Question about LG Televison & Video
No picture but have sound
Black screen but have sound and can change chanels have unplugged tv waited 30 sec to resart. Brand 27 in tvmonitor.
  • 148 Answers
The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! If this helped any, then please rate, thank you!No picture but have sound - 31dd7d3.jpg
Posted on Feb 04, 2010
My Philips 50PF7321D/37 TV picture turns blue after about 30 secs of being on and I cant seem to get it to stop. Also when I turn the TV on it has a black screen with sound for about 15 secs before it
Unplug both the set and a box or receiver if used with the set, remove from power for several minutes and replug all to see if a reboot will help or not.
Dec 09, 2012 | Philips 50PF7321D 50 in. Plasma HDTV
Intermitent black screen with sound, blue screen-no sound, normal
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You can try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Good luck...
Sep 06, 2008 | Mitsubishi VS-50111 50" Rear Projection...
TV screen is blank but I still get sound
its probably the motheboard. i got one for sale cause i broke the screen. or you can sell me yours so i can fix mine. if your interested email me at quoc5539@msn.com
Mar 02, 2009 | Sharp LC-26SH10U 26 in. LCD Television
Screen Goes Black
it sounds like your "lamp" is going out look for a hidden compartment.. or in your owners manual to see where its located its an easy fix and costs much less than a new tv
Oct 16, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony Bravia KDL 52 keeps turning itself OFF
i had prob where my sony would switch off for a few secs thenh come back on . The solution was in menu / tv settings / sleep timer . Go into that and make sure its set to off. there are opions for off , 5 min 20 min 30 min etc... mine was set to nothing just blank.
Apr 06, 2008 | Sony BRAVIA KDL-52W3000 52 in. LCD...
H.V shuts down/
try to check a bad conections in hv transformer and capacitor around them
Feb 01, 2008 | Zenith B27A11Z 27" TV
Pls more info; what do you mean tv on, picture froze? you are watching on tv chanel, do you use cable? I can help you but need more details.
Aug 29, 2007 | JVC AV-32D305 32" TV
Televison & Video Logo
112 people viewed this question
Computer Repairing
Computer Repairing
