I haved a 50h71 toshiba with red and green line running vertically on screen. Please help in solving.
    President:
  • 4,402 Answers
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
· http://www.mouser.com/index.cfm?handler=home
· http://www.mcmelectronics.com
· http://www.bdent.com
· http://www.electronix.com
good luck
please mark the post with a fixya
Posted on Feb 20, 2008
Vertical red and green lines on the screen
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hoping this will help in solving the problem....
Jun 27, 2011 | Samsung LNT4066F 40 in. LCD Television
Toshiba 50H13 blurry picture with white line on right side
replace all the surface mounted electrolytic capacitors on the hyper module. also called the scan converter module. this is a common trouble. what a nasty job. good luck.
Jun 23, 2009 | Toshiba 50H13 50" Rear Projection...
LCD screen has black and red colrs + a green vertical line
Reset the video card, and if that doesn't work it sounds like the card is dying. How old is the card?
Apr 03, 2009 | Toshiba Satellite A100-S8111TD Notebook
Getting 2 images on top of each other on Toshiba 50H71
How To Enter Service Menu is what you need to know and replace both of your STKs these ic chips control convergence.If they are STK392-110s use STK392-180s better ics.
Dec 18, 2008 | Toshiba 50H71 50" Rear Projection...
Toshiba 50H71
you need to replace both the convergence ICs they are STK392-110 you can get new replacement ICs at the following link and they will provide free instalation instructions with pictures so you can do the repair yourself. Heres the link.
http://servicemanuals.vstore.ca/
May 29, 2008 | Toshiba 50H71 50" Rear Projection...
Toshiba 50H71 projection tv
You need to replace both of the convergence ICs they are number STK392-110 you can get new replacement ICs at the following link and they provide free instalation instructions so you can do the repair yourself which tkes about 30 minutes to do and saves you about 400 dollars. heres the link.
May 18, 2008 | Toshiba 50H71 50" Rear Projection...
One green vertical line in HDTV Vizio 42
Try changing the H/V position in the TV Set Up menu. You can adjust the horizontal and vertical position of the screen and move it enough that the green line disappears from the screen.
May 18, 2008 | Televison & Video
Red picture toshiba model 50h71
try to turn down the screen control and see how the tv reacts.
Apr 10, 2008 | Toshiba 50H71 50" Rear Projection...
Toshiba 42h81
Hello, one of possible solutions is to replace capacitors (10uF/50V) on HYPER (PD0246) module. Please ask the tech to check/replace them. If you need more info please advice.
Apr 27, 2007 | Toshiba 42H81 42" Rear Projection...
Televison & Video Logo
71 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
