Question about Whirlpool GU2400XTP Built-in Dishwasher
Our new quiet partner III by Whirlpool is not cleaning our dishes well and soil is even on the bottom after cycle is complete. We have softened water and our glasses come out cloudy too. Never happened with our old dishwasher.
    Problem Solver:
  • 10 Answers
I have a Maytag model MDB9100 about 9 years old that's not worked well recently. Here what worked for me.
If the obvious solutions listed in your owners manual don't solve your problem the filters may indeed be the problem. Start by removing the lower spray arm. There is no need to remove the arm from what I'll call the "arm base/cover assembly"; keep it clipped on. At the center of the arm is a knurled screw. It looks like a thin disk with several bumps on it, about 2 inches in diameter. It will unscrew (lefty-loosy) and allow removal of the arm assembly. At quick glance it appears to be a molded part of the arm but that's a clever disguise. Making this part a different color would be too helpful. What else would the Maytag repairman do it they made it easy for the do-it yourselfer?
Anyway, after removing the spray arm take note (or photos) of the visible parts, i.e, spray nozzle, 2 split plastic spacers. Be sure you'll be able to return these to their proper position later.
Remove the six torx (star-shaped) screws and lift the impeller cover off. Again note/photograph the position of remaining parts, i.e. filter, impeller. You will likely find the filter clogged with debris. It can be pulled out. On my model it is retained in a groove and take a bit of force to remove. I used water pressure (sink sprayer) and a toothbrush to clean my filter.
Remove any debris from the sump/ drain area. Reassembly is reverse of installation. Be sure to flush out the arm assembly to unblock all holes before re-installing it.
I hope this helps.
Posted on Feb 04, 2010
I have a whirlpool Gold quiet partner III that is about 14 years old. It is no longer getting dishes consistently clean.Is it something fixable or is it time to get a new one?Could it be cleaned out?
There are many places and parts for dirt to remain after washing. Clean all parts as per manual. Spray inside with vinegar and lemon juice, place tablespoon of bi-carb soda in dispenser and put through cycle without dishes
Feb 25, 2015 | Whirlpool Dishwashers
I have a Whirlpool Gold Quiet Partner III dishwasher. When I unload the "clean" dishes, there is some type of film or crud on the dishes. I have to hand wash them to get this off. It seems like a...
You need to check the drain system completely, look for plugged screens, pump impellers, valves and the drain hose. You need to witness a large volume of water flow during drain.
Sep 19, 2010 | Whirlpool Dishwashers
Our quiet partner iii dishwasher is not working. It is not gettting dishes cleaned soap left on dishes
Our whirlpool gold quiet partner iii dishwasher is not working well . It is not gettting dishes cleaned soap left on dishes on top primarily
May 16, 2010 | Dishwashers
Our Whirlpool Quiet Partner III cleans the bottom rack fine, but the top rack does not seem to have any water pressure and thereby does not clean. Any solutions?
two things that you need to check one is the water level in the machine when it has completed it fill cycle.low water level will cause this issue with imporper cleaning.
make sure the spray arm is not clogged in any way.
the other is simply replace the main wash motor
Mar 09, 2010 | Dishwashers
Same problem. 2-3 inches of water left in the dishwasher at end.
Inspect for plugged drain screen. Sometimes you have to take apart the bottom area for access...
Sep 18, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Liquid soap mistakenly used - bubble explosion
Fill the detergent cup with fabric softener for a full cycle. Don't be alarmed if bubbles seep out.
Finish off with a white vinegar wipedown of the insides if it still feels soapy.
Sep 09, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Dishwasher is not getting dishes clean. Water is
follow this link:
http://www.fixya.com/support/t2390397-dishwasher_acts_up
that guy gave me some good advice!
Jun 09, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Quiet partner III taking over 4 hrs to complete normal wash cycle
ok check how fast the water is draining,,might be a bit slow...onthejob
Jan 20, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool gold quiet partner IV
You probably need to clean the filter; here is a site to show you how to do it: http://01tutorials.com/video/1686251/how-to-clean-the-filter-on-a-whirlpool-gold-quiet-partner-iv-dishwasher/4107
Sep 20, 2017 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool GU2400XTP Built-in Dishwasher Logo
1,287 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
