Question about Acer Aspire 5315 Notebook
My pc does not recognize the DVD ROM What do I do?
  • 109 Answers
CAUSE-It may happen due to some corrupted registry keys in the computer.we can follow the following steps to delete the upper and the lower filters.
RESOLUTION/ WORKAROUND-
1. Locate the following key in the registry: HKEY_LOCAL_MACHINE\SYSTEM\ControlSet
2. In some cases, there may be multiple ControlSets. You may see something similar to the following HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002
Or
3. Select either CurrentControl Set or the lowest numbered ControlSet, for example, in the second list above, ControlSet001, and do the following.
4. Locate the following key and highlight it in the left window of the Registry Editor. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
5. In the right window, you should see something similar to the list below. There may be some variation in the listed drivers for the upper and lower filters. For example, the upper filters may list a driver other that PWD_2K. You may also see only upper or only lower filters:
LowerFilters = CDRALW2K
UpperFilters = PWD_2K
6. Delete the upper and/or lower filters.
7. Exit the Registry Editor and restart the system.
NOTE: If the computer still does not recognize the drives, go back into the registry and repeat the above steps for editing the registry for each of the ControlSets listed on the system.
Posted on Feb 04, 2010
Dvd rom in samsung laptop 300E failed to be recognized
boot live os cd
if its ok
problem in your os
Mar 11, 2014 | Samsung X05 Notebook
Dvd/cd writer will not recognize cd's or blank disk's will recognize dvd but not play.
Did this problem occur after a OS upgrade? Open Device Manager, DVD/CD-ROM drives, open and uninstall the DVD/CD rom. Reboot your machine, Win 7 should apply the correct driver. If you need a driver go to your manufacturer's website. Drivers and support section.
Dec 14, 2012 | Computers & Internet
My compaq presario f768wm isnt recognizing my cd/dvd rom. my camera quit working and also it says it can't find my audio output device.
For that problem, Try first replace that internal DVD-rom drive other good internal DVD-rom drive. if not Also Detected or recognize.
Try this second solution. insert external USB type DVD-ROM. if not recognize also, Your operating system Have internal software device data corrupted. You need to reinstall operating System like windows xp, windows 7 (OS) etc.. to fix data Corrupted of operating system device for hardware software.
Please see sample external DVD-rom USB type.
Just let me know if not yet working your Compaq Presario 700 series DVD-rom Drive.
Thanks for using Fixya.
Aug 19, 2011 | Compaq Presario 700 Series DVD-Rom Drive...
Just installed new HP dvd1270i. PC boots but
Check your power connector to the DVD Rom and also check the cables (Sata or IDE). If this doesn't bring any solution, scan your system using updated anti virus. Good luck.
Apr 07, 2010 | Dell DVD-ROM for Dimension (6t903)...
Dvd-rom sd-616E driver no longer recognized by
Reboot the computer and go into the BIOS, see if its recognized in there, if its not recognized then you'll need to turn the computer off and unseat and reseat the cable and the power connector to the dvd drive. Then turn on the computer again and go into the BIOS, if the dvd drive is still not recognzied then you'll need to replace the drive.
If the dvd drive is recognized in the BIOS and not in windows then you'll need to go into the system restore in windows and choose a date the last time the computer was working, it will restore your computer back to this date and reboot. At that point it should recognize your dvd drive. If it doesn't then your OS is corrupt and you'll need to wipe out the drive and restore your computer back to factory defaults.
Feb 04, 2010 | Gateway 5200XL PC Desktop
Dvd rom is not recognized
Not all computers detect DVD-ROMs. Look at the label on your laptop drive. If it says it supports DVD-ROMs, than you will be able to use it. If not, consider buying a DVD-ROM drive.
Nov 23, 2009 | Acer Extensa 5620 Notebook PC
Worked in other computer in this Gateway Celeron 1.2gh it does not recognize that it has a cd or dvd in it. Running WinXP Pro with sp2, roxio 9 and Cyberlink PowerDVD6
If the pc isn't recognizing the hardware the main reason this happens is that you need to install the proper drivers.
Here's a link: Hope it helps
http://www.opendrivers.com/category/15/cd-rom-free-driver-download.html
Good Luck =)
May 24, 2009 | CyberDrive DVD-ROM DM-166D Internal DVD...
I cannot get my DVD Rom drive to recognize any DVD
You need to install the DVD decoder that came with the drive such as PowerDVD or WinDVD. If you dont have the disks or setup files for those, you can download a free Windows DVD player program such as VLC Media Player that will work. http://www.videolan.org/vlc/
May 18, 2009 | HP Computers & Internet
Want to Boot from dvd ROM
when the pc in post usually on dells bios there is a boot menu option it is usually f12
if you don't know what your doing in the bios it is not a good place to test your skills after pressing F12 just choose cd rom for boot
Jan 28, 2009 | Dell OptiPlex GX280 PC Desktop
Presario 3700 dvd writer no longer recognizes bland dvd disc
the lazer lens of your DVD rom was not able to read the disc. Clean the optical lens with soft materials. if same errors after cleaning, Be sure that your system is stable can can cause error on DVD rom if either that is not the case. maybe its time replace your DVD rom.
Jan 10, 2008 | Compaq Presario 5000 PC Desktop
Acer Aspire 5315 Notebook Logo
182 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
