Question about Dishwashers
People periodically get shocks from the metal sink , dishwasher?
People periodically get shocks from the metal sink. THe only electrical item in the vicinity is the dishwasher. This has been installed for about 9 months without this problem. I unplugged the diswasher and this problem seems to have gone away..how do I troubleshoot this problem?
  • 3,361 Answers
Make sure the ground wire on the dishwasher has a really good connection.
Also the ground wire in the plug in receptacle.
Posted on Feb 04, 2010
I get a small electric shock each time i put my hand on the heart rate monitor on the left of the treadmill. Also happens when i h the inclune buttons on the left. Any suggestions?
Hi Pjd
Shocking problem!
Suspect that the treadmill is generating static electricity.
It is building up as you run... via the rubber mat.
Like the comb through the hair picking up tissue paper bits.
This is basically a Van De Graaff Generator.
Try attaching a wire from the machine chassis (metal) to a metal tap at your sink.
Do you still get a shock?
Not sure where you are and what your electric supply is.
I'm in Australia and our AC plugs have a third pin which is connected to our meter box which is then connected to an outside GROUND ROD.
Perhaps the AC power you are using has no ground or only a 2 pin connection. I which case I would add a three wire plug to the treadmill and the ground pin would connect to the treadmill's metal chassis by a screw or bolt.
Anti static spray may also help
Cheers
Van de Graaff generator
https://www.target.com.au/p/anti-static-spray/50563715
anti static wrist strap
Mar 01, 2016 | Exercise & Fitness
Connectingit hooking it up
The exact list of parts for a dishwasher hook-up would depend on the existing plumbing and electrical . There are three hook-ups needed; a hot water feed, typically from under the sink. A Tee is installed on the hot water line with a valve, and the hot water line to the dishwasher is connected to the valve. A drain line from the dishwasher is installed under the sink. It connects to the sink drain. The Electrical connection can be made using the appropriate electrical cord.
There are specific guidelines and considerations on how to connect the drain line under the sink, and what is required for the electrical hook-up. If you do a search on "how to install a dishwasher" you will be able to find extensive information.
2q== 9k=
Apr 10, 2014 | Dishwashers
Frigidaire fghd2433kf dishwasher. less than a year old. flashed PF. the power hasnt been off. now whole unit is dead. no lights or movement.
Hello bidness_67 please check inside of the sink cabinet look for a switch on the back wall. If there is one flip it. Many new building electrical codes require a switchto turn off power to the dishwasher. Sometimes when putting items in the cabinet the switch is hit unknowingly. If there is no switch check outlets (the GFCI ones)and press the reset then check the dishwasher.if not those two items check breaker box for a tripped breaker.
Aug 15, 2011 | Frigidaire FGHD2433KF Builtin Dishwasher
My badger 5 plus 5/8 HP HD insinkerator is leaking from the bottom of the unit. It is dripping from the reset button and one other metal tab location. It is at least 10 years old. Can it be repared?
Sorry to read about your problem, I hope this helps you out.
sorry no it is rusted out, even if you could take apart, after 10 years 1/2 the parts will be rusted..
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.
Thanks and good luck. you are looking around $90.00 for a new unit
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 05, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Any thing stainless which gets washed in my dishwasher comes out with rusty spots
Check the items are dishwasher proof, not just the items that are becoming tarnished but other items, main culprits ar cheese graters and garlic presses as these are not suitable for the d/w and will cause deposits on the other items.
There are 4 main reasons
1.Stainless items are left in a damp d/w with salt or acidic food residue.
2.Items are peft for long periods of time in a damp d/w after cycle has finished
3. undissolved powder (particularly if using quick wash) has come into contact with the cutlery.
4. different types of metal have come into contact with each other.
Hope this helps.
Jul 06, 2010 | Dishwashers
How can I change the fan inside my computer? It's making too much noises
  1. Shut down the computer through the Start menu.
  2. Ensure that your computer and attached devices are turned off. If your computer and attached devices did not automatically turn off when you shut down your computer, turn them off now.
notice.gif NOTICE: To disconnect a network cable, first unplug the cable from your computer and then unplug it from the network wall jack.
  1. Disconnect any telephone or telecommunication lines from the computer.
  2. Disconnect your computer and all attached devices from their electrical outlets, and then press the power button to ground the system board.
caution.gif CAUTION: To guard against electrical shock, always unplug your computer from the electrical outlet before opening the cover. notice.gif NOTICE: Ensure that sufficient space exists to support the open cover—at least 30 cm (1 ft) of desk top space.
  1. Lay the computer on its side so that the arrow on the bottom of the computer points up.
  2. Open the cover:
    1. Facing the back of the computer, press the release button on the right side of the computer with one hand while pulling up on the top of the cover with the other hand.
    1. Press the release button on the left side of the computer with one hand while pulling up on the top of the cover with the other hand.
    2. Hold the bottom of the computer with one hand, and then pull open the cover with the other hand.
caution.gif CAUTION: To guard against electrical shock, always unplug your computer from the electrical outlet before you open the cover.
  1. Open the computer cover.
notice.gif NOTICE: Before touching anything inside your computer, ground yourself by touching an unpainted metal surface, such as the metal at the back of the computer. While you work, periodically touch an unpainted metal surface to dissipate any static electricity that could harm internal components.
  1. Disconnect the cooling fan power cable from the FAN2 connector on the system board.
  2. Disconnect the power cable from the PWR connector on the system board.
  3. Lift up the airflow shroud.
caution.gif CAUTION: The heat sink can get very hot during normal operation. Be sure that the heat sink has had sufficient time to cool before you touch it.
  1. Remove the heat sink:
    1. Release the retention module clip by pressing in on the tab and lifting the retention module clip up.
    1. Pull the release lever out until the heat sink is released.
    2. Lift the heat sink away from the microprocessor.
notice.gif NOTICE: Lay the heat sink down with the thermal grease facing upward.
May 12, 2010 | Dell Dimension 8300 PC Desktop
Siemens SE64A630 GB I got a tingle up my arm when holding the dishwasher and touching my sink. I checked and when the dishwasher is plugged in, there is 24VAC between the dishwasher door and the stainless...
I would say it is an earthing problem, check over your earth wires, normally black and grey is neutral, check to make sure your earth wires are connected properly, and tight, better to completely turn appliance off by disconecting power plug while doing this, take care not to play around with the wires too much to prevent a nasty electric shock
Jul 01, 2009 | Siemens 24 in. SE64A630GB Built-In...
Electic shocks
earth bond your sink and get some one to look at dish washer possible loose connection on your macine
May 17, 2009 | Dishwashers
The part by the sink causes water to flow all over the counter
Almost all dishwashers connect to the sink drain in one way or another. Many connect (via an Air Gap valve) to a garbage disposal.
If the "metal part" is at the rear of the sink, that is the top of the air gap. When water comes out of it, that means the drain is plugged.
If there is a garbage disposal, does water drain through it? Does the disposal work?
If there is no disposal, does water from the faucet run through the drain of each sink with no problem?
Thanks for answering these questions in a reply.
Apr 10, 2009 | GE Dishwashers
Water won't drain completly
Start by cleaning the drain hose. this is a common issue when food builds up in the drain hose. most of the time it is what is called the air gap. the little metal looking thing on your sink. take the cap off and then there is another small cap underneath usually white that you would push 2 tabs in to get it out and you would see any debris inside.
Nov 08, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwashers Logo
122 people viewed this question
Top Dishwashers Experts
