Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony WEGA Trinitron 32" HDTV - no signal
I received this with a No Signal problem. I turned on the TV, hooked up to my cable, and still got that. The No Signal is shown in the top left in a rectangular "box" across the top of the screen, with "8" in it's own box in the top right. Because of this, I can't change channels to determine if I'm even getting any audio. When I do turn it on, I see a red LED blinking 10 times, then I get the No Signal. Any ideas?
Also, I need to find a new case for it. The case is broken, but that happened after I brought it home - it almost completely fell off my handtruck. But that's minor, to my No Signal problem
  • davidsbronco Feb 21, 2008
    1. "unit good in raster and sound" - what?? Basically, just check the voltage across the tuner section of the board, right?
    2. try the memory - it's become clear to me, that I'll need a schematic for this, so I know what, where, how to check for these things. How much voltage should I be looking for, at any particular spot on the board? If I find the memory is bad, where would I find a replacement?
    still looking for a solution to my broken case dilema, too. Anyone know where I can find an empty case for this? If nothing else, I'll just build it into a new entertainment center, but wanted to try this, first
    Problem Solver:
  • 5 Answers
1. Unit good in raster & sound but you said that it has NO SIGNAL so try to check your Tuner Ckt.specially voltage supply that are estated in that particular section.
2. Try also your Memory to replace.
3. Check all estated voltage in all particular ckt. for every section that are possible cause for the problem.
Posted on Feb 21, 2008
Is the sony trinitron 32"
U have pay cable or satalite service tv incomming broadcasting signal.Yes,than ur tv no need for a DTV converter.Those pay boxes will revert back to analog signal for ur analog tv.If u planning to get free over the air broadcasting,than u need a converter box to convert digital signal to a analog tv.
Mar 21, 2011 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
I have a 32 in sony trinitron and i do not know
You need a matching transformer, or 'balun'.
Any home electronics store will have these. $3-$5.
Now, if this TV does not have a cable connector on the back, there is a good chance you will not be able to receive many of the channels (not a cable-ready TV).
Jan 11, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
KV-27FV17 No Signal When we turn it on it shows No signal...Help
check cable/ antenna first,if everything okay, the tuner assembly might be ta fault.
Aug 30, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Wega Trinitron HDTV Blue Screen with Sound
Had similar problems with HD cable on dvd. swapping with another cable solved the problem.
Aug 11, 2009 | Televison & Video
Lost some stations on my Sony lcd TV.
It is most likely a signal issue. Bad coax connections, splitters and faulty cable are usually the culprit. Best to call your cable company and request a signal test. You may also try swapping tvs. Swap sony with viewsonic in the room where viewsonic tv is.
Jul 03, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
"No signal"
It could be a bad barrel at he TV and at the wall. Your cables and connector could be of poor quality. You may also have a signal issue. Has anyone fron the cable company be out to take a signal reading?
Nov 09, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
I want to connect HD cable signal to HD projector
not directly unless it says hdtv somewhere or you need a converter box.
Oct 21, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
"No Signal"
Might need a tuner, I suspect if you arent seeing any snow/static you probably need to press the tv/video button untill you get the ANT input.
Jul 31, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
619 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
