Question about LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive
Power not getting to my lacie 320GB D2
I just swapped out the power supply. The ps green light flasked when plugged into the drive but is solid when unplugged. Juice not getting to the drive - fried connection? How do I get fixed - would like to do locally rather than ship back.
Same here. I pulled the drive from the case and swapped it with another and the drive works fine. Must be the control board inside the case. Where can we find the replacement board?
Posted on Mar 15, 2010
Lucie power supply issues.
Just take the hard drive out the caddy and use it in another caddy. It will be easier and cheaper than fixing the caddy.
Jul 17, 2016 | LaCie mobile drives Power Supp Hard Drive
Drive stopped responding -- problem with power supply or drive?
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
if this fails to fix the problem
check usb leads for secure dust free seating
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Jul 05, 2012 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
I have an old LaCie d2 160GB Hard Drive Extreme with Triple Interface (circa 2005)... I have lost my power cord and I can't seem to be able to find one online to purchase...Does anyone know where I can...
your drive can be used with any D2 or Big Disk power supply as well as some LaCie Porsche power supplies (you need to make sure the connector is the same).
Searching for LaCie Power supply on eBay will give you a few hits that match your needs.
Regards,
Jan 10, 2011 | LaCie (300740) 160 GB Hard Drive
Unit never revs up to 10,000 rpms it tries about four or five times then stops and gets a blue blinking light.lacie d2 quadra 500 gb
if the unit has the original hard drives inside (i never one with 10 000 rpm drives though), the problem might be caused by a power issue.
Please verify the power supply by plugging it into the wall then listening to it. It should be silent. If there is a high pitch noise or hissing, it is defective and needs to be replaced.
If replacing the defective power supply did not solve your issue or if the power supply did not have any issue at all, the internal components will need to be inspected.
If you replaced the internal drives with 10 000 RPM drives, it might be why the drives do not get enough power.
Regards,
Dec 31, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Also getting a clicking noise and not showing up on computer
sounds like youve fried your hard drive. Has the computer been dropped recently?? Or you got a disk boot sector virus that has blocked access to the hard drive. the clicking is the data arms scratching into the disk media. Either way it means a new hard drive.
Jul 11, 2009 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Hello, I have a Lacie 330770 250 GB hard drive.  It does not respond when I plug it into the outlet.  I have tried several different outlets in different rooms, and neither the green light on the power...
If the green light on your LaCie power supply does not light, you likely have a bad power supply. You can buy a new one from LaCie. If you are purchasing a new power supply from LaCie ask for the higher wattage unit. LaCie upgraded this a while back.
Jan 26, 2009 | LaCie (300770) 250 GB Hard Drive
Problem with LaCie 500 GB d2 Quandraq
Contact Lacie support for a new power supply. I had the same problem, contacted Lacie support, they sent me a new power supply with power cord and all is well now.
Sep 22, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie Big Disk
Fixya is unable to suggest parts sources.
Dec 17, 2017 | LaCie 301294U 1TB Big Disk Extreme + with...
External hard drive
500Gb Lacie D2 Quadra with the same problem of flashing led and not mounting on the desktop (Mac G4 Mirror), traced to the power supply (57w) going down on power, both 12v and 5v supplies are available but the main power to run the drive drops to below an adequate output, hence the clicking and whirring evident from the drive with simultaneous flashing led.
Testing with another Lacie power supply (250Gb D2) this time a 34w unit got the drive up and running, however, and this is the reason for this post, this lower power PSU failed a week later whilst waiting for a warranty replacement from Lacie (5 weeks and still waiting for the new PSU from them. they have no stock)
Message for all Lacie D2 users, check the power supplies first, test with another Lacie PSU, do not run the drive on a lower rating (34w) PSU it will fry it and leave you with another failed power supply.
If you are in a tight spot use the temporary power supply to move your data to another drive and get the correct 57w power supply before running the drive again.
Don't do as I did assume any Lacie power supply will run any Lacie hard drive, they won't, fortunately I had a second back up, but am 2 drives down and no new PSU's available to buy anywhere.
Try and purchase another spare 57w power supply, something all D2 users should do for long term security, as these do not seem to be very reliable and getting warranty support from Lacie on these is currently impossible.
The lack of 57w power supplies from Lacie and its distributors across the world is surely a warning to be noted!!!!!!
Buyers beware!
Aug 08, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive Logo
215 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
