Question about Sharp AR-5320 Black and White Copier
How do I clean the drum on a SHARP Z57 11. My copies come out with what looks like a long fingerprint. Thanks, Ron >>
Sharp AR-M 420U How to chenge language and copy coming is very light scanner also clean
You have to in to admin settings for language.
Settings Key > Administrator settings > Enter 5 digit pin > Operation Settings > Display Language Settings.
Check the toner cartridges and Drum Unit. Most people forget about the Drum it probably needs to be replaced but check toner first.
Mar 19, 2017 | Sharp Office Equipment & Supplies
Sharp mx-2310u printing double vesion of an image, the copy and the lighter to the right. how can i fix this?
Double print usually happens when Drum completed its life and Cleaning Blade unable to clean the drum surface properly, Replacing of Drum and Cleaning blade will gave you good copy quality, Don't forget to clean Charger unit
Aug 27, 2014 | Sharp MX-2310U Color Printer : 2310U
Reset counter sharp ar-5631
Press the :
( #/P ) key --> ( * ) key --> ( clear ) key --> ( * ) key
clear the misfeed: 24 start --> 1 start
reset the maintenance counter: 24 start --> 4 start
reset the developer counter: 24 start --> 5 start
reset the copy counter: 24 start --> 6 start
reset the printer counter: 24 start --> 9 start
Nov 03, 2011 | Sharp AR-5316 Advanced Digital Imager...
How do you clean the print rollers? All my copies have a long vertical smudge/streak that runs entire length of the right side of the sheet (8.5x11 and 11x17).
It might not be the rollers but the image drum. A bad image drum will sometimes cause streaks on print outs. If you look at the right side of the image drum you will probably see a streak that matches what is being left on your paper. Be careful not to touch the image drum as it will cause fingerprint on your printouts! Of course if the image drum is bad it will need replacing and fingerprints won't matter.
Mar 01, 2011 | Ricoh Aficio AP610N Laser Printer
Our Sharp AR-160 copy machine is 5 yrs old. We have had to have continued maintenance, most recently the "developer" was replaced and our copies still come out faded. How long should we expect...
Did they clean the laser unit?
You can play with bias to raise the copy darkness.
For start you can open the front door and right side way door, remove drum unit, and you will be able to see long glass above drum unit. clean it with the dry wipe or wet one but be sure to dry it.
By my experience it is a good low maintenance copier... if the preventive maintenance is carried out correctly, every 60 000 copies more or less.
Hope that helps!
Dec 27, 2010 | Sharp AR-160 Copier
I have a sharp ar-m257 copier. my copies were
There are a few thing's > have you cleaned the optic's > clean the primary charge unit in the drum unit > how old is the drum & developer? Also, is the copier calling for for "Maint's Req"
Apr 05, 2010 | Sharp AR-M257 Black and White Copier
Sharp sf 2114 too much toner on copies
Sound like you need to have the developer, drum and drum blade replaced, you might want to have a tech look at this.
Hope that helps.
Lbcoaster
Nov 13, 2008 | Sharp AR-5316 Advanced Digital Imager...
Big Black Ink Line in all copies
Lift up a lid and clean the tiny scanner glass. One black dot will cause that effect to happen when using the document feeder. If the glass is clean, open the door on the right side and look at the green drum for lines. If you see any lines on the drum, then it's time for it to be replaced.
Sep 22, 2008 | Sharp AL 1631 Copier
My sharp sf 2022 machine, i need solution
mr engineer please check the drum mark sensor and clean it and also check the check the toner motor connector and do this program    c interrupt 0 interrupt ,44 copy key 07 copy key after stoping the machine off and then on but first clean drum unit maintenance code is 20 then copy key and then three times ca ca ca
Oct 18, 2007 | Sharp AL 1631 Copier
Sharp AR-5320 Black and White Copier Logo
67 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
