Question about Kohler 12 kW Emergency Power System - 12RES-L
Kohler Confident 7 model 7CCKM22 generator
My Kohler Confident 7 model 7CCKM22 generator installed in our RV,only runs with the start button is held in, as soon as it is released, it stops. It is air cooled & LPG fueled. I can only get 60volts output while holding it in & not 110. I am a retired auto-electrician with very little electronic knowledge. I have given it all the tests I can think of & it has me bluffed. Can you help me please.
Cheers Paul.
    Master:
  • 342 Answers
Sounds like a relay should be latching one it has started
Posted on Apr 04, 2010
Testimonial: "Thanks. Will take your advise to my electronic wiz-kid friend who has the generator regulator, & is going to run tests. Will let you know the outcome."
I have a Kohler Confidant 5, model 5ckm21 generator in my RV, serial # 326827, spec# 101228. It worked fine one evening and the next day it wouldnt stay started unless the start button stays depresse
no 14vac coming from generator to control board.--cause can be regulator board on end of generator---dirty brushes or worn out brushes==b1 and b2 winding open that outputs the 14vac--my problem was blown regulator board
Dec 05, 2012 | Kohler Electrical Supplies
Kohler 10 runs only while holding start
Oil pressure, or no AC output from the stator, check stator and rotor for resisitances and shorts.
Nov 18, 2012 | Kohler Electrical Supplies
RV generator Model 4CKM-RV (60 Hz) will not start
if same fuel as RV make sure over 1/4 tank or wont run
Jun 10, 2012 | Kohler Electrical Supplies
Kohler Confidant 4 puts out to much voltage
Are you running the gen and plugging in the RV at the same time? I assume it is wired right and you have a transfer switch? Are you saying the voltage is fine when the RV isn't plugged in?
Apr 15, 2012 | Kohler Electrical Supplies
Kohler confidant 4 generator will not run.
i got the same gen and with the same problem
mike
Sep 24, 2009 | Kohler Electrical Supplies
Kohler confidant 4 generator service manual and wiring diagram
First thing is to check oil level as low oil pressure will shut it down.
Aug 11, 2009 | Electrical Supplies
I have a kohler rv generator that will start .
When this happens, this usually means that your genset is not creating voltage. First thing I would do is disconnect your remote start wire from the genset, this will eliminate the start switch inside the RV. For a shorted remote start switch can cause you genset to shutdown. Second, place a volt meter at a spot where you will be able to read genset voltage. If no voltage is available and your voltage regulator is new, then the problem is with either the rotor or stator. The rotor is the easiest check. You need to reach the brushes. Take a resistance reading, which should be around 20 ohms. Clean the rings and make sure there is enough length on the brushes, at least over 1/2". Next, flash the fields using a 12Vdc battery. Use rubber gloves when doing this. Place the positive side to the ring closest to the bearing and negative goes to the back ring. This is done while genset is running so be careful with rotating parts. Have a volt meter on the output wires. Once you flash the fields the voltage should increase to over 50Vac. If it does then your stator is bad since you installed a new voltage regulator. If the voltage does not increase when flashing, then the rotor is bad.
Apr 10, 2009 | Electrical Supplies
Kohler 12 kW Emergency Power System - 12RES-L Logo
1,180 people viewed this question
Top Kohler Electrical Supplies Experts
John Trevino
Wayne McNeil
Craig Butler
Craig Butler
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
