Question about Saunacore Standard Residential Sauna Heater Sau Sau Kw10.5std
KW9B model, power to unit but no heat when timer
KW9B model, there's power to the unit but no heat when timer is turned on
Heaters are pretty simple: when timer is on, voltage is applied to the heater elements until timer turns off. To troubleshoot your problem, use a multimeter or circuit tester to check the terminal connections on the heating elements themselves. With the timer ON, you should be able to read voltage (120 or 240, depending on your heater) at those connections. If you don't check the continuity of the wiring from your timer to your heater. Continuity w/out voltage at the element indicates a faulty timer, no continuity means bad wiring. If you do read voltage at the element but it isn't heating, your element is burnt out -- time to replace it. If it's a newly assembled setup or seems odd to be burnt out for some other reason, double check that you're using the correct voltage for that particular heater... 120vac won't run a heater rated at 240vac.
Posted on Oct 27, 2010
How do we turn off timer?
Will need a model number for the unit in order to assist. Once you've found the model, try googling for "<modelnumber> manual".
Aug 30, 2014 | Heating & Cooling
My whirlpool dryer model ler8620pw0 does not shut off in the automatic cycle, but does in the timed cycle. what would cause this?
Dryer will not shut off:
The timer: Located in the control console of the dryer the timer consists of a small motor connected to a series of gears that rotate cams, which turn electric contacts off and on inside the timer. The timer contacts control the dryer motor as well as the heat circuit and the timer motor itself. A defective timer motor or a defect in the timer's electrical contacts can cause the timer motor to fail and the timer will need to be replaced. The contacts can be checked for continuity with a multi-meter. This test should only be made when the dryer is unplugged. Another test u can do is observe by eyesight and see does the timer advance or is it stuck on one cycle?
1. On gas and electric dryers that have an "Auto Dry" cycle, the cycling thermostat is often used to advance the timer as well regulate the drum temperature. Essentially, thermostat will alternately turn on the heat source or the timer motor when the temperature has been satisfied. To check this thermostat, you will have to check for power to the timer motor with a multi-meter, during a cycle. This is a live voltage test and caution should be used.
2. Some dryers will use a cool down thermostat to tumble the clothes without heat, at the end of the dry cycle. Power is routed through this thermostat to the drive motor to keep it running until the drum temperature has dropped to a specific temperature. If this thermostat fails it can cause the drum to turn indefinitely or until the door is opened. You can check the thermostat for continuity with a multi-meter. This test should only be made with the power removed from the dryer.
Lastly check the moister sensor for OHMS according to ur schematic as it must show a certain amount of ohms as per ur unit. When unit has been on short while
Jul 25, 2014 | Whirlpool Dryers
My kenmore 110.66512694 is not drying and is not turning off automatically, i have to turn it off myself or it will run forever.
Their are 2 types of dryers. Electronic dryness sensing style and Autodry style. Yours is Autodry.
Electronic dryers have a dryness board which relies on info from moisture sensing bars that the wet clothes rub against. AutoDry models like yours alternates the power between the heating element and the timer motor. This is what you heating assembly looks like:
Check all the components on the heating assembly for continuity.
I have a service manual and more HERE
Apr 01, 2011 | Kenmore Dryers
I have a Kenmore 70 top load dryer that is not heating. And the timer doesnt turn off anymore either. Both items seem to have malfunction at the same time. Help?
This is typical. If the heating element is no longer working, the unit doesnt know to turn off due to the clothes still being wet. However, the timer has absolutely nothing to do with the heating of the unit. If the timer doesnt turn off the unit even when the time is short (example: 10 minute timed dry), the timer has a different issue. If you have merely set the dryer to dry the clothes (not a "timed cycle" to dry) then the dryer will continue to run as I have stated before. The dryer will run until the clothes are dry. Now, its time to address the heating part. Your dryer heating element has gone bad. It can be replaced if you are somewhat handy. You can pick one up from your local appliance store and it has simple instructions. Please make sure that you disconnect the unit from its power source prior to attempting any repairs. Safety First. You can also call someone to replace it for you and it shouldnt be too costly. Good luck on either option.
