Question about Lexmark X3650 Printer
How do i change print cartridge? - Lexmark X3650 Printer
    Scholar:
  • 126 Answers
Plug in your printer, turn it on, then lift cover from front, not just scanner cover, reach lower. Carriage will move back and forth a few times before settling in middle of printer. Pull forward on both levers to release covers over print cartridges. Lift up on cartridge on end closest to you and then pull toward you and up to remove cartridges.Remove tape from new cartridges and install as per instructions on box new cartridges came in or just reverse removal instructions.
Posted on Feb 23, 2010
I70 Canon photo printer will not print after changing print cartridge.
Check the black cartridge and make sure the orange or yellow tape at the rear end is not still attached. If it covers the small hole on the top of the cartridge, the printer won't print black text.
Mar 09, 2012 | Canon BubbleJet i70 InkJet Photo Printer
Epson printer will not print any copies. I get the message "change cartridges 98/99." I did change both cartidges and can't clear the message and print copies.
i assume that everytime you try to print you get the same message. i sometimes get cartridge unrecognised on my epsom. I have to remove the cartridge, wipe the chip on the cartridge and reinsert.
If this doesnt work please specify printer model and if using original epsom cartridges.
Nov 15, 2011 | Office Equipment & Supplies
What is the replacement printer for HP Laser Jet
This document provides information about replacing the print cartridge for the HP LaserJet 1010 printer series, including life expectancy and replacement instructions. Print cartridge life expectancy The life of the print cartridge depends on the amount of toner that your print jobs require. When printing text on letter/A4-size paper at five percent coverage, the print cartridge lasts an average of 2,000 pages. This assumes that you set the print density to three and disable EconoMode. (These are the default settings.) See Ordering supplies for information on ordering replacement print cartridges. Changing the print cartridge Follow the below instructions to change the print cartridge:
  1. Open the print cartridge door, and remove the old print cartridge. See the recycling information inside the print cartridge box. Figure 1: Removing old print cartridge c00028312.gif CAUTION: To prevent damage, do not expose the print cartridge to light. Cover it with a piece of paper.
  2. Remove the new print cartridge from the packaging, and gently shake it from side to side to distribute the toner evenly inside the cartridge. Figure 2: Gently shaking new print cartridge c00028313.gif
  3. Pull the tab until all the tape is removed from the print cartridge. Put the tab in the print cartridge box to return for recycling. Figure 3: Removing tape from print cartridge c00035442.gif
  4. Insert the print cartridge in the printer, making sure that the print cartridge is in position. Close the print cartridge door. Figure 4: Inserting new print cartridge c00028315.gif
Apr 20, 2010 | HP LaserJet 1010 Printer
How do i change the print cartridge?
Replacing the print cartridge
  1. Open the print cartridge door, and remove the old print cartridge. CAUTION: To prevent damage to the print cartridge, minimize its exposure to direct light by covering it with a sheet of paper. Figure 1: Removing the print cartridge c01174123.jpg
  2. Remove the new print cartridge from the packaging. CAUTION: To prevent damage to the print cartridge, hold the print cartridge at each end.
  3. Pull the tab until all the tape is removed from the cartridge. Put the tab in the print cartridge box to return for recycling. Figure 2: Removing the sealing tape c01211568.jpg
  4. Gently rock the toner cartridge from front to back to distribute the toner evenly inside the cartridge. Figure 3: Shaking the print cartridge c01211569.jpg
  5. Insert the print cartridge in the device and close the print cartridge door. Figure 4: Inserting the print cartridge c01174125.jpg CAUTION: If toner gets on your clothing, wipe it off with a dry cloth and wash the clothing in cold water. Hot water sets toner into the fabric.
NOTE: When toner is low, faded or light areas appear on the printed page. You might be able to temporarily improve print quality by redistributing the toner. To redistribute the toner, remove the cartridge from the device and gently rock it from front to back.
Sep 13, 2009 | HP Office Equipment & Supplies
I just changed my black ink cartridge. Now, after
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth. Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Aug 18, 2009 | Office Equipment & Supplies
Changing cartridge on printer
The Basics manual from HP:
http://h10032.www1.hp.com/ctg/Manual/c00694908.pdf
Check out page 17 of the Basics manual for detailed instruction on replacing the cartridges.
Make sure the HP All-in-One is on.
Caution If the HP All-in-One is off when you open the print cartridge door
to access the print cartridges, the HP All-in-One will not release the
cartridges for changing. You might damage the HP All-in-One if the print
cartridges are not docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then lightly press down on a
print cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge
from the slot on the right.
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
5. Pull the print cartridge toward you out of its slot.
6. If you are removing the black print cartridge in order to install the photo print
cartridge, store the black print cartridge in the print cartridge protector or an
airtight plastic container.
If you are removing the print cartridge because it is low or out of ink, recycle the
print cartridge.
7. Remove the new print cartridge from its packaging and, being careful to touch
only the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
Caution Do not touch the copper-colored contacts or ink nozzles.
Touching these parts can result in clogs, ink failure, and bad electrical
connections.
