Question about Thermador RDFS30 Dual Fuel (Electric and Gas) Kitchen Range
Need to take range top off a Thermador RDFS30. How do I do that
2 Suggested Answers
SOURCE: LP conversion for Thermador 4 burner range top
I have a Thermadore 6 burner gas cooktop PCG366E purchased January 08. I purchased the LP conversion kit, they only make one kit for all models. The instructions included with the kit were written for an older model and have not been updated by Thermador. The gas regulator is located next to gas inlet pipe. You have to get at it from above. Remove the 2 star burners over that side of the cooktop. You will need a 20mm socket to remove the nut at the center of the star burner. Lift it off and disconnect the wire to the ignitor ( You need to push on the spring lock in order to seperate the the connector terminal). Remove the stainless steel pan and then remove the metal pan underneath ( you will need a Torxs bit for this screw or vise grips). You should now see the regulator. At the top of the regulator is a cap with the letters NG visible. Twist this a 1/4 turn ccw, lift up and turn over to expose the letters LP reinsert. The regulator is now ready. You will need to replace the orifice tips at each burner. Use a 7mm socket with an extension. Put a piece of tape in the socket to hold the orifice in place while you insert it. You also need to adjust the valves. You must pull off the knobs and and remove the trim bezel. If you look through the screw hole on the right you will see a screw head (bypass screw). Insert long skinny flat blade screwdriver through the hole and turn the screw CW all the way (about 1/4 to 1/2 turn in my case). My cooktop had two burners with a low simmer feature, This devise is located in front of the bypass screw. It has a hole in it but does not align well with the head of the bypass screw and makes it difficult to turn the scew. Thats it, I hope this info has been helpful. I have not yet connected the propane therefore have not tested the unit but it should work.
Posted on Feb 27, 2008
How do I access lead to the broiler element on a RDDS30V thermador that has fallen into the space behind the oven cavity?
You should be able to get at it by removing the back inner panel. The website at the link below has good schematics and shows the assembly of most appliances.
http://www.appliancepartspros.com/02-information-items-parts-for-thermador-rdfs30.html
Feb 07, 2015 | Ovens
Door locked
Your door lock mechanism failed. Needs to be replaced
Apr 11, 2013 | Thermador RDFS30 Dual Fuel (Electric and...
Oven is on but display says not
If you live in Huntington Beach, CA and need oven repair service call us at (714) 698 88 73 or find useful info on our website Oven Repair Huntington Beach CA Appliance Repair Huntington Beach CA
Aug 29, 2017 | Thermador RDFS30 Dual Fuel (Electric and...
Left two burners do not have gas flow and ignigator does not spark
Lift top of hood and check if gas flow pipe are blocked with debris. It may need to be cleaned.
Aug 16, 2010 | Thermador RDFS30 Dual Fuel (Electric and...
One of the Burners does not light.
that part is about $150.00 ouch. Take a look on repair clinic .com I am amazed that some of the parts for it are no longer made. Also there is a place in Carol Stream ILL that will refurbish some parts for your unit. Contact CG Industries at (630)588-4030. Located at: 356 Gundersen Dr., Carol Stream, IL 60188. Let me know if this helped
Apr 28, 2009 | Thermador RDDS30 Dual Fuel (Electric and...
Install replacement glass cooktop on thermador electric range
i have thermador range model # REF30RS. my glass broke, i ordered the part, replaced the glass, but i do not remember where all the screwss go. where can i get a diagram?
Mar 12, 2009 | Thermador REF30 Electric Kitchen Range
Drip pan
I don't have a solution, but I am trying to figure out how to remove the sealed burner drip pans on a Thermador PRSG 364 GLS gas stove. Any suggestions?
Apr 29, 2008 | Thermador RDFS30 Dual Fuel (Electric and...
Thermador RDFS30 Dual Fuel (Electric and Gas) Kitchen Range Logo
55 people viewed this question
Top Thermador Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
