Question about NEC Lands Phones
Phone not ringing for incoming calls light is blinking
    Problem Solver:
Found manual and reprogrammed
Posted on Feb 07, 2010
How to stop all lines blinking on incoming calls-
the problem has started after a service provider change
get them back to fix or change service providers again
Jun 20, 2017 | Avaya 1416
Our phone is not ringing for an external calls but the light is blinking indicating that there is an incoming calls, but calls coming from intercom does ring! meaning our phone is not in silent mode and i...
There are many features which can cause the phone not to ring when incoming calls are on the line. There is a do not disturb key and a mute button on the phone itself. Check to make sure they have not been set. There is an incoming call feature that sometimes needs to be programmed on the phone before it will ring for incoming calls. There is also an automatic answer function that can interfere with ringing too. Instead of listing all of the possibilities, I am including a "cheat sheet" with all of the features & programming for your phone below. Click on the link and scroll through the options to troubleshoot this issue.
If you have any questions please use the comment or reply link near your question on Fixya's website to contact me and I will continue assisting you until this issue is solved.
Sep 14, 2011 | Panasonic KX-T7730 Corded Phone
One phone handset will not answer incoming calls. You can call out on that handset, but it will not answer incoming calls.
It needs to be put in the ICD group. By default, nobody is in ICD group 1. Adding the phone and giving a ring status to it, even if it's no ring, makes the light blink on incoming calls. If you have access to system programming it's program 622 and 623. If you don't, your dealer/installer will have to do it.
Carl
Jul 07, 2011 | Panasonic KXDT321 Phone
1 lines is ringing & another is not ringing
Somewhere you should have a programming and operating manual for your phone system. Typically in a Panasonic you turn on CALL WAITING for both Intercom and Outside lines via a code you dial at each phone on the intercom (7311# 7321# for a TA).
This is assuming that the lines are already programmed to ring at the phone.
Carl
Aug 21, 2009 | Panasonic KX-T7730 Corded Phone
Line 4 doesn't ring in coming call
The way 4 line phones work is that you need 4 lines on every jack that is connected to your phone.
You see the light probably because one of the phones has line conected and you see line appearance.
Mar 20, 2009 | Nortel Lands Phones
Some phones light up but there is no ringing...
is the ringging assignment setting
means downstair phone been set for incoming ring, so u can see the indicator ligh on and ringging
up stair dint assign a incoming ring so that u only can see the indicator light always blinking w/o ring...
contact yr phone provider to set the ringging assignment
Feb 24, 2009 | Toshiba DKT-2020 Corded Phone
Night button and incoming calls
The programs involved with you ringing are 81 ( no light or Day Mode ), 84 ( blinking red light or Day 2 Mode ), and 87 ( solid red light or Night Mode ). To change the ringing assignments you need to know the port numbers of the phones you want to ring or not ring. You can do this by pressing DN/ICM dialing # 4 0 2 at each phone, the diaplay will show the physical and logical port numbers. These numbers will be used to turn on or off the aaociated lamps within the above programs. Do you have anyone on staff that understands the system programming ? Let me know ...Mike
Jul 17, 2008 | Toshiba DKT-2020 Corded Phone
Incoming calls blink red
Your phone is not programmed to ring. call local dealer for programming change.
Jul 07, 2008 | Toshiba DKT-2020 Corded Phone
Blinking light but no ring sound on incoming calls
This is a phone system phone and each station you want to ring when a certain phone line rings has to be programmed into the system. This is not something you can change at the phone itself. You will either need to pay a company to make programming changes or locate a programming and installation manual for your phone system (not the phone) and try to re-program it yourself. If you have not done this before it will not be easy but it may be worth the effort so you can continue to make your own changes instead of paying someone $200 per hour to do it for you.
There is also the remote possibility your phone's ringer is broken. You can try swapping your phone with another of the same type and model to see if it will ring.
Oct 17, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
Lands Phones Logo
279 people viewed this question
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Oloyede Monsuru
SC Spike
Level 1 Expert
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