8. Slide the new print cartridge forward into the empty slot. Then gently push on the
upper part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
9. Close the print cartridge door.
If you installed a new print cartridge, the HP All-in-One prints a print cartridge
alignment sheet.
Note If you have colored paper loaded in the input tray when you align
the print cartridges, the alignment will fail. Load unused plain white paper
into the input tray, and then try the alignment again.
If the alignment fails again, you might have a defective sensor or print
cartridge. Contact HP Support. Go to www.hp.com/support. If prompted,
choose your country/region, and then click Contact HP for information on
calling for technical support.
Jan 03, 2009 | Office Equipment & Supplies
Change ink cartridge
Here is the procedure to change the ink cartridge
  • First Press the POWER button to turn on the printer.
  • Open the top cover.The cradle moves to the center of the printer.Open the cradle latch.
  • Slide the print cartridge out of the print cartridge cradle and discard it.
  • Remove the replacement print cartridge from its packaging and carefully remove the plastic tape. Hold the print cartridge so that the copper strip is on the bottom
  • Slide the print cartridge firmly into the cradle. Ensure that the copper contacts the print cartridge meet the copper contacts of the print cartridge cradle
  • Close the cradle latch.
  • Verify white paper is loaded in the printer, then close the top cover. The printer automatically prints a calibration page for optimum print quality.
good luck:-)
Oct 08, 2008 | HP Office Equipment & Supplies
I have a hpdeskjet f2180 and need to change the ink cartridges. How do I get to the cartridges to change them !
Installing print cartridges
  1. Make sure the HP All-in-One is on. CAUTION: If the HP All-in-One is off when you open the print cartridge door to access the print cartridges, the HP All-in-One will not release the cartridges for changing. You might damage the HP All-in-One if the print cartridges are not docked safely when you try to remove them.
  2. Open the print cartridge door. Figure 1: Opening the print cartridge door c00906461.jpg Make sure the print carriage moves to the center. If it does not move to the center, turn the device off and then turn it back on again.
  3. Remove the tape from both cartridges. Figure 2: Removing the tape from a cartridge c00651128.gif CAUTION: Do not touch the copper-colored contacts or re-tape the cartridges. Figure 3: Copper-colored contacts c00651129.gif
  4. Hold the cartridges with the HP logo on top.
  5. Insert the tri-color cartridge in the left cartridge slot and the black cartridge in the right cartridge slot. Figure 4: Carriage slots c00853116.jpg Figure 5: Inserting the tri-color cartridge in the left slot c00853117.jpg
  6. Make sure you push the cartridges in firmly until they snap into place. Figure 6: Pushing the cartridge in firmly c00853118.jpg Figure 7: Tri-color cartridge and black cartridge correctly installed c00853119.jpg
  7. Close the print cartridge door. Figure 8: Closing the print cartridge door c00906462.jpg
Aligning print cartridges The HP All-in-One prompts you to align cartridges every time you install or replace a print cartridge. You can also align the print cartridges at any time from the control panel or by using the software you installed with the HP All-in-One. Aligning the print cartridges ensures high-quality output. NOTE: If you remove and reinstall the same print cartridge, the HP All-in-One will not prompt you to align the print cartridges. The HP All-in-One remembers the alignment values for that print cartridge, so you do not need to realign the print cartridges. To align newly installed print cartridges
  1. Make sure you have letter or A4 unused plain white paper loaded in the input tray. The HP All-in-One prints a print cartridge alignment sheet. NOTE: If you have colored paper loaded in the input tray when you align the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.
  2. Load the print cartridge alignment sheet print side down on the left front corner of the glass with the top of the page to the left. Figure 9: Loading the alignment sheet c00906464.jpg
  3. Press the Scan (c00906465.jpg ) button. The HP All-in-One aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
Jul 29, 2008 | HP Office Equipment & Supplies
How do I change HP 5610 print cartridges.
gtabseps.gif Introduction Follow the instructions below to replace the print cartridges. This document applies to the following products:
  • 5605
  • 5608
  • 5610, 5610v, 5610xi
Replace the print cartridges Step one: Remove the print cartridges
  1. Make sure the HP All-in-One is on. Press the On button to turn on the HP All-in-One. The On button is lit when the HP All-in-One is on. Figure 1: Press the On button to turn the product on c00442142.gif 1 - On button CAUTION: If the HP All-in-One is off when you open the print-carriage access door to access the print cartridges, the HP All-in-One will not release the cartridges for changing. You might damage the HP All-in-One if the print cartridges are not docked safely on the right side when you try to remove them.
  2. Open the print-carriage access door by pulling it forward. The print carriage moves to the far right side of the HP All-in-One. Figure 2: Open the access door c00442143.gif
  3. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it. Figure 3: The print carriage c00316910.gif
    • If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
    • If you are replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.
    Figure 4: The print cartridges in the proper position c00442144.gif 1 - Print cartridge slot for the tri-color print cartridge 2 - Print cartridge slot for the black and photo print cartridges
  4. Pull the print cartridge toward you out of its slot.
Jun 21, 2008 | Office Equipment & Supplies
Lexmark X3650 Printer Logo
53 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
