1:160th/ N Scale Die Cast Logo
55 people viewed this question
Top Mustang Toys Experts
ray gallant
Are you a Mustang Toy Expert? Answer questions, earn points and help others
