Question about Garmin GPS
My GPS will turn on and go to the warning screen and freeze. Once I unplug it from my power source it goes off immediately instead of staying on battery power. The battery is fully charged and I have tried turning it off and turning it back on several times
  • dr_norton20 Feb 04, 2010
    Thank you very much for the reply. I figured it was a battery problem but I just got it like two weeks ago so I didn't think it was possible. I'll have to call Garmin tomorrow. Thanks again.
    Top Expert:
  • Garmin Master
  • 80,396 Answers
From what u say the battery is defective, just because it seems charged doesn't mean the battery is any good, the fact the system only turns on when plugged in is a dead give away to a battery problem, it will not boot up with a defective battery. The battery is not owner replaceable, you must send it back to Garmin for service and battery replacement.
Posted on Feb 04, 2010
  • yadayada
    yadayada Feb 04, 2010
    no matter the problem it is under warranty correct? email them 1st
We have A Garmin 1300. It works fine for a while then the screen goes blank. We hold down the on button for a LONG while then the screen will come back up and make you go through several screens, but...
Be sure to update the firmware by running the Garmin WebUpdater.
Download and Install WebUpdater.
It is not necessary to unplug the vehicle power cable as the unit will shut down automatically if the vehicle power source is not supplying power after the vehicle is turned off. If the vehicle power cable does continue to supply power, then a manual shut down can be done with the power switch on the nuvi but it is still not necessary to disconnect the vehicle power cable.
Aug 12, 2011 | Garmin nuvi 1300 Car GPS Receiver
GPS turns on and goes to warning screen and freezes.
You can send your unit in to Magellangps.com or autonav2000.com to recover your MRM 700 unit.
This is a software issue that will require the unit to be reloaded.
Good luck
Apr 03, 2010 | Magellan RoadMate 700 GPS Receiver
When I connect my Garmin Nuvi 200w to my car to charge it does not work. It just receive charge but does not work. If I disconnect it the GPS It work.
Are you using the garmin power cord or are you using an aftermarket cord? Some after market cords have usb plugs that although they plug right in to the power port on the unit, they tell the unit that you are updating the database. The unit displays only a picture of a computer connected to the unit and that's all it will do. Their is a way around this. Simply wait until the unit displays the about photo of the computer attached and then unplug the power cord from the unit. After the screen clears immediately replug in the power chord. This must be done quickly before anything appears on the screen. If you're too slow, simply repeat this step until you manage to replug the unit before anthing appears on the screen. Once plugged in as about the unit will operate normally on the external power source until you either turn it off or unplug it. Simple repeat above when ready to resume use.
Apr 01, 2010 | Garmin nuvi 200W GPS Receiver
When I plug in my vehicle power supply into my nuvi 250 gps, the computer symbol appears on the screen and my map will not return until I unplug the power source and turn on and off the gps unit. How do I...
This may be happening if you are connecting the GPS to the vehicle power source via USB cable, instead of the supplied power cord & cradle. If this is the case, try again not using the USB connection method.
Another source for free, comprehensive help is available directly from Garmin:
Monday - Thursday: 8 AM - 6 PM, Friday 8 AM - 5 PM Central Time (closed holidays)
US: 913-397-8200
US Toll Free: 1-800-800-1020
Canada: 1-866-429-9296
Sep 17, 2009 | Garmin nuvi 250W GPS Receiver
My HL-S4666W's screen picture freeze whenever I turn it on
If the tv has a built in discoder, it is the decoder at faulty, bypass the decoder using a dvd player, and if that plays then it will prove the decoder fault, the dvd signal is stronger than an external source, oh, by the way, unplug any source of dish/arial etc to the decoder, giving the dvd master control of the tv
Jun 07, 2009 | Samsung HL-S4666W Television
Have got Garmin nuvi 710touch screen will perodicly freez and i am unable to turn the unit off or on
In order to recalibrate the nuvi® 7xx's touch screen, follow the instructions below.
  1. Start with the unit powered OFF and unplugged from power supply.
  2. Press and hold your finger anywhere on the touch screen
  3. Next, slide the power switch ON and immediately slide it into the Lock position. There is no need to wait for the screen to flash on or show the Garmin logo before moving the switch into the Lock position.
  4. Leave your finger on the screen for about 45 seconds.
  5. Two intersecting lines should display on the screen along with the message: Press Dot.
Follow the rest of the on screen prompts to complete the screen recalibration. Once it is completed the unit will display Calibration Complete
Oct 13, 2008 | Garmin GPS
GPS Logo
70 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
