Question about Creative Labs Zen MicroPhoto MP3 Player
Reg edit & Msconfig
I am not able to open regedit and msconfig menu in my pc
    President:
  • 4,402 Answers
Do you get an error?
Posted on Feb 20, 2008
Vista only runs in safe mode
1. Press the Start button.
2.
Type msconfig in Start menu or click 'run' and type msconfig.
3.
Open the program. (Click msconfig icon if it doesn't open automatically)
4.
Also, open the command box. Click Start > run > and type cmd.exe and open. (If the above method does not work, using "msconfig", your "System Configuration Utility" program should open on your screen.
5. Click on the "General" tab on the utility program. Select the "Normal Startup" option. Click "Apply" and "Ok" to confirm the change back to normal mode.
6.
Follow the on-screen prompts to restart the computer. Your computer should reboot normally.
7. IF
this doesn't work: Click on the "Boot" tab in " msconfig" > the "Safe boot" option should be unchecked.
IF that doesn't work, go to "msconfig" again and click the Startup tab. Disable all startup programs or, if you know which one is causing the problem, just a single program.
Hope this helps! Godspeed
Feb 06, 2014 | E-Machines Computers & Internet
Schedule record application starts automatically in background when system restats
Try this:
Disabling Startup Programs in Windows For some programs, it's smart to have them start with Windows, such as anti-virus and firewall software. However, for most programs, starting them at boot-up just wastes resources and extends startup time. There is a tool installed with Windows, called MSConfig, that allows you to quickly and easily see what's running at startup and disable the programs you prefer to run on our own after startup as needed. This tool is available and can be used to disable startup programs in Windows 7, Vista, and XP.
NOTE: MSConfig can be used to configure several things other than just startup programs, so be careful what you do with it. If you're not sure about using it, just follow the steps in this article and you should be fine.
To run MSConfig, open the Start menu and type "msconfig.exe" (without the quotes) in the Search box. As you type, results display. When you see "msconfig.exe," click on it or press Enter, if it is highlighted.
NOTE: If you are using Windows XP, open the Run dialog box from the Start menu, type "msconfig.exe" in the Open edit box, and click OK.
Click the Startup tab on the System Configuration main window. A list of all the startup programs displays with a check box next to each one. To prevent a program from starting up with Windows, select the check box next to the desired program so there is NO check mark in the box. Click OK once you have made your choices.
A dialog box displays telling you that you may need to restart your computer for the changes to take affect. Click Restart to restart your computer immediately. If are not ready to restart your computer, click Exit without restart.
Aug 26, 2012 | IBM Lenovo ThinkPad L412 Notebook
Why does my pc only start on safe mode
While in safe-mode, open the Start Menu and click "Run"
Type "MSCONFIG" in the dialog box and hit Enter.
Under the boot tab, uncheck the "boot in safe mode" check-box.
Restart your PC.
Oct 16, 2011 | Microsoft Windows Vista Home Premium...
In normal mode PC hangs due to spies or viruses. Unable to start the system in safe mode or safe ode in networking mode always it restarts if tried with safe mode. www.kaspersky.com, www.grisoft.com,...
When you are restarting the PC - Press F8 Key till you get the options to Boot
Choose Last Known Good Configuration and load windows
Once you have logged into your PC - try to MSCONFIG
If that does not work, Open Task Manager ( CTRL + ALT + DEL ) key and Click on Services Tab. Click the Services Button below. and it should let you open SERVICES.MSC
Disable all the Antivirus software installed ( double click on the software name and under Startup type - choose Disable )
Also Disable the Windows Installer
Try to access or Download some Virus program to Run or Clean.
Jun 24, 2010 | HP Pavilion a1610n PC Desktop
I want to get rit of babylon but a part of it stays on my computer and say cannot delete and all the time when I start my computer I have a sign error.
If you are comfortable making registry changes ****DO SO AT YOUR OWN RISK, INCORRECT REGISTRY EDITING CAN LEAD TO SYSTEM INSTABILITY OR INABILITY TO BOOT**** then i would suggest opening the registry editor (start>run>regedit) and removing any keys under HKEY_LOCAL_MACHINE\Software which reference Babylon. Also, make sure (since this is happening at startup) that you have run MSconfig (start>run>msconfig) and deselected any references to Babylon there. Also, check your system variables (right click computer>properties>advanced>environment variables) and be sure that there is not a PATH that points to Babylon left over.
**As with any registry editing make sure you perform a complete registry backup, or at the very least manually set a system restore point before you atempt any of this.**
Let me know how it works out, or if you need further assistance.
Feb 06, 2010 | Computers & Internet
Fyxegtbu.dll
You can remove this command from the startup menu
Click on RUN and enter msconfig and then click ok. When the config box comes up, click the startup tab, and look for the line that has fyxegtbu.dll in it, and uncheck that box. Reboot and it should be gone
Oct 23, 2009 | Microsoft Windows Vista Ultimate Edition
When I turn the comp on, it shuts off by itself after 20 or so seconds.
Log into windows through Safe Mode. Open run and launch msconfig. In the General tab choose Selective Startup and uncheck Load Startup Items. Now reboot your PC and check if it still reboots. Let me know if it works or not.
Sep 30, 2009 | Acer Aspire One AOA150-1570 Notebook PC
I have the BSOD problem - msconfig admin privileges
msconfig is just a nice GUI to the keys in registry, what you may have is a driver or disk problem.
run chkdsk C: /F (or /P if in repair console)
instead of running msconfig, run services.msc and disable everything that doesn't belong to microsoft.
with another computer, download Autoruns.zip
copy it to the troubled machine and run it via the command line.
It's a very nice utility, msconfig on steroids :)
Sep 15, 2009 | Dell XPS M1530 Laptop
Dell inspiron 1525 w/ Vista 32 will not hibernate
Hibernate issues are generally an issue with the Video driver. Try the following: Update to the latest list of drivers from support.dell.com BIOS Video Driver see if the issue is resolved. If not, then try editing the startup group of MSCONFIG and see if an item running at startup is causing the issue. (Start, RUN, MSCONFIG, OK to open MSCONFIG)
Jun 09, 2009 | Dell Inspiron 1525 Laptop
Creative Labs Zen MicroPhoto MP3 Player Logo
23 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
