Question about Kenmore 52342 / 52344 / 52349 Side by Side Refrigerator
Kenmore Sideby side refrig 106.53242300 freezer
Kenmore Sideby side refrig 106.53242300 freezer motor comes on every 3 minutes, runs for 20 seconds. doesn't seem to be as cold. what can I do?
    President:
  • 1,891 Answers
Sounds like a bad blower motor . replace it . the brg must be bad . mm
Posted on Feb 04, 2010
Kenmore model 795.78544.804 refrigerator and freezer not getting cold enough
If there is a capacitor running the compressor, replace it. if that does not solve the problem, suspect the compressor failing.
Apr 19, 2014 | Refrigerators
Kenmore side by side 253.52349302 making stalling noise
motors start capacitor relay may be going bad..
Jan 20, 2014 | Kenmore Refrigerators
Food is freezing on left side of refrig and not so cold on right
Check the back wall of the freezer section for any ice buildup. This would be from a failure to defrost and requires parts.
Check the freezer side for the evaporator fan motor. Is the fan motor running?
If not a fan motor is needed.
If there is ice on the back wall of the freezer you can activate the defrost control by turning the cold control thermostat OFF then back ON "3" times.
Once you activate the control listen closely in the freezer side for a sizzling sound. This would indicate the defrost thermostat and defrost heater are good and the defrost timer needs replacing. If there is no sizzling sound after 20 minutes,the defrost thermostat and possibly the defrost heater need replacing.
Nov 09, 2009 | Maytag MSD2756G Side by Side Refrigerator
Freezer and refrig not cooling
it might be a cooling gas problem
you first check it by caling l service men
also please give me ratings on this........
Aug 25, 2009 | Whirlpool ED2FHEXN Side by Side...
Freezer quit freezing
HI,
you can try this suggestion first.
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
any further question let me know.
thanks,
Mar 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Problem with kenmore side by side leaking
2 things could be wrong first is you compressor running if is not running you have to check the overload to see if it tripp if it did it will sound like a babys rattle just repl and compressor should kick back on if is running then is you evaporator motor running if is not then check for volatge at the wires if you get 118 then repl your motor. is the unit defrosting is there a lot of ice on the back cover it might not be so 3 thing might be failing 1 timer 2 defrost thermostat 3 heater coil call a tech to have those check out thanks
Oct 09, 2008 | Kenmore 50522 / 50524 Side by Side...
Kenmore sideby side fridge
You have a defrost system problem. Defrost is controlled by a timer which energizes the heater circuit. The heater circuit has a radiant or cal rod type heater which melts the frost from the coil. When the coil reaches a temperature where all ice would be gone a termination switch opens and shuts of the heater. The timer will continue to run until defrost time expires (18-22 minutes).
If you can locate the timer there is a clutch head screw to advance the timer to the defrost position. Turn the screw clockwise SLOWLY until you hear one audible click. The heaters should come on and defrost take place. If the unit restarts after the 18-22 minute period the timer is good, if it does not restart advance the screw to a second audible click and it will restart.
If you had to turn the timer the to second click to get it started cooling replace the timer.
If the unit restarted after the 18-22 minutes and defrost did not happen your problem is in the heater circuit. This would be an open heater or bad defrost terminator switch. To access the heater and defrost terminator the back panel in the freezer section must be removed. With an Ohm meter you can check the heater to see if it is good.
Jul 01, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Elite refrigerator stops cooling - Relay keeps cycling
the relay on the compressor is most likely the culprit part# 8201786 you can buy it at the local sears parts and repair center it is very easy to replace it. your refrig compartment will start warming up soon. to prevent damage to your compressor probably a good idea to unplug the refrig until you get the part replaced..
Dec 17, 2007 | Refrigerators
Kenmore 52342 / 52344 / 52349 Side by Side Refrigerator Logo
100 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
