Question about HP DeskJet 5150 InkJet Printer
Paper jam 3 times i tried to print the paper jammed. I opened the top door and saw that the clear plastic belt, or what ever you call it detached from the hook, don't know how this happened, was not fidiling with it. I see it just hook back, but it seems to be too long, do you run it through something on the print head or what? Do you have grafix to show me how?
  • Maritha Feb 20, 2008
    now where do i get that manual
    i just want to know how to attach the plastic belt thingy that runs along with the rod, or just above it
Any way you can post this service manual online or send it to me? I'm always fixing broken stuff for friends but this one has got me stumped, and it's my own printer. Can't figure out how to disassemble it and don't have a star-drive screwdriver either. I'd love to get a copy of that manual if you still have it around. I'm printing resumes and don't have the cash for a new printer right now.
Posted on Apr 01, 2010
    Genius:
  • 3,587 Answers
Only way to do this is with authorized service manual
Posted on Feb 20, 2008
  • Patrick Michaels
    Patrick Michaels Feb 20, 2008
    become an HP authorized service person..that's what it took for me....
Sir my printer problem is on printer menu write a clearing paper path what is this massage and give me solution.
Thank you contacting FixYa for your printer inquiry.
This error is associated with either a sheet of paper blocking the paper path or a partial piece of paper that blocks path or trips a sensor. The printer will usually throw up a error code 13.XX on the display and the XX is a number that will indicate where in the paper path this error most probably occurred. Just follow the steps for your error on the below chart.
This link will take you to the user guide which will be helpfull identifying components and providing guidelines for most of the helpful hints and things you will need to know about this printer.
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00218691/c00218691.pdf
Locate your error on the matrix below and follow the steps. Comment back if you need more help. Thank you again for contacting FixYa.
TF
HP Laserjet Error Codes 0 - 19 Message on printer Display Panel What it means. What to do. 13.XX PAPER JAM [LOCATION] Media is jammed at the specified location (and possibly at other locations). If the message persists after all jams have been cleared, a sensor or sensor lever might be stuck or broken. For all jam messages, do the following: 1. Remove jammed print media from the specified location. Check the entire paper path for other pieces of media in the path. 2. Open and close the top cover to clear the message. 3. Check sensors and flags in the paper path for proper operation. 3.0 PAPER JAM [LOCATION] A non-specific paper jam occurred. 1. Remove jammed media from the specified location. 2. Verify the paper tray is fully closed. 3. Inspect and/or replace the feed and separation rollers. 4. Ensure there is no obstruction in the path, such as a torn piece of paper. 5. Open and close the top cover to clear the message. 6. Check sensors and flags for proper operation. 13.1 PAPER JAM OPEN INPUT TRAYS Paper-delay jam at paperfeed area. 1. Ensure that paper trays are loaded and adjusted properly so media can feed from the tray. It might be necessary to reduce the stack height of media in the tray. 2. Check the input area for obstructions such as media in the path. Also check to see if the registration assembly damaged or unseated. 3. Replace any defective sensors or flags. 4. Verify the media meets the specifications. 5. Check the pickup feed and separation rollers for unusual wear. Replace as needed. 6. Rotate the media in the input tray by 180° and/or turn it over On NX engines this is most likely the fuser flag or the ACPM. The ACPM has a photosensor hard-wired to the back of it. 13.10 PAPER JAM CHECK DUPLEXER Jam at duplexer. 1. Check the duplexer and the rear area of the printer for obstructions or damage. 2. Check the duplexer for proper operation. Replace the duplexer if a sensor is defective. On a 5si, 8000, or 8100 series laserjet a Duplex Jam can be caused by a tray 2 and 3 feed assembly failure. 13.14 For Laserjet 5si. This error is caused by a defective paper control PCA Replace paper control PCA. 13.2 PAPER JAM OPEN INPUT TRAYS Paper-stopped jam at paper-feed area. 1. Check the input area for obstructions such as paper in the path. Also check to see if the registration assembly is damaged or if the transfer roller is out of place. 2. Replace any defective sensors or flags. 3. Ensure the media does not exceed the maximum length. 