Question about Panasonic NN-P295SF Microwave Oven
Just went dead after operating a few seconds
No indication of power. 110v good at the plug. pulled the front panel but couldn't see obvious signs of cooked parts. Is there a fuse to replace inside, where is it located? thanks
  • 72 Answers
Could be a cavity thermal located top left side of cavity under the cover
Posted on Feb 04, 2010
Microwave went totally dead while operating; there is power to the outlet.
If the control panel lights up intermittently, then you either have a loose connection somewhere near the panel, or a failing component on the circuit board itself.
Jul 10, 2015 | LG LMV1813ST Microwave Oven
What is Error F7
I am having the same problem. According to the owner's repair guide error Code F7 indicates that power to the magnetron was interrupted. You will want to make the following checks: 1. Unplug microwave oven or disconnect power. 2. After 40 seconds, check to see whether this solves the problem. 3. Unplug microwave oven or disconnect power. 4. Check resistance of the magnetron thermostat. 5. Check the magnetron. 6. Check wiring to the 1100W inverter and control system. See "Checking Inverters." 7. Plug in microwave oven or reconnect power. 8. Check operation of all interlock switches. Check door, hinge and cavity front alignment. Adjust as needed. 9. Unplug microwave oven or disconnect power. 10. If switches operate correctly, replace 1100W inverter. 11. If problem persists, replace electronic control. 12. Plug in microwave oven or reconnect power.
While this is helpful, it is still out of my confort zone as I pulled the control panel and discovered a virtual zoo of connectors. Obviously ponly a trained repairman knows which ones need to be checked. I will probably have to resort to calling one and shelling out the dough.
Jun 21, 2013 | KitchenAid KHHS179LSS Convection /...
Gh9115xe went off completely sometime after a cup of coffee was reheated. Now, nothing works. The outlet is live.
probably not
there is a glass fuse under the outer case near the circuit board
if that is blown it is from a short so you may have to take it in for a diagnosis
Apr 28, 2017 | Whirlpool GH9115XEB / Q 850 Watts...
The microwave starts, then stops after a few seconds, and smells
Remove the cover after pulling the power plug. Check the transformer and large capacitor for signs of overheating. If they look ok, then remove the sheet metal wave-guide from the area where the energy enters the cooking cavity. Under the wave guide is a fan-like device called a stirrer that has a plastic bearing. This stirrer bearing is commonly arced over (when the oven is operated with nothing to heat in it). Usually the bearing looks good, but has arced internally. Replace the stirrer as a unit. The machine can be operated with the case off and a cup of water for a load, but keep you hands clear. Look for smoke.
Sep 07, 2009 | Panasonic NN-H504WF Microwave Oven
Control panel went off and hence it stopped working
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If the cavity thermostat needs to be checked or replaced you'll need to pull the oven from the wall.
You can download Frigidaire / Whirlpool installation instructions here.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Nov 26, 2008 | Frigidaire PLMV169DC Microwave Oven
GE MicroWave JES1136WL01 died while defrosting.
Mine has the same problems. After removing top cover, check fuse on power supply board (mine was OK). Then check thermo fuse located to the far left under the top cover( 2 black wires going to it) using a meter. I then jumped this fuse to see if this was the only problem. I hope to find a replacement thermofuse at the local hardware store.
Nov 17, 2008 | Microwave Ovens
Sharp Microwave Model R-1830: No power
A microwave can be dead for many reasons.
If the fuse is good, it may be an open oven thermal cutout (TCO) on the top of the oven cavity / body or an open thermal fuse on or above the magnetron.
These should read closed (virtually zero) on a continuity check.
If it went dead or when you plugged it in or opened or closed the door, then there's a problem with a door switch or door switch mount.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find exploded views and order parts by entering your model number here at the Sears parts site but the best place to order Sharp parts is Tritronics.
Oct 12, 2008 | Microwave Ovens
Panasonic Dimension 4 microwave model NN-C703BBPQ not working. Display is not illuminated as if fuse has blown. Have changed fuse in plug, but still no visible sign of life. Anything obvious that might...
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
Jul 29, 2008 | Panasonic Microwave Ovens
My R-1870 microwave oven is completely dead. No display no response to keypad entries. No fan, No light below the oven. No light in the oven. Checked the circuit and there is 110v to the plug.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
We have the full service manuals for this series of ovens and have uploaded them to our site here and here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 05, 2008 | Sharp Microwave Ovens
Oven stopped working. No lights, no control panel. nothing
It should be worth fixing. A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open. Then when it cools, it closes the circuit and allows power through again.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can probably find an exploded view by entering your FULL model number (R-1470) here: http://www3.sears.com (the 3 is correct)
You can order Sharp parts from Tritronics at http://www.wehaveparts.com
Please write back with more details if you need further help.
Dec 17, 2007 | Sharp R-1470 Microwave Oven
Panasonic NN-P295SF Microwave Oven Logo
205 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
