Question about Dell E773C 17" CRT Monitor
My Dell E773c Monitor's image is like a "hyperbola" wider at the top and bottom and narrower in the middle. The Horizontal adjustments do not do anything to correct the problem, Help!!!!
  • 457 Answers
Try to do a factory reset (look up "recall" in the manual, or here: http://support.dell.com/support/edocs/monitors/e773c/EN/ug/setup.htm).
If this does not help, you need to adjust the geometry settings (H/V position, H/V size, rotation, trapezoid, parallelogram, pincushion and pin balance) using the monitor's settings menu. Expect a long afternoon of fiddling around until you get a satisfactory result. A test picture for geometry settings could be of help.
Make sure your computers video setting does not exceed the monitors specification of 1152 x 864 @ 75 Hz.
Posted on Feb 06, 2010
The image is getting smaller
If in the horizontal direction your line output stage requires attention, new line output transistor/ capacitors etc. If in both dimensions probably a power supply fault.
Mar 07, 2011 | Dell E773C 17" CRT Monitor
Picture not adjusting to full screen an dmonitor buttons Exit, brightness, contrast and Menu are not working also. Checked all buttons contacts are ok.I tried to search for vertical and horizontal variable...
You will need to reset the resolution to fill the screen. That is done through Windows.
If the actual menu buttons on the screen are not working, you probably need a new monitor.
var fctb_tool=null; function FCTB_Init_5ddec69ff7a64d918e9c62baf4d86075(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_4b77af1c80d64567931291644b9994c7(t) { fctb_tool=t; start(fctb_tool); }
Dec 18, 2010 | Dell E773C 17" CRT Monitor
How do you adjust the vertical and horizontal of the image on your screen?
Press the OSD (On Screen Display) button on the face of the monitor. You'll find controls to control the size & position both horizontally & vertically.
Jun 01, 2010 | Dell E773C 17" CRT Monitor
The view on my monitor is very truncated - about two inches top and bottom are not filled
Press the MENU button on the monitor and adjust the width and height of the picture to full screen.
Oct 10, 2009 | LG Computers & Internet
Monitor fails to adjust-narrow in the middle
You have to use the OSD (onscreen display) to adjust the vertical height or the horizontal width.
If you have an auto button, try letting it readjust your monitor to the default setting. If this doesn't work, find the geometry setting and adjust the hoizontal or vertical manually to correct the "narrowness".
If this doesn't help, please reply with your monitor make and model number and we'll see if we can sort it out...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 20, 2009 | Computers & Internet
Task bar on bottom of screen and ribbon on top of screen disappear -- can no longer access them
why is it that it is not made clear that you have to pay to get assistance till you've taken all the time to access the site, figure out how to post, then actually post.  then here comes the money police.
I google quick, free dell monitor assistance or support and you're what I got.  I beleived you were free.
Unfortunate.
Jul 09, 2008 | Dell E773C 17" CRT Monitor
Dell Monitor E773C
on dell monitors they have buttons on the front (at least the old ones do).   If you can't see things on your screen like task bar on the bottom, or anything on the top and sides --- try adjusting this buttons.  They control vertical size, horizontal size, etc. -- also position on the screeen    If you accidently hit them (I did) it throws everything off.
good luck
May 23, 2008 | Dell E773C 17" CRT Monitor
Dell monitor E773C 17"
It sounds like this needs component-level troubleshooting, probably in the signal section. It might also be loose connections or residue of some kind in one of the switches or on the switch board.
Jan 04, 2007 | Dell E773C 17" CRT Monitor
Dell E773C 17" CRT Monitor Logo
465 people viewed this question
Alun Cox
