Lost all power on mx8710 and it not the power cord it has to be the mother board what is the probley can it be fix
  • 397 Answers
Could be a couple things, Memory-try resitting them.. also could be processor, Try resitting that also,,If you need help let us know, We will try to help you anyway we can
Posted on Feb 04, 2010
Doesn't turn on
tried changing power supply cord, with battery out, if no lights
with new power cord, mother board will have to be replace, power button on mother board not engaging,
Aug 17, 2010 | HP Pavilion dv1000 Notebook
Tip
If your computer has a black screen and not booting to desktop
Normally if the computer has the black display then follow these steps:
1) disconnect the pwr cord form the back of the computer //
2) disconnect the printer and the internet cord//
3)hold the pwr button for 1 min and then release// this is called "pwr drain" when the pwr cord is disconnected//
4)connect the pwr cord and restart the computer and see if it boots or not.
5)if not then disconnect the pwr cord again and open the side pannel of the computer//
6)on the mother board you will find the RAM (MEMORY CARD) which will be approx 6 inch long", take out the card/s and plug the pwr cord and restart the computer//
7) if you get the beep sound then the mother board is ok and if you do not get the beep sound then the problem could be mother board//
8)if getting the beep sound then fix the RAM CARD properly and restsrt the computer// it shoul boot//
note** during all this process make sure that the pwr cord is pulled out when you put your hand inside the computer or else you can get power shock..
on Jun 10, 2010 | Computers & Internet
Computer powers on, no beep, monitor is blank
open the tower, on the mother board you will find the RAM card approx 6 inches long, take out the card and restart the comp, you should get the beeping sound and the mother board is fine, if no beep that indicates the motherboard has gone bad.
place the ram card properly into the same slot and then restart the computer. NOTE while putting your hand into the comp components always make sure that the pwr cord is pulled out or else you will get shock.
also check the cord at the back of the harddrive should be fixed properly. take it out and refix it at both ends . probable cause is there is some loose connection of the cord or the RAM.
May 10, 2010 | Computers & Internet
NO POWER TO MY LAPTOP MX8710. HAVE REPLACED POWER CORD AND BATTERY. STILL DEAD...HELP PLEASE
The problem is with the laptop internal mainboard chk with the RAM and processor in the laptop
Oct 30, 2009 | Computers & Internet
Pc suddenly lost all power...gateway laptop mx8710
i work on a lot of gateways that lose power. its going to be your motherboard, it can be fixed, most of the time. get a technician to see it.
Oct 13, 2009 | Computers & Internet
Dell laptop wont run with power cord and wont charge battery
could be the A/C connector on the mother board this would have to be replaced by a TECH if your cord is good and you have voltage coming out of the end of the cord that plugs in to the laptop then your A/C connector on the mother bord is bad and its a common problem this happens with use, if the laptop is new then return it if not it could cost $120.00 to fix. GOOD LUCK
Sep 21, 2009 | HP Pavilion zd8000 Notebook
Power switch turns on and off
that would work if you want a costly bill. Try this before dishing out cash, the problem is the switch that tells the board to turn on and of is bad and a cheep quick fix is to open the back of your TV(#15) (unplugged of course)and remove the hex(#10) screws to the mother board look under TV tube and you will see the switch board,remove both hex screws(#10) and pull the switch board out,follow black cord to mother board and pull cord out of its port. know find the word KEY also #2 on the switch board, should be the red wire. cut this wire and be sure there isn't any bare wire showing at your cut, a piece of black tape will help this. reinstall the switch board and mother board and back of TV . you should be all good to go
Jun 26, 2009 | Televison & Video
My television quit working after a storm, it wasn't even turned on during the storm. the power on the set and remote does nothing. but it makes a sound when plugged in like it is turning on then nothing...
Ok, this was a direct hit in this case and you will defiantly need to replace the power supply board in this unit. the first thing that will happen during a direct hit is, the surge will run threw the power cord and travel threw the entire power supply circuitry, frying all circuits. this includes the main mother board as well. I recommend replacing the mother board and power supply board as well. this will restore your set to its original operational value. The mother board is commonly called the main control board.
please rate and god bless:)
Apr 02, 2009 | JVC HD-52G886 52" Rear Projection HDTV
My cd-rw is not present in my comuter or window exploler
its likely a filter upper and lower to be exact. in english? a cd buning app added a driver that is broken now. filtercheck in cdr-zone.com forums fixed it for me many times. reinstall/repair burning app that doesn't work after removing filters.
Oct 13, 2007 | Dell Compact Disc Reader CDR-1900 CD-ROM...
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
