Question about Kyocera FS-4000DN Laser Printer
Kyocera fs 4000 how to replace drum, transfer roller and pickup roller
  • 200 Answers
(1) Detaching and refitting the drum unit
Procedure
1. Remove the developer unit (See page P.1-5-
9).
2. Open the left side cover and then remove
the waste toner box.
3. Unlock the drum unit lock and then remove
the drum unit.
4. Check or replace the drum unit and refit all
the removed parts
(1) Detaching and refitting the transfer roller and separation charger brush unit
Procedure
9).
2. Remove the drum unit (See page P.1-5-10).
3. Slide the paper chute guide and unhook the
hooks.
4. Remove the paper chute guide.
5. Remove the shaft (transfer roller) from the
both bushes.
6. Release the four latches and then remove
the separation charger brush unit.
7. Check or replace the transfer roller and separation
charger brush unit and refit all the
removed parts.
CAUTION: Note the following, when refitting
A. The separation charger brush unit is
inserted into the two projections of the frame
and does not run on to the projections.
B. The separation charger brush unit is
firmly in contact with the separation charger
plate of the frame.
(1) Detaching and refitting the paper feed assembly (paper feed roller and pickup roller)
Procedure
1. Remove the paper cassette.
2. While pushing the lock and then slide the
paper feed roller pin.
3. While pressing the lever and then remove
the paper feed roller assembly.
4. Check or replace the paper feed assembly
and refit all the removed parts.
(2) Detaching and refitting the ****** roller
Procedure
2. Push the bottom plate down until it locks
(30/31 ppm printer [EUR/USA model] only).
3. Unlatch the two latches and then remove
the ****** guide.
4. Remove the ****** holder (roller) from the
****** guide.
5. Check or replace the ****** roller and refit all
the removed parts.
Posted on Feb 19, 2010
How do I detach the transfer roller bushes of a kyocera fs-2020d?
if you remove the pcr assy from the drum unit you will need to put the assy on the table. With a small slotted screwdriver you will have to wedge between the black roller bushes and the gray support on the pinion side.
Best regards,
Marius
Oct 05, 2016 | Kyocera FS-2020D ECOSYS Monochrome Laser -...
Kyocera FS-3920DN call service 2000:0011742
The call service 2000 is about the main motor. Pull the Developer Unit and then the drum unit out of the printer and check if the gears on both units are moving freely. Then turn the printer on without the 2 units and see if the motor is functioning. If your the motor moving then the message displays on printer will be 7410 (because you have the drum unit outside). There is a possibility that the transfer roller is damaged.
Mar 26, 2014 | Kyocera Fs-3920dn Laser Printer
I have a Kyocera Ecosys FS-1118MFP. When I try to make a copy the page comes out totally black. I have tried to change the toner, but its still the same. Tried adjusting the exposure aswell but invain. Any...
This is an uncommon issue and could be one of several things
  • The formatter could be sending garbage print data to the ECU (rare)
  • The ECU is bad, this controls the laser
  • The high voltage power supply could be bad
  • The the primary charge roller is bad.
Typical laser jet process.
  1. Primary charge roller is charged to -600V and transfers this to the photosensitive drum in the toner cartridge.
  2. Th laser removes the negative charge and places a +600V charge where the image/text will go
  3. Toner is attracted to the positive charged areas on the photosensitive drum (toner is negatively charged)
  4. Transfer roller has a + charge sits under the paper, this roller attracts the toner from the photo roller to the paper
  5. The fuser melts the toner onto the paper
So if the laser is going crazy and removes all the negative charge or no negativ charge is being applied to the photosensitve drum then toner will stick everywhere to it and you get a black page.
How this helps.
Jul 13, 2012 | Kyocera FS-1118MFP Laser Printer
My Kyocera FS-2000D always says there is a paper jam when I send a document to print. There aren't any papers that are jam and usually I just open and close the top cover to clear it. Is there any fix...
The problem should be with the transfer roller.
Open top cover and remove developer unit by pulling (it's under toner).
Open left side cover. Reomve the waste toner box by pulling a lever in its neck. There wil be a gray buttom on the drum unit. If you push it, you can pull out the drum unit. Better safe then sorry, avoid direct light, and any other dabage-hazard. The Drum is really very sesible indeed. Place it somewhere in safe and secure.
I you now opet top cover, and take your hand into the hole, you can realize, if the transfer roller isn't moving.
Try to rotate it by cw and ccw. Don't pollute this area! The only one thing you can do to wipe the transferroller softly.
Then put bak the drum, the waste t. box. The gray bottom in the drum unit have to stand vertically. Push it ttill it "click".
Then put back the developer unit with the toner.
Try to squeeze the side covers softly by bare hands. Furthermore do the same with top cover. Close rear unit if nessesary.
Try to cleaan the pickup rollers in the begining of the paper tray.
Try to replace the papers.
I hope my answer will help you.
I used to have the same problem.
Fell free to ask!
Aug 11, 2011 | Kyocera FS-2000D Laser Printer
I have a Kyocera fs 1920 printer how do I replace the drum with a new one
1. Remove the paper cassette and the paper transfer unit. (Draw the paper transfer unit while pressing the buttons in)
2. Remove the developer unit.
CAUTIONS When if installing or removing the developer, do not let the magnet roller touch any part in the printer.
A. Open the top cover.
C. Remove the toner container.
D. Disconnect the developer connector.
E. Remove the developer from the printer while sliding the developer lock lever frontwards.
F. Gently flip down the magnet roller protective cover.
NOTE After removing the developer, seal it in the protective bag and place it on a flat surface. Do not place the developer in a dusty area.
3. Remove the waste toner bottle.
4. Remove the drum unit while pressing the drum lock.
I hope this is helpful,
Shawn
Dec 31, 2010 | Kyocera Mita FS-1920 Laser Printer
Black dots printing on left side of paper
dots are usually always caused by the drum..drums are very easy to replace..(you don't even need a screwdriver)
here's how..
remove the unit that the toner sits into..it's called a process unit..comes out as a whole with the toners...
next open left cover..
remove waste toner bottle. (drum sits right above it!!!
next remove drum by pushing on grey button and pulling drum
out the left side of the printer.
as far as the jam message you might need to replace tray feed tires located up under the machine
Jan 11, 2010 | Kyocera FS-3900DN Laser Printer
Kyocera FS-1920 error message: "call service 6400:0295998"
Your drum unit is not seated correctly. Look inside for a bent drum ground clip.
Oct 19, 2008 | Kyocera Mita FS-1920 Laser Printer
Kyocera FS-1920 won't pick up paper from tray
replace pick up rollers and paper tray roller. Take out paper tray and toner, lift printer so you can see underneath you should see a set of rollers its nopt to hard to get out. also in the paper tray there is a roller swop that out to
Dec 14, 2006 | Kyocera Mita FS-1920 Laser Printer
Kyocera FS-4000DN Laser Printer Logo
1,152 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
