Question about Samsung HCP4252W 42" Rear Projection HDTV-Ready Television
I just replaced two ic chips stk 010 on my hcp4752w and it fixed the red background but is still off all three colors are off now and i triple checked my soldering and everything seems good ,the grid is off in covergence mode , any advice would be helpful
  • Samsung Master
  • 1,525 Answers
Hello did you check the resistors in front of the ic and the 2 capacitors at either end
regards
shaun
Posted on Feb 07, 2010
I changed my two IC chips and three resistances on my Hitachi TV to fix color alignments. Now the problems is that yellow and blue double image are seen at the bottom of my screen with no much effect on...
Ur tv still have dead resistors parts,test all 12 resistors parts around the 2 STK convergence ICS and changes some more dead resistors parts or changes all 12 resistors parts for sure.If tv still have the same problems after tested and replaces more resistors parts or all 12 resistors parts.Than some how when u handling and replacing the 2 STK convergence ICS and resoldering the 2 STK covergence ICS u short it out the 2 STK convergence ICS by resoldering without proper grounding ur self not to allow for static electricity to kill the 2 STK convergence ICS or u using a soldering iron to high of a wattage for doing soldering ICS work.
Apr 23, 2011 | Hitachi 43FDX01B TV
I have a mitusbishi ws-a65 hd 1080 tv. im having trouble getting the picture to line up with the shodows, its showing double, how can i fix this?
Your Convergence ICs have likely failed. It is very common on rear projections. Replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu.
Use this simple test to verify.
Go to the users menu on the tv.
Look for the converge option to align the red and blue colors
If you cannot move the red either horizontal or vertical, then the STK chip has failed for red section.
If you cannot move the blue either horizontal or vertical, then the STK chip has failed for the blue section.
If you can move both in each direction then the problem is something else.
Note if one STK chip fails, you replace both regardless. There may only be one STK chip in this set. If there are two, they will be right next to each other.
Feb 20, 2011 | Mitsubishi Televison & Video
Tv is showing double images, not lining up
Your Convergence ICs have failed. Replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu.
Feb 20, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Picture is no longer working properly. Picture is blurry and colors are all wrong. Ghost image. Happened all at once not gradually. What needs fixed mitsubishi 65" medallion series. appox 7 yrs old
Your Convergence ICs have failed. It is very common on rear projections. The solution is to replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu. It is about a $300 repair at a tv service center. You will need the service manual if you decide to do this yourself.
Try This:
When you notice the symptons Use this simple test to verify.
Look for the converge option probably under setup or video setting. Converge is short for convergence to align the red and blue colors to the green color.
Feb 19, 2011 | Mitsubishi WS-55819 55" Rear Projection...
I have the samsung hcp4752w tv , and it wont turn on . i no the convergence chips are bad , because the person i bougth it from let me no , he also gave me the convergence repair kit with it , but all of...
Right next to the convergence IC's you'll see the resisters. Get a meter and do an Ohm check. You can find out what the resisters are rated at by the colored bands on it.
Read this
http://wiki.xtronics.com/index.php/Resistor_Codes
Dec 14, 2009 | Samsung Televison & Video
Hour glass bowing on the top and bottom of my HCP4752W Samsung
Check the resistors near the ic, and the fuses to the ic's, i bet you will find an open fuse. the fuse will look similar to a resistor without color bands. use a dvm and set it on ohms, with the tv turned off.
Sep 02, 2009 | Samsung HC-P4752W 47" Rear Projection...
SAMSUNG HC-P4752W 47
There are three main reasons that convergence can still be inoperable after replacing the convergence amps. One, when the amps failed they blew the fuses protecting the power supply from shorts. Two, when the amps failed the yoke return biasing resistors burned open. And Three the Digital Convergence Unit has failed. Once things have gotten to this point it is usually time to have a professional have a look at the set.
Jun 02, 2009 | Samsung HC-P4752W 47" Rear Projection...
Samsung three colors on screen, out of focus #hcl4715w
It is a convergence problem. The IC's (integrated circuits) or STK chips or the "guns". You have a red,and blue, IC's that provide all the colors. When the colors are out of convergence, you get ghosting or what looks like 3D pictures. I haven't been able to locate the part numbers for the IC's or STK chips but have located a convergence board. No luck determining if IC's are included (a phone call first to verify) but if they are, would make life much easier for you to install. Part # is BP95-00415H http://jr.partsearch.com/Part/Samsung/Samsung/BP9500415H/New.aspx?ModelMfgName=Samsung&ModelBrandName=Samsung&ModelNumber=HCL4715W
Typically, IC's cost around $10 or less. here is a link to a guy who provides pretty good instructions on replacing the IC's along with pictures.
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Hope this answers your questions. Best of luck.
Greg
May 31, 2009 | Samsung HCL4715W 47" Rear Projection...
SAMSUNG HC-P4752W 47" TV Convergence problem
Resistors most likey...look for burnt or discolored resistors near the convergence chips.
Apr 07, 2009 | Samsung HC-P4752W 47" Rear Projection...
Seeing triple red,blue,green
you have proble with the convergences ICs if the tree colors are at fault then also check your power supply voltages the polarization resistors
Feb 08, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Samsung HCP4252W 42" Rear Projection HDTV-Ready Television Logo
90 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
