Question about Kenmore Vacuums
I got a sock stuck in the hose how do i get it out?
  • 670 Answers
Take a metal closthes hanger and undo the hook end from the spiral at the base of the hook, leave the hook and the coil that held the hanger together as is and straighten the rest. Put the spiral end of the hanger into the hose, when it reaches the sock twist the hanger to screw the spiral into the fabric, not too far, only a little. If you have enough grip on the sock, it should pull back out. You may have to try several times until the sock pulls free. Good luck.
Posted on Feb 04, 2010
There is a sock stuck in the hose of my dyson dc23 animal motorhead how do I get it out
Hi, this is Jim with Crucial Vacuum,
Detach the hose and stretch it out completely, if the sock is in a hard to reach place use a broom handle to push it out. Be careful to mind the edges of the hose you don't want to cause a tear, which would lead to poor suction.
You can purchase replacement parts for your Dyson DC23 direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/dyson-dc23-pre-filter-part-913394-01.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
May 08, 2015 | Dyson DC28 Animal Upright Vacuum New DC 28...
Was using vacuum and sock is now lodged in vacuum hose. How can I get the sock out?
The easiest way to remove an article of clothing from the hose is to remove one end of the hose from the vacuum, and reach in with a piece of wire with the end bent into a hook. A wire coathanger will work well for this. Just straighten out the coathanger, take a pair of pliers, and put a small bend at the end of the wire, in a J, or hook shape. Then, reach the wire into the hose, and when you feel the obstruction, twist the wire, so that the hook gets stuck on the sock. Then, pull it out, and reattatch the end of the hose back on the vacuum.
It doesn't matter which end of the hose you remove, just whichever is easier, and hopefully closest to the clog.
Do not try to push it out, as it will just bunch up tighter. It must be pulled out.
Jun 17, 2011 | Kenmore 31913 Progressive Direct Drive...
Sock stuck in hose midway. Unable to getit out with wire or brrom handle. Is there a way to take hose apart at either end.
If the sock is midway, taking either or both ends apart won't help. Take it to a vacuum repair shop and ask them to try to unplug it. You may need to buy a new hose.
Feb 22, 2011 | Kenmore 23913 Progressive PowerMate Bagged...
Sock in hose???
just push a longer rod down the hose its the only way to get this out i bet its right at the hover end to and a wire hook may get at it from were the hose gos into the hover bag,(mine gets blocked up there every time)
i use a lenth of welding wire with a hook bent in it but a coat hanger would do if you straiten it out first then bend just the first inch of it so it fits inside the hose
Jan 19, 2010 | Electrolux Central Vacuum
So... my friend sucked a sock in his maybe '07 bissell.
its there and is stuck itll take some time and patience to get it out its probally stuck at the sammlest poit pf suction .and the coat hanger and such is really the only way unless you wanna tear it down?
Jul 06, 2009 | Bissell 2600 Sweeper Vacuum
Any tricks to putting on a central vacuum hose sock? The last one took me 4 hours and I'm sure there must be an easier solution. It has no zipper.
Send it back and get one with a zipper. :) Okay did it come in a tube or with a tube? They are really necessary when putting a hose sock on. You first want to put the hose sock on the tube. You then slide the tube over the hose and take the hose sock off at the end. Tie the hose sock securely in place and start pulling the tube over the hose. The sock will slide off the tube and onto the hose as you go.
Jun 08, 2009 | Electrolux Central Vacuum
Sock stuck in hose
Yes there is a small clip on the purple/yellow part on bottom of hose. its hardly an inch thick pll back on the tab and up on the hose
Oct 28, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Blocked vacuum hose
You'll need a sturdy stick like a thick bamboo stick to push this out but remove the hose FIRST from the vacuum and compact the hose up before inserting the stick. Either that or you may have to order a new hose which can be cheap. What model is it you have?
May 09, 2008 | Vacuums
I have a sock stuck in the hose of my vacuum cleaner. Rennaisance canister model. Because of the design of the handle I can't utilize the reverse blower. Please advise. Thanks
lol
Try taping a fishing hook or some such onto the end of a straightened out coat hanger. See if you can push it up the hose and hook the sock.
Or, remove the hose entirely, and push a broom handle down the hose.
That's all I got...
May 07, 2008 | Vacuums
Stuck sock
first off how did u get the sock that far..lol but yes it (can but it is a pain and u chance tearin the hose but if ufeel like u have to better get a roll of duct tape just in case)but i would try the coat hanger a little more put a bend at the very end of hanger hook the sock and pull
Dec 30, 2007 | Electrolux Lux 5500 Canister Vacuum
Vacuums Logo
76 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
