Question about Kenmore Washing Machines
Kenmore washer will not spin but will agitate? After testing it multiple times I can get it to spin for a short time then it stops???
Check drum belt, or motor
Posted on Feb 04, 2010
Kenmore stylemaster 902202 will not spin, agitate or drain tub spins freely
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. Or
http://www.youtube.com/watch?v=TB_W6sPdzkM
Pl click if helped
Apr 07, 2013 | Kenmore 24032\24036 Top Load Washer
Washer skips spin cycle what is the most likely problem
Hi
First make sure that nothing is blocking the drain pump assembly located inside the bottom of the unit, after this test the lid switch assembly, you jump it to test it. If the lid switch is also fine then the control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 28, 2011 | Kenmore Washing Machines
Kenmore washer spins while agitating. In fact it
burnt spot on time,stuck in spin mode-mike
Jan 27, 2010 | Washing Machines
My GE Wizard Washer will agitate or spin for a very short time.
replace the transmission. this job is better done after a few dozen bottle of your favorite whiskey. Check the timer controls to ensure timer is advancing properly. tranny's are notorious on ge's for this sort of problem as well as inner basket drive blocks coming loose. ge makes alot of great appliances, this just happens to be one of them that isn't. i trust their jet engines too, although hard to work on them from 30,000ft.
Jul 02, 2009 | GE WBSR3140DW Top Load Washer
Not sure if manifold is leaking
Leaks water...check the pump first. The fill valve and hoses may be the next step. See how to take apart info. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
  1. Agitation problems and agitator dog repair aid info
  2. Automatic dispenser information
  3. Common problems with Inglis, Whirlpool, Kenmore direct drive style of washers
  4. Diagnostic Direct Drive washer chart from American appliance
  5. How a washer works, good to read this first
  6. Help for storing an appliance
  7. How does the agitator come off my washer ??
  8. How to prevent socks from getting into your pump
  9. Ohm test a common direct drive motor
  10. How to by-pass a lid switch for testing the washer
  11. Basic information: Inglis, Whirlpool, Kenmore Direct drive washers
  12. Inglis, Whirlpool, Kenmore Direct drive washers - How to take apart - Cabinet off, cabinet on, checking or replacing a lid switch, replace the pump, replace motor coupling or motor.
  13. Inglis, Whirlpool and Kenmore direct drive washer- useful parts breakdowns
  14. Important disclaimer
  15. My direct drive washer will fill ok, agitates ok but when it comes to the spin and drain cycle the washer comes to a screeching halt...no spin, no draining and the timer stops, what's up?
  16. My clothes have a whiting on them that looks like lint.
  17. My washer has a funky odor
  18. Noises
  19. Ohm meter testing a motor capacitor
  20. Slow water fills
  21. The wash tubs on my direct drive washer are leaning to the right...why?
  22. Timer stalls or missing cycles
  23. Timer will not advance
  24. Tips on changing a common washer fill valve
  25. To learn more about washing machines, click here
  26. Washer Basics: Filling with water
  27. Washer leaks water
  28. Washer moves around to much
  29. Washer will not spin
  30. Washer sample wiring diagrams
  31. Washer spins and agitates at the same time
  32. Washer belts: If your belt on any washer looks like these, replace the belt(s).
  33. Washer runs but wont agitate or spin
  34. Washer won't run, agitate or spin
  35. What is that black power powder or filings under my washer??
Apr 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Kenmore 90 washing machine does not spin or agitate
make sure your pump is not clogged or jammed..that will stop the motor,,quick test,,pull pump off and start unit in wash,,or spin if unit is empty..onthejob
Jan 31, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer fills and agitates at same time
it sounds like the timer is going bad
Oct 22, 2008 | Washing Machines
Kenmore washer
Has it stopped agitating completely now or does it start each time then stops? Do you hear anything - say like a humm when you try it afterwards. Dose it spin/drain water from washer?. Post a response so we could know what next
Regards
Sep 01, 2008 | Kenmore 24032\24036 Top Load Washer
Begins to agitate but stops
The motor could be drawing too much current and causing the overload relay to trip. You will need to get an authorised techinician to test the motor.
Nov 01, 2007 | Kenmore 93702 Top Load Stacked Washer /...
Washing Machines Logo
18 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
