Question about Coffee Makers & Espresso Machines
Reneka Concept 956 coffee machine, water/coffee comesout luke warm and the milk frother isn't working, just producing a stream of luke warm water. Any idea's?
SOURCE: The streamer on my x1 has stopped working
Several things I would check here. How old is your machine? Is the coffee coming out hot enough? If not, then perhaps the boiler is not reaching optimum working temperatures and needs replacing. When did you last descale your unit? If you live somewhere where there is a lot of hard water, and you don't prefilter it, then it could be scale build up in the tube. Try soaking only the tube end of the wand in some vinegar for about an hour, then try flushing it with steam once again. Finally, one has to be dilligent in CLEANING the steam spout right after you use it, EACH AND EVERY TIME! (that is why you almost always see barristas with a damp cloth over their shoulder, ready to use). Milk left on the wand will bake on and become quite hard to remove. This will happen on the outside as well as inside the tube. Soak the end of the tube with boiling hot water for about 10 minutes, wipe the end clean, and with a fine wire or pin clean the inside of the steam wand tube. You may have to repeat this procedure several times to fully clean the wand. If you are at all mechcanical, you could take your machine apart, remove the wand, and soak/clean it separately. But only do this if you are a quite confident handy person. Hope this helps and good luck!
Posted on Nov 03, 2007
SOURCE: THE NESPRESSO MILK FROTHER HAS STOPPED FROTHING
I contacted Nespresso who may well replace the item
Posted on Nov 27, 2009
SOURCE: Flashing red light. Nespresso Citiz & milk coffee machine.
I had the same problem today. "http://www.singleservecoffee.com/archives/007209.php" talks about filling the frother above the max line, so that the whisk does not suck in air and does not pop off. I tried it and works. Make sure you close the lid properly to avoid spillage.
Posted on Feb 05, 2010
SOURCE: Lost my Nespresso Aeroccino Milk Frother Hot Milk Whisk
Call Nespresso customer service at 800-562-1465. Replacement set of 2 wisks were $2.95 + shipping
Posted on Jul 01, 2010
  • 155 Answers
SOURCE: The milk in the frother
the frother should have come wit two attachments a coiled one and a paddle the coil one is for frothing fill frother to bottom mark or slightly lower.hope this helps let me know how you went
Posted on Sep 14, 2010
I have a coffee to cup Neff CV7760N coffee machine (the type that sucks milk through a frother, rather then a wand). After 4 years excellent service the frother is now quite erratic - usually froths one...
Clean the frother by using detrergent or coffee clean tab.
just half liter water take add 1 coffee clean tab in one pot.insert the milk suck shner pipe in that pot .start the machine and press for milk sucking.
Jan 28, 2015 | Coffee Makers & Espresso Machines
Delonghi problems
Try filling both water and the milk container with the correct decalcifying solution - just slit the 500 ml that results from the 1:1 mixture and - without the coffee capsule - press the cappucino button. Instead of cappucino you will get the decalcifying solution running through the entire system including the connector for the milk container (unlike the recommended decalcification method where you use the extra nozzle). Good luck - worked for my machine which only produced steam but no milkfoam...
Aug 02, 2014 | De'Longhi En520.W Nespresso Lattissima...
Delonghi 3500s coffee machine not producing hot water or steam from water outlet/milk frother
Hey Everyone,
I had this exact same problem.
Check out my video of how to fix it.
Video: https://youtu.be/_SbGiD4LeCc
Hope it helps!
Jun 25, 2014 | Coffee Makers & Espresso Machines
The milk frother is not sucking milk from the cup... it appears that the steamer is working as if it is steaming the milk. Any ideas on why the frother tube is not sucking any milk up?
it is clogged with dried milk. Remove the frothing wand from the machine. now press milk froth. you should get a ton of steam blowing out of the hole where the frother used to be. Your frother comes apart for cleaning. pull the chrome tip off, pull the 90 degree fitting and the black milk suction tube off, if it is really dirty you can soak the disassembled frother in hot water with a cleaning tablet. ( the small ones you drop in the brew unit, not the big descaling tab.) also, there is a clear tube with a point on the end of it sticking out of the frothing wand. this is an air admittance oriface. it allows air to enter the hot milk stream and make it frothy and bubbly. if it gets clogged, you will get hot milk but no froth. Your machine came with a spare one in the parts kit.
Jul 04, 2011 | Miele CVA 4062 Stainless Steel
Hi, the steam from the wand is not frothing the milk like it used to, hardly any froth at all.
If the frother is warming the milk, but is not frothing, then you want to make sure the panarello is clean.
Slide the cover off the frother and check the pin hold on the top edge of the cover. If this hole is blocked the milk will not froth. Rinza is great clean to help prevent these issues. http://www.cerinicoffee.com/rinza_urnex.asp
Also recommend frothing water instead of milk to clean the frother well.
For more information visit: http://www.cerinicoffee.com/Coffee_cleaning_supplies.asp
Jun 07, 2011 | Gaggia Brera Coffee Maker
I have an Impressa Z5 and it won't **** milk up the tube as either part of the cappucino program or the stand alone milk program. I've checked and nothing in the nozzle is blocked and the plastic pipe...
There are three possible causes to milk not frothing: 1. The frothing tap is blocked: to unblock either use the cappuccino cleaner from Jura, or in 400ml of luke warm water dissolve a teaspoon of vinegar or 1/2 teaspoon of bicarb and run this liquid through the frother until completely finished (or run the cleaning program). The run about 600-800ml of water through the system. While passing the liquid through let the tap rest at froth, and milk setting for 5 seconds at a time. Repeat if necessary. To prevent this in future clean frother after 5 minute of none use. 2. The breathing nozzle is blocked, you can use the Jura Maintenance guide to see how to disassemble and clean and reassemble, but most Juras come with a spare, so replace it. 3. The machine needs to be descaled, since there is lime or scale in it.
Jan 15, 2010 | Jura Capresso Impressa Z5 Espresso/Coffee...
problem is overheating at a single point in the bottom of the milk container. Try cleaning the milk residue after each time you use it and the flashing red light disappears. This is a design fault. Nespresso are happy to keep marketing the Citiz but there is no fix - so the Nespresso "mess free" coffee machine is a bunch of flannel - good coffee all the same!
Jan 09, 2010 | Coffee Makers & Espresso Machines
Milk is heated but doesn't produce adequate froth
Inspect the end of the frother nozzle you should see a small plastic piece protruding.
If you dont see it remove the lower half of the frother and insert a pen and push the plastic insert to the end of the frother.
A "click" should be heard when it is located correctly.
Feb 21, 2008 | Gaggia Titanium Espresso Machine
Coffee Makers & Espresso Machines Logo
114 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