4. If multiple sheets are feeding, it might be necessary to fan the media and reduce the stack height. Also, replace separation pad. 5. Verify that the fuser is properly installed. On NX engines this is an input jam. 13.20 PAPER JAM CHECK REAR DOOR Media stopped in the paper path during power on or when the top door was closed. 1. Remove all media in the paper path, and then open and close the top cover. 2. If the message persists after all media is removed: Check if media is jammed in the prefeed area. Replace any defective sensors or flags 13.21 DOOR OPEN JAM The top cover was open while printing. 1. Clear the jam and close the top door. 2. If the message persists, check the top door switch for proper operation. 13.5 PAPER JAM CHECK REAR DOOR Paper-delay jam at fuser. 1. Check the transfer roller and small media belt to ensure they are operating and can feed print media. 2. Check the paper path for obstructions at the transfer roller, toner cartridge, paper feed assembly, and fuser. 3. Replace any defective sensors or flags. 4. Turn the media stack over and/ or rotate it by 180° in the input tray. If still persists - replace fuser, then DC controller. 13.6 PAPER JAM CHECK REAR DOOR Paper-stopped jam at fuser. 1. Check the paper path for obstructions at the fuser and output/delivery area. 3. Replace any defective sensors or flags. 13.99 PAPER JAM [LOCATION] A non-specific paper jam occurred. 1. Remove jammed media from the specified location. 2. Verify the paper tray is fully closed. 3. Inspect and/or replace the feed and separation rollers. 4. Ensure there is no obstruction in the path, such as a torn piece of paper. 5. Open and close the top cover to clear the message. 6. Check sensors and flags for proper operation
Jun 09, 2011 | HP LaserJet 4350 Printer
I have a problem. When I turn on my printer, the first symbol from top constantly blinks and it doesn't print anything. How can I solve this issue?
Welcome to FixYa!
If the first symbol on the top is constantly blinking as shown in the picture below, It means that a paper or a foreign object has jammed your printer.
Jam can occur in 3 areas. Please refer to the image below.
1. Internal Areas
2. Input Trays
3. The Output Bins
To clear the jam, turn the printer off and disconnect the power cord. Be careful not to tear the paper in case of a paper jam. If a small piece of paper remains in the printer, it could cause additional paper jam.
Let's clear out the Internal Areas first. Push the button to open the print-cartridge door, and then remove the print cartridge. To prevent damage, do not expose the print cartridge to light. Cover it with a piece of paper. Please refer to the image below.
If jammed paper is visible, grasp it with both hands and slowly pull it out of the printer. Please refer to the image below.
If no paper was jammed inside the print-cartridge door, open the Output Bin or the back door
of the printer. To avoid damaging the printer, do not attempt to clear a jam in the top output bin by pulling the paper straight out.
Again, if jammed paper is visible, grasp it with both hands and slowly pull it out of the printer.
If no paper or foreign object is visible, close the back door of the printer.
Next, let's take a look at the Input Tray. (We have already taken out the print cartridge.)
Lift the Tray 1 roller cover, grasp the jammed paper or foreign object, and slowly pull it out of the printer. Please refer to the image below.
If no jammed paper is or foreign object is visible, open Tray 2 and see if a paper is visible. Again remove it slowly with both hands. Please refer to the image below.
Close Tray 2.
If no jammed paper is visible in the second tray area, pull down the upper media guide (we have already taken out the print cartridge). With both hands, grasp the jammed paper and slowly pull it out of the printer. Please refer to the image below.
Close the upper media guide and return back the print cartridge. Please refer to the image below.
These steps should clear out any jams that you are experiencing.
Connect back the power cord again and turn on your printer. You should be able to print now.
Thanks for using FixYa. Keep me posted.
Jas247
Mar 03, 2011 | HP LaserJet Black-and-White Laser Printer
My printer comes up with a clear paper jam and press checked key. I have cleared all paper from machine and yet the light flashes and will not allow me to print and the same error code comes up. What...
Solution one: Turn the All-in-One off and on again Follow these steps to turn the product on, and then off again, to reset the print mechanism.
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Wait 15 seconds.
