Question about HP Officejet 7130 All-In-One InkJet Printer
Communication error related to scanning
I have a networked 7130 with 3 PCs that works fine with all functions on PC1 and PC2. PC3 can print fine, but getting an error communicating with scanning device when attempting to start scanner via hp director software from PC3.
Hi how can i set up fax
Posted on Feb 04, 2010
This printer is connected to 1 pc via usb and prints via the network from pc 2 and 3.it suddenly stopped printing from pc no 3 but still prints from pc 2
If the printer is printing from pc1 that means the usb port is ok. If prints from pc2 that means the network port is ok, so the problem is not in the printer but in PC3. Check connection of pc3 to the network, check the settings, check recently installed programs - especially firewall or new antivirus version. Scan for viruses - there are some blocking traffic. You can even turn the pc3 back in time using the system restore service.
Hope this helps.
Sep 13, 2011 | HP Laserjet M2727nf Multifunction Printer
Restaurant Pro Express - Shared Printer - wierd scenario
Delete printer from PC it is not connected to(PC2). Make sure you can print a test page in windows from PC it is connected to(PC1). Then check on sharing. Make sure the share name is the same as what 3rd PC is looking for(PC3). Print to printer from PC3. On PC2, set up and install as a network printer. If all PCs can print to kitchen printer from windows, then you should not have to make any changes in RPE.
Also, if you cloned everything including the RPE folders, you may not be syncing properly. Check by changing the price of something and saving. It should change on the other stations also. Make this test from each station.
Jul 13, 2010 | Pc America Restaurant Pro Express
I can't switch to one of my boxes.
1) Make sure your connection to pc3 is good, take out and reconnect both ends.
2) If that has no effect power down the switch for 30 seconds then switch back on.
3) If that has no effect, connect pc3 to the pc2 slot. If PC3 now works, you've got a problem with the switch. If pc3 still doesn's work, its a problem with the pc3 lan connection. You'll need to check "Network connections" in your control panel.
Jun 07, 2010 | ConnectGear (UG104) 4-port KVM Switch
Print to a pc printer wireless
The easiest thing to do is enable printer sharing.
Feb 27, 2010 | Lexmark Forms Printer 2580 Matrix
Prints same page differently on different PC's
also check the HP support link, i saw some update fix for driver and firmware for 2k3 server OS
here is the link:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=3662058&prodTypeId=18972&prodSeriesId=3662052&swLang=8&taskId=135&swEnvOID=1005
Apr 03, 2009 | Office Equipment & Supplies
2 Eth Cards one for Internet & one for LAN
First of all, I would really recommend you to buy a Cable/DSL router. It is quite cheap, usualy more secure, much easier to configure and troubleshoot. Also, it does not require to have one PC up and running all the time, hense saving energy. Do you know that a PC running 24/7 may cost between 60$ and 100$ in electricity annually? This is more than the cost of a basic router!
But, since your question is about sharing your Internet connection with a PC, here are some guidelines. I will assume here that you are using Windows XP.
On PC1:
1. Connect the modem to Eth0 in the PC. Do not connect anything in the USB port of the modem.
2. Make sure that the link lights are lit both side. If they are not, you may need a cross-over cable (this is usualy not the case)
3. Configure Eth0 to get IP address DNS automatically
4. Disable (uncheck) all protocols except TCP/IP on Eth0.
5. Run the Network Setup Wizard (Start > All Programs > Accessories > Communications > Network Setup Wizard) and follow the steps.
On PC2:
Simply run the Network Setup Wizard (Start > All Programs > Accessories > Communications > Network Setup Wizard) and follow the steps. Specify and you Internet connection is through a Home or LAN network.
That should do it.
Apr 25, 2008 | Computers & Internet
USB to Ethernet adapter for printer
to run your printer on the network follow this steps. ist add your printer in your 1PC then share it. then add printer to your pc3, pc4.
To do this go to Start Menu/printer and faxes/add printer/follow add printer website. Do this process again to PC2, PC3
Mar 16, 2008 | Computers & Internet
Ef3116 has different up and down speed.
PC1 may have a defective NIC card. Also, verify that PC1's NIC card is using an up-to-date driver and that it's interface speed and duplex settings are set to auto-negotiate.
Jan 09, 2008 | Linksys EtherFast 3116 Port 10/100...
Home networking
You need to go to control panel>network set up wizard on the pc which has the internet connection and when you go through the wizard amongst prompts select, allow other computers to connect through this computer and then finish off the wizard. On the other computer you do the same but, on this one select this computer connects via another computer on the network and again finish off the wizard.
Oct 02, 2007 | Acer ALW 3016 Networking Switch
HP Officejet 7130 All-In-One InkJet Printer Logo
171 people viewed this question
Seeker5211
Seeker5211
