Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
Stained Screen The screen has a yellow stain on it, which began as a smaller circle and now covers almost the entire screen. When a picture is white, the color shows yellow. We've replaced the bulb and it didn't fix the problem.
  • Anonymous Mar 09, 2008
    Same issue
    Problem Solver:
  • 8 Answers
I just made this repair for $10 (and a bunch of personal labor). you can buy the part for $220 or repair for free if you snarf a pair of 3D glasses as you leave a movie. some googling will find a thread describing the fix and even a guy selling pre-cut polarizers for $10.
Posted on Jan 25, 2013
  • 3 Answers
QTV1,
I also have several yellow blobs on my TV (PT-50LC14). It is due to a burnt polarizer filter just past the blue filter for the blue chip. This TV is a three chip design with red, blue and green chips.
I am currently trying to get a new polarizer filter from Panasonic.
Duane at duanetr@sbcglobal.net
P.S. Do you want to sell an parts from your TV?
Posted on May 02, 2008
  • Hang123 Jun 04, 2008
    I received a new blue polarizer unit from Panasonic. I installed it and it fixed my problem!!!
    Duane
  • 87 Answers
You have a bad light engine.
Posted on Feb 24, 2008
Need to take yellow stain out pf white nike airmaxes
Hi. Do you know what caused the stain? You might want to try a cotton swab with a little bit of a diluted bleach solution - put 1 part bleach to 10 parts water, mix, and then dip the cotton swab in it and gently apply to the stained area. It might take a bit of work to get it all out. I hope this helps.
Mar 28, 2015 | Nike Clothing Accessories
White clothes come out stained
AT LEAST YEARLY YOU HAVE TO CLEAN WASHER ORTHER VICE STAINED COMING NORMALLY.. YOU HAVE TO CLEAN WITH OXSY CLEANE LIKE BORAX,CLOREX,,
Jan 20, 2014 | Miele Washing Machines
My 2 year old sprayed kitchen cleaner over my plasma screen and it stained is there any thing i could do to restore it back ?
No, the screen or glass front is a part of the the entire display panel which costs as a part more than the set did when new.
The coating on the screen is photo chromic and anti glare in nature much like the coating on expensive camera lens.
I had a used one with similar damage and the only thing short of replacing the panel was we used very fine rubbing compound and carefully removed ALL the coating on the screen.
Picture was brighter but any glare from indirect light showed a loss of brightness.
Either live with it or replace the set. Most sets in the owner manual have warnings about what not to use when cleaning a screen.
May 15, 2012 | Televison & Video
Panasonic DLP TV has huge yellow blotch covering most of the screen
SET uses a optical light engine--lamp which is quite hot shines into the engine---blue is first to get the light and heat and is usually first area in the lens and baffles to get damaged(loss of blue leaves red and green which equal a yellow screen.
You have a damaged light engine.
Apr 23, 2012 | Panasonic PT-43LCX64 43" HDTV
How do we remove erasable white board marker from the apollo screen?
With Windex, just use a wet rag afterward to make sure the ammonia is not left behind. If the screen is stained that is a different issue as you will have to use a cleaner that actually removes some of the screen, but doesn't eat through it entirely.
May 07, 2010 | ACCO Brands Apollo Projector Screen
The screen is scratched and stained- I would like
that is a good idea, but expensive.
if the screen is that bad, you may want to try with some commercial available polish for glass or plastic, like plast-x. you can get that in any auto parts store or your local walmart...
http://i93.photobucket.com/albums/l72/NoTwilight/temp/PlastX.jpg
Apr 23, 2010 | Toshiba 57HX83 57" Rear Projection...
Clothes are being stained and ruined in our kenmore washer. there are brown stains covering our white clothes.
This is greasy rust. It's not uncommon. Whats causing it is a bad tub bearing. I rate replacing it a 6 on a scale of 1 to 10. 10 being the hardest.
Please rate solution
Aug 27, 2009 | Kenmore Washing Machines
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
622 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