Feb 08, 2011 | Kenmore Dryers
Dono heat and timer dont turn
HI. Due to the fact that the timer is not advancing, this will lead me to believe that the timer is the culprit here. The timer is equipped with a motor. this motor, when energized, will advance the timer dial, thus, activating the unit, and progressing the cycle. If the motor is damaged, as in your case, the unit will not heat, or run correctly. Simply replacing the timer control module will correct this problem.
Replace this damaged timer mechanism asap.
Dec 04, 2009 | Estate TEDX640JQ Electric Dryer
No heat model # 96576200 6572 29" electric dryer
For the heat to come on, the following things occur.
1. Power to the unit.
2. Timer or controller sends power to heating element.
3. Over-temp safety is closed and working properly.
4. Heating elements are working.
You will need to know how to use a voltmeter to troubleshoot this problem and since you would be working with high-voltage (220-240Vac), you will need to be confident with your skills. I will tell you what to do, but only do them if you are confident with the meter and electricity.
1. Unplug the unit!
2. Open up the cabinet so you can get to the internal parts.
3. Disconnect, then Ohm the heating element. You should read a resistance across the heating element that is relatively low.
4. Disconnect, then Ohm the safety. It should show zero ohms or near it, indicating that it is closed.
5. Manually operate the timer so that it is in the "on" mode. Verify that you have continuity from the power input to the heating element output on the timer.
Whichever of these does not match is the broken component.
Change your meter to Volts A/C (Vac) and check that there is 220-240 volts across the outlet's two "hot" leads.
If you think you may have a power problem (unlikely) then turn your circuit breaker off then back on. One side may have tripped and you are only getting 120 volts to the unit (again, unlikely, but an easy thing to check).
Otherwise, call a professional service tech.
If this helps you, please select YES to one of the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Dryers
My dryer continues to run unless I turn it off. Also the dryer is spinning but no heat comes out.
HI. The timer is responsible for the heating of the drum during the cycle. current is regulated by the timer. If the unit dose not stop, or has to be shut down manually, this will confirm that the timer is faulty. this will cause a no heat issue as well.
Here are a few more possible problem areas that will cause a no heat issue below.
  1. Hi Limit Thermostat failure
  2. Thermal fuse failure
  3. Centrifugal switch failure
Here are a few steps to help with the testing of your timer. follow carefully.
Take a close look at the timer motor control. Depending on your make and model, there may be a number of wires connected to it. Locate the wires that deliver power to the mechanism. These wires should be slightly larger in size than the other ones. Use your needle-nose pliers to remove one of the power leads. Pull the connector off the terminal by pulling on the connector, NOT the wire, or it may break the wire.
Lift the dryers control panel up and set your units timer to a normal dry cycle. If your multimeter came with alligator clip probe adapters, this will be handy here, so put them on if you have them. If not, any meter(ohm) will do.
Set the multimeter to read ohms (usually labeled R1 or RX1). Clip or touch one probe to the terminal from which you removed the wire. Touch the other probe to one of the other terminals. You should get a reading of zero. If you get a high reading, then the timer motor is bad and it's time to replace it.
Oct 10, 2009 | GE Dryers
My electric furnace/heat pump runs even when the therm is off.
electric furnaces turn on the heat in stages so you dont get a major surge. the fan and the "first stage of heat" are on the same switch. that switch is stuck closed, so that it always has power going thru it. it needs to be replaced
Aug 27, 2009 | Heating & Cooling
My heat pump keeps on switching off and I think it has something to do with the timer but haven't got a instruction book - How do I turn the timer off
what is the brand and model number of your timer?
Do you mean thermostat? Is this a portable unit or a heat pump for the whole house?
Jul 11, 2009 | Heating & Cooling
Dishwasher not starting cycle
a dishwasher has a timer similar to a dryer you need a schematic so you can check the voltages at the heat cycle some times the timer goes out, and rarely the heating element or pump goes out. and make sure when you press start power travels through the button.
Dec 07, 2007 | Dishwashers
Saunacore Standard Residential Sauna Heater Sau Sau Kw10.5std Logo
209 people viewed this question
Top Saunacore Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Saunacore Pool and Spa Expert? Answer questions, earn points and help others
