Question about LG Computers & Internet
Problem with an LG monitor being used with a MacIntosh lap top
  • 1 more comment
  • jdrescher Feb 04, 2010
    Just hooked up LG W2286L to sideport of Mac but the screen on the lap top does not show up on the LG (just a purple-ish outer space background) and the cursor doesn't show up on the screen either?
    Have you received my second response?
    No I have never had them working together and I don't know how to adjust the resolution you speak of. I have been able to see the cursor now on both screens.
  • 4,472 Answers
What is the model of the monitor? What kind of problem are you having? Have you had the two working together before without a problem? Once I have more information I can assist you further. Please give as much detail as possible.
Thank you,
Lee
Posted on Feb 04, 2010
  • Lee A.
    Lee A. Feb 04, 2010
    So you haven't had them working together at all before? Have you tried adjusting the resolution output at all? Do you know the monitor itself works? Please use as much detail as possible.
    Thank you,
    Lee
  • Lee A.
    Lee A. Feb 04, 2010
    What kind of mac laptop is this? Here is a youtube video that may help you.
    Thank you,
    Lee
My Lg monitor L1950B is not displaying anything on the screen but power is on..Help please
of the power lamp glows. and the OSD is dead.
then its dead.
check AC power, carefully, use a desk lamp to be 100% sure
there is power. if power lamp is off.
if OSD works
then plug in Display to another PC or lap top.
the Lap has an external monitor key, that must be pressed.
if the screen good, the so be it, bad pc.
if screen is dead, so it is.
Sep 27, 2013 | Computers & Internet
I have an LG W3000H which should be able to get excellent resolution (2560 x 1600). But, I'm only getting 1280 x 800. And, I can't increase the resolution any further. I'm using a Dell latitude 6410...
The limit is due to your video card in your computer, did you try to install the monitor driver on your lap top for this monitor since it needs the inf file for the computer to know what kind of resolution this monitor can support. You also may not have enough memory for the video card since it is shared memory with the CPU.
Oct 01, 2010 | LG W3000H-Bn Monitor
Using two monitors attached to my lap top and can only use one of the two screen
  • Attach two monitor and switch on the laptop
  • automatically second monitor will show diplay
  • if not then find out dual display symbol on the taskbar click on it.
  • window will open select dual monitor
  • click apply
  • if not then right click on desktop --properties--desktop two monitors symbol will see select 2nd monitor
Apr 17, 2010 | E-Machines eMachines Monitor E15T4
I am using the LG Flatron L1715S 17" LCD Monitor as an external monitor for my lap top as the screen on my lap top is toast. What I cant figure out is how to size the screen to fit the proper dimensions of...
The FLATRON L1715S color LCD monitor with auto-synchronous support, plus it is PC and MAC compatible, has features like simple one button auto setup and is VESA DDC2B, DDC1, Plug and Play compatible.
use the 'Auto' adjust button on ur lcd..
howevr, if u want to configure using win xp/vista..right click on ur desktop->properties->settings->increase the 'screen resolution' to minimum: 640x350 or standard: 1152x864 or maximum: 1280x1024 @ 75Hz..
best is to seek professional advice of ur system admin/vendor....
Nov 05, 2009 | LG Flatron L1715S 17" LCD Monitor
I have a LG lap top,vertical lines on LCD screen
Try replacing the inverter, if you plugged in a monitor and are still getting the screen then the onboard video has gone to ****.
http://www.lge.com/support/manual.jsp
Go there and search for the manual, input your region as North America then choose USA, opt out of the survey and download the manual in pdf form.
Feb 18, 2009 | Computers & Internet
White thin line verticaly middle of lap top screen
Sounds like the monitor. Do you have another monitor to hook up to the laptop? If so, that will tell you precisely if it's the monitor or video card.
Dec 21, 2008 | LG Flatron L1750S 17" LCD Monitor
Blank screen on my monitor
kindly check display settings in your laptop.....
Dec 02, 2008 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Blurry and shaking pictures on LCD
refresh rate, likely
try to adjust to a compatible rate. the monitor manual will give you its compatible rates. the video card should have that rate available. if not, you may damage the monitor with the wrong rate.
stop and try another monitor that has a refresh rate available on your video card.
good luck
mark
Dec 10, 2007 | LG 42LC2D 42 in. LCD HDTV
Lg monitor won't come on
Try connecting the LG monitor to the VGA port on the HP tablet instead on the docking station.
Aug 06, 2007 | LG L1920P 19" LCD Monitor
Monitor not working.
The USB connector isn't for video. You plug a USB cable to a free USB port on your PC then plug that into you?re the type B USB connector (squarish with two rounded edges) on your monitor. Somewhere on your monitor you will fine two standard type ?A? USB sockets (rectangular), basically your monitor has a USB hub built into it for convenience. You will have to either get a new video card with a DVI output or an adaptor to convert DMI to VGA. Most of the ones I've seen are $50 or more.
Jul 14, 2007 | LG Refurbished 15 GOLDSTAR LCD LM151X1...
Computers & Internet Logo
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
