Question about NEC ETW 16DC-1 Corded Phone
Etw-16dc-1 incoming calls not ringing - NEC ETW 16DC-1 Corded Phone
  • 2,069 Answers
Perform a "reset all" operation. Regards
Posted on Feb 04, 2010
I have 1 phone line that is shared with my all-in-one fax, therefore, we are using the phone/fax in DRPD mode but I am unable to receive incoming faxes. The fax machine is a Samsung SCX-4521F.
I would get a line sharing device. That device will be able to establish wether the inbound call is a fax or voice call, and route it accordingly.
Jun 09, 2009 | NEC Electra Professional ETW-16DC-2
Programming
yes enter program mode and change MB 4-01 for your port number. Assignment of ringing per phone.
Jun 02, 2009 | NEC ETW 16DC-1 Corded Phone
I have a NEC ETW 16DC-2 phone that does not ring with calls
The telephone instrument you have can be used on the NEC Electra Professional Level I, and the Level II systems (and under some conditions the NEAX 2000 series). Codes for features are somewhat different based on the system. It is possible that your phone is in "Do-Not-Disturb" if other phones on your system actually ring when they are called via the intercom (on the Level I and Level II systems, initial intercom ring is a system wide setting). The cancel DND code is: Level I system: with telephone idle, press <FNC>, dial 60, press <FNC>. Level II system: with telephone idle, press <FNC>, dial 69, press <FNC>.
It is also possible that your ring volume is very low. To adjust, press <SPKR>, dial 601, then adjust volume using the up/down keys at the bottom of the phone (press <SPKR> when finished. If your system is programmed to access an outside line when you press <SPKR>, you will need to press the <INTERCOM> button first.)
If your system is set for voice intercom, people calling your phone can make it ring by dialing a "1" after your intercom number.
If you do all this and your phone still won't ring on incoming calls, let me know and we'll have to go into system programming to correct it.
Jan 06, 2009 | NEC Electra Professional ETW-16DC-2
Can't find caller id function on NEC ETW-16DC-1 BUSINESS PHONES SYSTEM
You have to make sure the phone system you have has CID cards in it. What kind of card is in the Electra phone system.
Sep 08, 2008 | NEC ETW 16DC-1 Corded Phone
How to program a line to ring keysets
Not sure if I understand your question correctly, but I think I just learned how to do that on an electra professional. Memory block 4-1-1 lets you go through each of the internal extensions, and you can set each extension to ring when a call comes in from any/some/all of the outside lines.
to reach memory block 4-1-1, I used a multi line terminal connected to ports 1. Press fnc => hold => # => 0 => * => line key 4. Use the fcn(?) key to cycle through the internal ports, the line key buttons to map each of the 4 lines (presumably line keys 1 through 4 on your system).
As to where to get a manual, I am not sure, I have 3 thick binders... good luck
Apr 08, 2008 | NEC Electra Professional ETW-16DC-2
How to activate mic phone
Feature 1 or function 1 will work
Mar 04, 2008 | NEC Electra Professional ETW-16DC-2
LINE 3 RINGS ON ONE PHONE- AND DOES NOT RING ON THE OTHER 3...
You will have to get into the programming mode and change Memory Block 4-01 for the port of each phone you want to ring. The corresponding light for the button is OFF for no ring, GREEN for ringing, and RED for delayed ringing.
Jan 28, 2008 | NEC Electra Professional ETW-16DC-2
NEC ETW 16DC-1 Corded Phone Logo
37 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
