Local Disk(D:) is not accessible Access is denied
My local disk drive is cannot accessible. when trying to opren(click) the dive the text box shows access denied. How this problem can solve? my harddisk is cannot open or access deneid
First u have format the c:drive the problem is solved
if not u should format all over the system
Posted on Feb 20, 2008
I HAVE ACCESS DENIEND ON LOCAL DISC HOW CAN I SOLVE PROBLEM?
Posted on Nov 13, 2008
If access is denied, right click on the drive and set administrator rights to gain access.
Oct 10, 2015 | Computers & Internet
I have encrypted my local disk using bitlocker encryption and now it shows Local Disk(D:) is not accessible Access is denied and when i right click it was not showing security tab. please help me
Try This:
Before you start
  • You must be logged on as an administrator.
  • The volume must be encrypted.
To turn off BitLocker Drive Encryption
  1. Click Start, click Control Panel, click Security, and then click BitLocker Drive Encryption.
  2. From the BitLocker Drive Encryption page, find the volume on which you want BitLocker Drive Encryption turned off, and click Turn Off BitLocker Drive Encryption.
  3. From the What level of decryption do you want dialog box, click either Disable BitLocker Drive Encryption or Decrypt the volume as needed.
    By completing this procedure, you have either disabled BitLocker or decrypted the operating system volume.
    Good Luck!!
Aug 16, 2012 | HP Computers & Internet
"Access is Denied"
you need a file called takeownership which when run installed to the reg it gives you the option of taking ownership removing that anoying Access Denied screen.
google for it I did and it works a treat.
good luck
Jul 07, 2008 | Computers & Internet
The hard disk in drive D: is not accessible
My Toshiba lap top when i try and copy pictures to a disc it will not let me it says D:/is not accessable.incorrect function
I also tried downloading pictures from a cd and it would not read it though it did read a pdf file for documents on another disc
Mar 02, 2008 | Samsung Super-WriteMaster SE-S164L DVD?RW...
I recently had this problem. Whenever I clicked on any of the drives a window appeared with warning which said drive not accessible. Access is denied. Previously I thought that it is a virus which has edited my registry and is not allowing me to enter or even view my content. So I formatted the whole system but that didn't help. Now I am sharing this with you.
  1. Open My Computer. Goto Tools>Options. Goto View Tab Pane. Uncheck the last Option in the Advanced Setting which says Use simple file sharing(Recommended). Apply the setting.
  2. Open the properties window of the drive you are unable to access.Goto Security tab pane.
  3. Goto Advanced.
  4. Now click on the Owner tab pane.
  5. It's very rare that the ownership of the drive changes. But it happens once in a while.
  6. So if you are the user say Admin then select Admin(ComputerName\Administrator).
  7. Click on the box which says Replace owner on subcontainers and objects and click over Ok.
  8. Apply the changes.
  9. Now you should be able to access the drive.
Feb 18, 2008 | Samsung (SP0822N) 80 GB Hard Drive
Access denied
Using Admin logon, open mmc and go to disk management.
Right click on C: drive and click "Properties", select "security" tab and click "advanced" button, select "owner" tab.
Choose new owner and check the "replace owner" check box and "apply".
Dec 15, 2007 | Computers & Internet
Well this message can be two things(if not more) One of them being that the disk has security set and you wil need to change those settings if you want access to the drive the other scenario being that a program has locked the disk for exclusive access. Assuming you are using Windows XP. To check the security go to the properties of the disk then click on security(Tf the security tab isn't there, Open my computer then click Tools->Folder Options then the View Tab. Scroll to the bottom/last option then uncheck Use Simple File-Sharing press OK/Apply) Now back to Properties of the disk then Click the security tab. You'll need to try this first and tell me what's there, or if u got any error message etc. My explanation might be to long if i try to explain every possibility. regards, babb
Sep 26, 2007 | Seagate Barracuda 7200.7 40 GB Hard Drive
This occurs when the drive was taken from a PC where someone made the drive un-shareable.
The fix in XP:
1. Turn off Simple File Sharing, via Explorer, Tools, Folder Options, View, (NOT) use Simple File Sharing.
2. Now when you right click the drive letter for the drive on the new PC you will see a Security tab (made invisible by Simple File Sharing).
3. On the Security Tab, add yourself or any user, and grant Full Permission.
4. Now you can Explore the drive like any other.
Sep 20, 2007 | Computers & Internet
Computers & Internet Logo
755 people viewed this question
Alun Cox
David Payne
David Payne
