Question about 4D 3G-Green Scroll Trackball Finger Mouse - Black
The trackball is not as good as it was, but it is ok wgen I move it the right hand side of the screen, but to the left it is awful. I have to roll it many times to get it to the left part of the screen. What can I do?
  • 16 Answers
Try cleaning it ,, there might be dust stuck near the rollers
Posted on Feb 04, 2010
Trackball 8800 Blackberry
Your trackball needs to be cleaned. You have two options.
1) You can send it in to be repaired, or
2) You can clean the trackball yourself.
To clean the trackball yourself:
The silver ring which covers the trackball can easily be removed if you use a small screwdriver to lift it at the outer side of the ring. Be careful here! (Like you should be during the whole process as all parts have very small plastic nipple which can break very easy.)
When the silver plastic ring is removed you will see the inner trackball component which can be removed completely. Before doing this you should carefully remove the silver metal ring that holds the trackball component in its position.
The trackball component itself can also be carved. For every direction the ball can roll to you’ll find a sensor wheel. Those wheels are mostly carrying some gunk you should clean them from.
Once this is done put everything back together to the place each pieces came from and secure the trackball with the silver plastic ring that you removed in the first step.
Your BlackBerry’s trackball should be back working now.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 02, 2010 | AT&T Blackberry Curve 8300 Smartphone
Track ball requires multiple press to get it to do anything
Hi, to change the trackball or trackpad sensitivity of the BlackBerry smartphone, complete the following steps:
1) On the Home screen, go to Options > Screen/Keyboard.
2) In the Trackball or Trackpad section, click Horizontal Sensitivity or Vertical Sensitivity to change the sensitivity level.
3) Press the Menu key and select Save. The new sensitivity levels are saved.
A higher sensitivity number indicates a higher sensitivity level for the trackball or trackpad.
The trackball user interface found on certain BlackBerry smartphones is similar to the trackball used in a mouse in conjunction with a desktop computer.
In the event debris comes in contact with the trackball and affects the usability of the BlackBerry smartphone, rapidly roll the trackball up, down, left, or right to potentially correct the problem.
If rapidly rolling the trackball does not correct the problem, please contact your wireless service provider for support options.
Try to re-install the BlackBerry Device Software using the application loader tool, before you re-install the software please back up the BlackBerry smartphone data.I hope this information will be helpful to you
Nov 19, 2009 | AT&T Blackberry Curve 8300 Smartphone
Rollerball will not roll upwards??
Nov 18, 2009 | RIM BlackBerry Pearl 8100
Ball on blackberry wont navigate up or down
Hi. BlackBerry smartphone trackball fails to roll in a particular direction because, debris is lodged in the trackball.
The trackball user interface found on certain BlackBerry smartphones is similar to the trackball used in a mouse in a desktop computer.
Using for certain period debris comes in contact with the trackball and affects the usability of the BlackBerry smartphone, rapidly roll the trackball up, down, left, or right to potentially correct the problem.
I hope this information will be helpfull.
Nov 11, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
The ball won't scroll down
Have you removed the ball at any time? If it is put back in wrong, it could cause this. If not, the ball assembly itself might be bad. You can find them fairly cheap on eBay.
May 30, 2009 | RIM BlackBerry 8800
Trackball want scroll down
Please change the sensitivity, to change the sensitivity follow the below steps
  1. select option in the main menu
  2. select Screen Keyboard
  3. set the horizontal/vertical sensitivity as 100%
May 16, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
The tracking ball rotates but it does not move over the icons on the left side. Is there anything I can do to fix this?
Depending on how comfortable you are with removing the trackball it's not hard to fix... you may have some dirt or grit interfering with the trackball and/or sensors. Take a small screwdriver or blade and gently pop the silver ring around the trackball off. This will free the actual trackball housing. Use an old toothbrush to clean everything. I also soaked the trackball in a little rubbing alcohol. Just make sure it is completely dry before reassembling. If that doesn't work you can purchase replacement trackballs from places like crackberry.com.
Apr 18, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Pop the ring around the track ball out with a small blade or your finger nail. Three double prongs hold it in place (bottom and both sides, none on top). Turn device over and gently tap the back. Track ball will release once ring is removed. At this point you can view the track ball and see exactely what is causing the block. Clean if needed with q-tip or remove lint/debris/etc... Just did this with my 8830. Working perfectly now. - {would not scroll down at all prior to}
Nov 25, 2008 | RIM BlackBerry 8800
Model 64213 (not a wireless model) Trackball is not working smoothly - already tried cleaning it and still gets "stuck" especially moving left and right. Up and down works well.
This is because the wheels that move with he trackball are getting stuck.
Try cleaning the inside housing.(The part that holds that trackball) Mainly, the tiny wheels that grab the trackball. Normal use can build up a gummy buildup inside that can be easily rubbed off with a cloth. Since the housing is underneath the trackball, there can be a greater potential for lint, crumbs or anything else to get inside as well. Clen in there, empty out any debree and you will find ti moves much smoother.
alternatively, one of the tiny wheels could be damaged and is not rolling properly. Roll each one with your finger to see if you can feal anything rough or if the wheel is rubbing against something.
Jul 28, 2008 | Computers & Internet
Track Ball
Your track ball may simply be dirty. Get a q-tip wet with rubbing alcohol and rub your track ball and repeat until the q-tip stays clean. Hope this helps!
Jul 02, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Computers & Internet Logo
54 people viewed this question
Top 4D Computers & Internet Experts
sonofspy
Level 1 Expert
ray gallant
Niki Kidman
Niki Kidman
Are you a 4D Computer and Internet Expert? Answer questions, earn points and help others
