Loaned my heater to neighbor, he ran it out of fuel. put more fuel in and it started spitting raw fuel and firing intermittently. I cleaned igniter plug and blew out igniter hole and fan motor,generally everywhere I could get compressed air. It started again and runs but continually sputters, but no longer spits out raw fuel. any ideas how to make it run smooth again?
  • Heating & Co... Master
  • 3,280 Answers
Hi you will have to clean it all out till you get all the stuff ou tof it it has pulled all this through from being run dry , you not far off just more to do
Posted on Feb 04, 2010
Heater is cycling on and off, less then one minute cycle time between cycles. Sometimes SPK code comes on and stays on without firing. Have shorted water press switch with no effect. Pretty sure gas...
The SPK Code, indicates that there is power to Igniter and should be producing a Spark to ignite fuel! If this is actually the case, then it is NOT a safety sensor issue, The igniter serves a dual purpose: produce a spark, and then CONFIRM a flame is consuming the fuel. If it does not get a proper Milivolt reading, then gas valve will shut off, hence a cycle occurs. Not enough reading is the same to the heater as no reading! Safety issue. If gas valve stays open, and no flame to consume raw fuel, it will build up and accumulate then when ignition takes place, it go...BOOM! Not Good.
Either insufficient fuel supply/pressure or faulty igniter. It's also not a Gas Valve. It's a simple switching valve, either open or closed.
Mar 16, 2015 | Raypak Digital Low-NOx R.337A Heater...
Bang at start up pentair heater
What kind of bang, like an explosion? if so, then a burner orifice or more than one orifice or the burners, are plugged. What is happening, raw fuel is not reaching hot surface igniter quick enough. The raw fuel then collects from a further orifice, and by the time that it reaches the hot surface igniter, there's a little bit too much fuel, and there is an explosion. Which is not normal. You need to clean the orifices and the main burners.
May 17, 2014 | Pentair Pool & Spa
Generator back firing from inlet manafold
Your symptoms are from running lean. Foam air filters put debris in carb jets. Check all the carb passageways and jets. Always start with a new plug.
Nov 29, 2013 | Electrical Supplies
Fouled plugs in #2 and #8 . Changed all plugs and still have a miss and the smell of raw fuel
ignition wires is agood start , check all wires for spark out put with spark tester saves a lot of time.
Oct 29, 2012 | 1997 Chevrolet Tahoe
No,4 plug not fireing changed plug wires.new coil.plug ran good for 100 miles then 4 stop again
You would need to figure out if it is a problem inside the cylinder or with something like the crank-cam sensor firing the coil. I would change the plug again to see if it works for a few days.
Could be a problem with the fuel injector or a vac leak if the plug is firing but no power from that cylinder.
Oct 01, 2012 | 2000 Ford Focus
Front cylinder dumping raw fuel, exits under exhaust pipe. Cylinder not firing.
pull the vacuum line from the regulator and turn the key on and see if gas drips or sprays out from the nipple on the regulator if so that's your problem the fuel is going threw the line into the intake port
Aug 05, 2012 | Cars & Trucks
I have a 95 Road King that isn't running right, it
Backfiring out of the exhaust is usually an ignition problem. Unburned fuel is getting into the exhaust system because it's not being ignited in the cylinder. When the engine fires on that cylinder again, it ignites the raw fuel in the exhaust causing the pop that people call a backfire. I'd investigate the ignition system. Connect a timing light to each of the spark plug wires if it has a single fire ignition or either of them if the ignition system is the stock dual fire. Start the engine and watch the timing light to tell if the engine is missing as the light will miss a flash.
Good Luck
Steve
Jun 05, 2011 | 2000 Harley Davidson FLHR-FLHRI Road king
When heater starts it does not always light, I get a C3 code
the ignitor is faulty, mine also did that and I noticed one night that it was shorting out right from the ignition box. I put in a new ignitor and flame sensor and it's fine now. All ignitors are basically the same you just have to do some creative wireing. reddyparts.com still has most parts for your heater.
Jan 20, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Clicks but wont fire
make sure the high voltage lead to the sparkplug isn't touching anything metal on its way to the plug. the clicking may be the high voltage discharging to a metal part, not the plug. those wires age during use.
Dec 01, 2007 | Reddy R70ET Utility Heater
Heating & Cooling Logo
93 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
