Paper jam,paper out of reach
How do you clear a paper jam when the paper is wrapped arou nd a roller and cannot be reached?
  • Leroy Elliott
    Leroy Elliott May 11, 2010
    what make / model? can't read your mind.
2 Suggested Answers
  • 16 Answers
SOURCE: how do you clear a paper jam when the paper is
Find another way to get to is .. refer to the Manuals.
Also provide a little more detail for the same issue.
Posted on Feb 04, 2010
C020 ON ESTUDIO 4511
There's a paper jam while the paper is trying to exit the printer. The definition of the error is saying that the leading edge of the paper has reached the exit sensor, but the other end of the paper hasn't yet. Because it's jammed...
It could just be a regular paper jam that needs to be cleared, or it could be a faulty exit sensor or a faulty registration roller, or registration sensor. I'd try clearing the jam thoroughly, and then try printing again. If it's a recurring error then you may need to call someone to replace a faulty part...
Jan 27, 2011 | Toshiba e-STUDIO 4511 Printer
PAPER JAM ML2010
May be it is your toner problem try toclesan it nd also change it.
If roblem still occurs then servece your printer and clean its pars with iso propile.
Sep 15, 2008 | Samsung ML 2010 Laser Printer
Up to two pages can be force fed through before the machine stops taking the pages and a paper jam error report is generated.
Inside the document feeder are two small levers near the middle of the paper path. One will be near the first roller to tell the machine that there's a sheet waiting to be pulled. The other will be an inch or two farther in, to tell it the paper has reached the scanner glass. If one of those levers is sticky, the machine will "think" it's feeding a very long continuous sheet. After a couple of feet or so, it reaches its programed limit and gives up to prevent tying up the phone line on an endless fax call when the document is jammed.
Open the feeder, find those levers, and make sure they move at the slightest touch. If one won't pop back up every time, it will give the symptoms you described. It may be as simple as a tiny scrap of paper wrapped over it, jamming it in its slot.
If the levers move freely, you may have a bad optical sensor underneath.
Oct 22, 2010 | Panasonic KX-FL511 Plain Paper Laser Fax
Symbol lit up but don't know what symbol means, I don't have manuel - begins with 2 dots :
The symbol with the 2 dots and what looks like a jagged line is the paper jam indicator. Open the paper tray and or front and back access doors to find and remove the paper jam. I the light still does not clear try turning the printer off then on to reset the jam indication.
Aug 20, 2010 | Lexmark E260 Laser Printer
Feb 04, 2010 | Computers & Internet
Paper jam, unable to pull paper out
Yeah, I would be careful though and only take out what screws you have to and document where they came from.
Jan 08, 2010 | Samsung CLP 315 Laser Printer
CONTINUING PAPER JAM. I OPEN DOOR, CLEAR THE JAM, AND PAPER STARTS TO FEED, THEN AGAIN ANOTHER PAPER JAM, AM I USING WRONG PAPER?
I know the problem, Its the Exit paper sensor! if u make a short circuit on the pin 2 and 3 of the CN2 when the paper reaches the sensor it wont jam. Chainging the sensor resolves the continous paper jam or try to clean it!
Apr 08, 2009 | Samsung CLP 315 Laser Printer
Printer always prin at the to of the page and then it will parer jam but no paper is in it to jam up I have a canon bjc-4200 and I like the print that it dose
hi there,
This problem mostly caused by another material (such as broken paper, etc) present in paper path prevent paper to reach paper cam sensor. Check inside your printer and clear paper path from another material. You can also try to clean paper feed roller. If problem still persist, replace paper feed roller
Regards
Source:
Canon Inkjet Forum
Nov 09, 2008 | Canon PIXMA iP1600 Printer
How do I clear misfeed.
In most cases where the machine says there is a jam, and there is no paper in the paper path, it's because the paper never got out of the paper drawer and didn't reach the 1st jam sensor. If you can open the machine and it resets, then chances are the paper feed roller is either slipping or in some cases not turning at all. If you can't clear the jam by turning off the machine, and back on, then you have a bad jam setect sensor or perhaps a small piece of paper lodged on the jam sensor. This will take some additional troubleshooting on your part. Need to know if the jam indicator goes away when you restart the machine. Let me know and I'll try to guide you from that point. Aloha, Bill Monroe
Sep 17, 2007 | Ricoh Aficio 1018D Copier
47 people viewed this question
jasbo
jasbo