  3. Press the Power button (c01602202.gif ) to turn the product on again.
    NOTE: The product might go through a warm-up period of up to two minutes. The product lights might flash and the carriage might move. Wait until the warm-up period is complete before proceeding.
  4. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
  • If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting. Reconnect the USB cable, and then try to print again.
  • If the issue persists , continue with the next solution.
  • If the self-test report does not print , continue with the next solution.
Solution two: Clear any paper jam Jammed paper can cause the carriage to stall. Follow these steps to clear any jammed paper. Step one: Remove any loose paper Remove any loose paper from the input tray and output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear a paper jam from the front of the product can damage the print mechanism. Step two: Clear the paper jam from the back of the All-in-One Use the following steps to check for and remove jammed paper from the back of the product.
  2. Disconnect the USB or Ethernet cable from the back of the product.
  3. Disconnect the power cord from the back of the product.
  4. Remove the rear door. Push the door latches toward each other, and then pull the door away from the product. Figure 1: Remove the rear door c00244379.gif Illustration of removing the rear door
  5. Gently pull the paper out of the rollers. CAUTION: If the paper tears when removing it from the rollers, check the rollers for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more paper jams are likely to occur.
  6. If you are printing labels, see if any are missing from the label sheet. If any labels are missing, find them inside the product, and then remove them carefully.
  7. Reattach the rear door. Gently push the door forward until it snaps into place.
Step three: Clear the paper jam from the front of the product Follow these steps to remove the paper jam from the front of the product.
  1. Open the cartridge access door. Figure 2: Open the cartridge access door c01913998.gif Illustration of opening the cartridge access door
  2. If you find paper jammed in the product that cannot be removed through the rear door, gently remove the paper through the front of the product.
    NOTE: Remove paper from the front of the product as carefully as possible. If any torn pieces of paper remain inside the product, more paper jams are likely to occur, and this could damage the print mechanism.
  3. Close the cartridge access door. Figure 3: Close the cartridge access door c01913999.gif Illustration of closing the cartridge access door
  4. Reconnect the power cord to the back of the product.
  5. Press the Power button (c01602202.gif ) to turn on the product.
  6. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
Keep in this LINK.
Oct 26, 2010 | Dell 948 All-In-One InkJet Printer
Hi, my HP D4360 DeskJet printer isn't printing. Both the power and resume lights are on and blinking, as well as both the ink lights. Any advice would be much appreciated. Thanks
The power and resume lights blinks due to two reasons. 1) If there is any kind of paper jam in the printer.Then its internal assembly cannot move so the lights blinks.So clear the paper jam if any.Open the cover and check if any paper jam.also there is a access door at the back to check any paper jam.The back plastic door can be opened to remove paper jam. But if you are confirmed that there is no paper jam then the other possibility. 2) The printer cartridges are faulty and needs replacement.There are two print cartridges in the printer.One color and one black.Any of the one can be faulty or in some cases both are faulty.But before replacing cartridge remove the cartridge and clean the brown dotted circuit on cartridge then reinsert the cartridges and check.But if this does not solve the problem then replace the cartridge one by one and solve the problem. Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 05, 2010 | HP D4360 DeskJet Printer InkJet
The printer is constantly sending a message- 'paper jam'
HP Officejet 7200, 7300, and 7400 Series - 'Paper Jam: Clear jam, and then press Enter' Message Displays on the Control Panel Display
Issue
During printing, the paper becomes stuck in the all-in-one and the error message 'Paper Jam: Clear jam, and then press Enter' displays on the control panel display.
Solution
Use the following instructions to clear a paper jam from the product:
Step one: Check for and remove any loose paper from the In tray
Do not try to remove jammed paper from the In tray. First remove any loose paper from the In tray to avoid worsening the jam.
CAUTION: Always try to remove jammed paper from the back of the printer first to avoid mechanical damage.
Step two: Clear the jam from the back of the printer
Follow these instructions to clear jammed paper from the back of the product. If the product is equipped with a two-sided printing accessory, skip to that section.
Remove the rear access door to clear the paper jam
1. Remove the rear access door by pressing the buttons on the side of the door and pulling it toward you.
Figure 1: Removing the rear access door
Rear access door
2. Gently pull the jammed paper out of the rollers.
WARNING: If the paper tears while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If all the pieces of paper are not removed from the product, more paper jams might occur.
