Question about Philips Health & Beauty
I have cut out the old rechargeable batteries in my Philishave after it has been out of use for many years. Plugging it in using the 5 volt transformer, it runs, but far too slow and has no power. What can I do to fix it? Could it be worn brushes?
  • otvik Feb 04, 2010
    Model no is HP1318
    I looked for brushes, but motor unit is sealed (not openable) - don't know if it has brushes
  • shaveroutlet.com
    shaveroutlet.com May 11, 2010
    What is you shaver model number?
  • Philips Master
  • 1,623 Answers
It is more likely that the problem you are having now is a result of the batteries missing. The shaver is not made to be used without batteries installed and running it without batteries not only can cause a few different operational problems but can also be a hazard. If you need batteries, you can get them at shaveroutlet.com. See link below.
http://shaveroutlet.com/shaver-battery-for-older-norelcoremingtonronsonwindmerewahl-p-212.html
It is possible that your motor brushes are bad. You can not replace them but you can check them. Remove the motor from the shaver by removing the two metal clips that hold it in place. Then carefully and gently pry off the plastic back of the motor with a flat jewelers screwdrived. Dont stick the screwdriver in too far or you will damage the delicate brushes. You will easily be able to tell if they are worn out once you get the back off. If they are OK, you will need to put the motor back together. Snapping the back of the motor back on can be difficult and you will have to be careful not to damage those delicate brushes. If the brushes are bad, you'll need to get an old used motor from a shaver repair shop. I suggest emailing info@shaveroutlet.com for availability.
Posted on Feb 04, 2010
Testimonial: "Thank you very much - if batteries are needed, I can solder back in (still read 3V). I cut them out because they were old, and I didn't think needed."
  • shaveroutlet.com
    shaveroutlet.com Feb 04, 2010
    If the batteries are old and you like the shaver, I suggest you install new ones. The old batteries will corrode if they haven't already. In time, corrosion will ruin the shaver just like an old corroded set of batteries will ruin a flashlight which we've all had happen before. The batteries can also short out internally when they get old which will render the shaver unusable.
    It's a small investment and will ensure that the shaver runs for many more years.
  • 4 Answers
Rechargeable batteries only have a limited life span. You can only use rechargeable batteries for your shaver within couple of years maybe but not necessarily mean for a life time. Yes, it is possible for it to work but not as functional as before because you haven't already used it for years now.
Posted on Nov 28, 2010
The charger that comes with Homelite 24v mower is crappy. I've gone thru 3 of them. What's a better alternative?
I have used a DieHard portable battery charger (model 200.71222) for several years to recharge my 24-volt, 18-year old Craftsman mulcher, model 315.370270. This is after the on-board charger died. I just disconnect the link between the two 12-volt batteries and remove all other battery connections. Then connect the charger leads to the positive and negative terminals on one of the batteries before plugging in the charger. I put the settings on the charger at conventional low maintenance and 2 amps. Charge one battery and then the other (assuming you have two 12-volt sealed lead acid batteries like my mower). I use binder clips 530-t.jpgfrom an office supply store to hold the battery wires on the terminals when I'm mowing...makes it simpler to remove and reattach for charging instead of the nut-and-bolt connectors that came with the mower.
May 14, 2012 | Garden
My battery does not hold the charge, i will charge it for 24/hour and it only last 5 minute, why is that, iI buy this product for wife when went to Iraq, and when i talked ton her on the phone three months...
NiCad batteries have this problem when they are recharged frequently after being only partially discharged. This is also the case when the batteries are left in the charger continuously - even if the charger is described as being "automatic". I have old 12v batteries that I have been using for 20 years, but I only charge them for a few hours, and only when they have run down enough to be useless. I prevent leaving them too long in the charger by using a timer that cuts the power to the charger after a couple of hours. A couple of years ago I bought new drills and chargers, and believed that the chargers would be automatic and so could be left plugged in. Those batteries only lasted a couple of years, while the old ones are still going strong. I now use the timer for any of these chargers, automatic or not - but I had to buy new batteries first. good luck, Al K
Jul 29, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
Milwaukee tool 18 volt nimh battery won!t charge
If the battery pack is more than 2 years old its time for a replacement. The typical charge/discharge life cycle of a rechargeable cell is 500 - 700 times and the shelf life is about 3-4 years from the date of manufacture. If the charging indicator lights up when you dock the battery on to the base and still does not work after 5 hours - its due for a replacement.
Apr 08, 2011 | Dewalt Accessories Batteries 18 Volt
I need to buy a drill/driver for DIy at home, I am medium skilled handy. Do the batteries in the battery operated ones die if not used/recharged regularly. What are the medium to good avilable.
The battery tools are the way to go, the batteries last a couple years or more. I have a couple that are almost 5 years old. For the home and light construction I would go with the Ryobi 18 volt. The price is very good and they are very dependible. Think about a set (drill, circular saw, reciprocating saw, and flash light) they will all come in handy around the home and sets are cheeper. You can find them at Home Depot
Jan 19, 2011 | Dewalt Home Fencing
Low battery alarm with rechargeable batteries
How about the battery contacts in the camera? Try cleaning them with a cotton swab lightly dampened with rubbing alcohol.
Feb 28, 2010 | Nikon COOLPIX Cameras
I have an Olympus C-765 for 5 years. Lately, the battery does not charge and in fact I cannot use the camera. How to know if the problem is with the battery or with the charger
1. Do not use ordinary batteries. Use rechargeable NiMH.
2. Measure battery voltage using tester or volt meter. 1.2 v for rechargeables.
3. Try measuring charger output.
Oct 31, 2009 | Olympus Camedia C-765 Digital Camera
Toymax robot RAD 4.0 battery missing - where to find replacement and operating instructions
Not sure this is still relevant to you after nearly 4 years, but The Old Robots Web Site (http://www.theoldrobots.com/download.html) has freely-downloadable PDF manuals for all(?) 4 RAD robots (and many others).
I can't help with sourcing a battery, though. However, as it's a 6-volt Ni-Cd Rechargeable, it should be relatively simple to put your own together, using 5 (Ni-Cd's are 1.2 volts, 6 volts divided by 1.2 is 5 batteries) of an appropriate size (AA's, from the looks of things), providing there's no circuitry WITHIN the original packs. You'd also have to get hold of the correct connector, of course.
Oct 14, 2009 | Toymax Toys
Yuasa np7-12 batterty has discharged after 7 yrs. Can I recharge using a std 12 v trickle charger?
Your Yuasa battery is of the sealed lead/acid type. These batteries are meant to be trickle charged at a voltage between 13.2 volts dc to 13.8. If the battery is dead it could take up to one day to completely recharge it. However, you mention it is 7 years old. The life of these batteries is generally 4-5 years. Their rated capacity (7 amp hour when new) diminishes over time. So there is a good possibility that your battery is getting too old to keep a charge and needs to be replaced.
Aug 28, 2009 | Home Security
Health & Beauty Logo
407 people viewed this question
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