3. Replace the rear access door. Gently push the door into the all-in-one until it snaps firmly into place.
Remove the two-sided printing accessory to clear the paper jam
1. Remove the two-sided printing accessory by pressing in the buttons on the sides and then pulling the accessory toward you.
Figure 2: Removing the two-sided printing accessory
2. Gently remove any jammed paper.
WARNING: If the paper tears while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the accessory. If all the pieces of paper are not removed from the accessory, more paper jams might occur.
3. Press the button on top of the two-sided printing accessory to open the door.
Figure 3: Opening the two-sided printing accessory door
4. Gently pull the jammed paper out of the rollers.
5. Close the accessory door.
6. Reinstall the two-sided printing accessory.
Step three: Clear the jam from the automatic document feeder (ADF)
1. Remove the document feeder tray from the product by gently pulling it.
2. Lift the cover of the automatic document feeder by pulling it outward.
Figure 4: Lifting the cover of the automatic document feeder
Automatic document feeder (ADF) door
3. Gently pull the jammed paper out of the rollers.
WARNING: In the rare occurrence of a severe paper jam, you might need to remove the face plate from the front of the automatic document feeder and lift the pick assembly to remove torn pieces of paper from deep inside the automatic document feeder.
4. Close the cover of the automatic document feeder, and then reattach the document feeder tray.
Step four: Verify that the print carriage can move freely
Follow these steps to try to move the print carriage.
CAUTION: Do not force the print carriage to move if it is out of plain view or feels stuck. Forcing it may damage the printer.
1. With the product turned on, open the print cartridge access door. The print carriage might try to move into the access area. If so, allow it to move to that position.
2. Without turning off the product, unplug the power cord from the back of the product. Unplug the power cord from the power source. The power cord must be unplugged to allow the parts to be moved by hand and to reset the paper feed mechanism, without the risk of an electrical shock.
3. Looking in through either the print cartridge access door or the output paper tray, make sure the print cartridges are locked into the carriage and have not come loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving.
4. Make sure the print carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found.
You may have to reach through the output paper tray to access the print carriage.
5. Close the print cartridge access door and plug the power cord back to the back of the product. Plug the power cord into the power source.
6. Press the On button to turn on the product.
Step five: Reload and test the printer
After you have removed the jammed paper, make sure the product is still functioning properly.
1. Reload the product with plain paper.
2. Peform a self-test by pressing and holding the RESUME button on the control panel until the product begins printing. A test page prints.
Step six: Service the printer
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Dec 30, 2009 | HP DeskJet 3745 Printer
HP 6540 Lights flashing can't print
This indicates a paper jam or the printer is out of paper. Do not clear a paper jam from the front of the printer.
The printer might be out of paper
1. Place paper in the In tray.
2. Press the Resume button on the front of the printer.
There might be a paper jam
1. Press the Resume button. If the paper jam does not clear, then go to the next step.
2. Push the two latch handles on the rear access door toward each other, and then remove the door.
3. Remove any paper that is inside the printer by pulling it out from the back of the printer. If you are printing labels, verify that a label did not become detached from the label sheet while passing through the printer.
4. Replace the rear access door.
5. Press the Resume button.
If the Two-Sided Printing Accessory is attached to the printer, follow these steps to clear a paper jam from the Two-Sided Printing Accessory.
1. Turn off the printer.
2. Press the buttons on the left and right sides of the duplexer, and then remove it from the printer.
3. Remove any paper inside the printer.
4. Open the duplexer.
5. Remove any paper from inside the duplexer.
6. Close the duplexer, and then re-attach the duplexer to the printer.
If the Auto Two-Sided Print Accessory with Small Paper Tray is attached to the printer, follow these steps to clear a paper jam
2. Press the buttons on the left and right sides of the accessory, and then remove it from the printer.
3. Remove any paper that is inside the printer.
4. Lift the back lever on the accessory, and then unhook the Small Paper Tray
5. Tilt the Small Paper Tray forward and open the lower door of the accessory.
1. Tilt the Small Paper Tray
2. Open the lower door
6. Remove any paper that is inside the accessory.
7. Close the accessory, and then secure the back lever to close the accessory.
8. Re-attach the accessory to the printer.
Oct 03, 2009 | HP DeskJet 6540 InkJet Printer
My printer made a weird noise and now says "Open door Clear carriage jam and then press Enter". How do I clear a carriage jam? I have opened the top cover and usually the print cartridges move to the...
Issue The error ' Open Door, Clear Carriage Jam, and then Press Enter ' displays on the product. The following symptoms might also accompany this error:
* The product will not print. * Printing stops unexpectedly. * The carriage does not move.
Try the following solutions in the order presented to resolve the issue. When one of the solutions resolves the issue, there is no need to continue troubleshooting. Solution one: Turn the All-in-One off and on again
1. Press the Power button ( ) to turn off the product. 2. Press the Power button ( ) to turn the product on again.
* If these steps resolved the issue , you do not need to continue troubleshooting. * If the issue persists , continue to the next solution.
Solution two: Clear any paper jam A carriage jam might follow a paper jam. Follow these steps to check for and remove any jammed paper. Step one: Check for and remove any loose paper from the input tray Remove any loose paper from the input tray, the output tray, and the automatic document feeder (ADF). CAUTION: Do not remove jammed paper at this stage. Step two: Clear a paper jam from the rear access door WARNING: Always clear paper jams through the back door if possible. To avoid tearing the paper and damaging the print mechanism, pull paper from the printer slowly and gently. Avoid touching the internal components of the printer.
1. Disconnect the power cord from the back of the printer. 2. Remove the back door and remove as much jammed paper as possible.
3.Replace the back door and open the carriage access door. If there is paper visible that cannot be removed through the back door, gently pull it out from the front.
4. Reconnect the power cord and close the printer.
Solution three: Make sure that the carriage moves freely
1. With the product turned on, open the cartridge access door. The carriage might try to move into the access area. If so, allow it to move to that position. 2. Without turning off the product, unplug the power cord from the back of the product. WARNING: You must disconnect the power cord to move parts by hand without the risk of an electrical shock. 3. Look in through either the cartridge access door or the output paper tray to make sure that the cartridges are secure in the carriage and not loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving. 4. Make sure the carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found. You might have to reach through the output paper tray to access the carriage. 5. Close the cartridge access door and reconnect the power cord to the product. 6. Press the Power button ( ) to turn on the product.
Solution four: Remove and reinsert the print cartridges Incorrect installation of the print cartridges can cause the product to show a false carriage jam. Follow these steps to remove, and then reinstall the print cartridges. Step one: Remove the print cartridges
1. Press the Power button ( ) to turn off the product. 2. Open the front of the product to access the carriage. The carriage moves to the center of the product.
3. Unlatch the two print cartridge latches, and then raise the latches. 4. Remove the print cartridges.
Step two: Reinsert the print cartridges
1. One at a time, hold a print cartridge with the printed label up, and then slide the print cartridge into its slot. Repeat this step for the other print cartridge.
# NOTE: Insert the black print cartridge into the slot with the gray latch, and insert the color cartridge into the slot with the blue latch. # Grasp the end of the latch on the cartridge slot with your thumb, and then pull the end of the latch toward you. While holding the latch, press down on the top of the latch until it stops, and then release the end of the latch so that it catches under the tabs. CAUTION: To avoid damaging the product, do not force the latches into place.
3. Close the product cover. A message displays on the control panel to align the print cartridges. 4. Press the Enter button to begin the cartridge alignment. Two pages print. Follow the instructions printed on the second page to complete the alignment. 5. Try the print job again.
Jul 08, 2009 | HP PSC 2175 All-In-One InkJet Printer
New out of the box 13:20 error paper jam there has never been any paper in machine we're just setting up. open and close front, then theres a fuser jam lift and close top, front door again.We have paper in...
Jun 24, 2009 | HP LaserJet 3600n Printer
HP DeskJet 5150 InkJet Printer Logo
115 people viewed this question
Seeker5211
Seeker5211
