Question about Vehicle Parts & Accessories
Radio does not come in after remote start was installed.Is this an issue with the transmitter being close to the car antenna?
    President:
  • 547 Answers
No, the transmitter for the remote start won't interfere with your radio receiver. It's likely that the installers just unplugged the radio antenna wire from the back of the radio itself.
The radio's antenna wire is a thick (1/4" diameter) black cable, with a 1-1/2" connector at the end of it. If you can locate this wire on the back of your stereo, push it back in to the stereo until it seats all the way in.
If you paid someone to install the remote start, it would be totally reasonable to have them inspect/fix this at no charge.
Posted on Feb 04, 2010
Remote will only start when i am close to vehicle
It depends on many things - mostly the range of the system itself and especially where you located the remote antenna. Some installers don't use the antenna and that will limit range severely. Most manufacturers want the antenna routed up the windshield pillar and mounted near the top of the windshield glass. This gives best reception since glass does not hinder the RF signal. OF course, a weak battery in the remote can cause range issues as well.
Nov 25, 2015 | Car APS921 Remote Starter - Keyless Entry
Garage door opener remote does'nt work when the garage door is shut
Probably you have a weak battery in your remote transmitter. When the garage door is closed it requires a stronger signal. Open the remote and replace the battery.
Oct 20, 2012 | Home Security
My radio will not transmitt but it receives just fine
Most problems with radios that receive but do not transmit are antenna or antenna wire/connector issues. It's easy to receive with a marginal antenna but transmitting requires a good working antenna. If you have a SWR meter or can get your hands on one, install it in line with the antenna and test for reflected power. Of course, make sure your TX light comes on when you depress the mic switch. If not, switch mic and try again.
Hope this is helpful! Reply if u can.
Oct 06, 2012 | Uniden Solara DSC VHF Marine Radio
Why alarm only works when close to car
Poor range can be caused by a number of things. Has this problem only been occurring recently? If yes, try replacing the battery in the remote transmitter since a weak battery can be a problem. If this is a new install, bring it back to the installer to have them check it. Other possible causes can be improperly positioned antenna, the alarm brain installed too close to an electronic control unit, the alarm brain mounted to a large ground plane or a defective alarm brain.
Oct 22, 2010 | Audiovox Prestige Code Alarm Remote Alarm...
My remote says no antenna. can not arm alarm.
REPROGRAM YOUR REMOTES USING THIS PROCEDURE:
REMOTE TRANSMITTER PROGRAMMING
Enter:
1. Turn the Ignition 'switch ‘OFF/ON’ 3 TIMES and stay in
ON position. Within 15 seconds.
2. Push the Valet switch 2 times and hold in on the 2nd
push, when a long chirp is heard then release the valet
switch. You are now in the Transmitter programming mode.
Program:
1. Press the Lock button on transmitter 1 until the siren
responds on Car with a confirming chirp; the first
transmitter is now programmed to Car.
Exit: Turn Ignition to 'OFF' position, or leave it for 15
seconds. 3 long chirps will confirm exit.
Note: If more than 4 transmitters programmed, the system
will only keep the last four.
Jul 06, 2010 | C3 RS6652W (NEW with 1 LCD Transmitters)...
Can an on-off switch in car antenna help FM transmitter sound ?
  • they are dependent upon the antenna. best thing to do if u want a to spent the time and money to do that would be to install a new stereo witha AUX plugin instead of your FM transmitter
Dec 02, 2009 | Car Audio & Video
How do you prove a remote control is transmitting?
take a digital camera (has to have a screen on it) and zoom in on the end of the antennae. if you look REALLY close, you can see tiny radio waves coming from the end. If you dont see any then you will have to go to a store like WAL-MART and get a new remote.
Jan 17, 2009 | Cars & Co Remote Controlled Car
STATIC/INTERFERENCE
&R=11812445&C=17577363&K=NBy0rr?h=2mv3s7&r=11812445 Your SIRIUS radio contains an FM transmitter that allows it to operate wirelessly through your car FM radio. We have determined that the output of this transmitter exceeds the limits established by the Federal Communications Commission (FCC). As a result, the unit may interfere with the performance of radios operating in areas adjacent to your radio. There are no health or safety concerns associated with this issue.
  • If you listen to your SIRIUS radio wirelessly through your vehicle's FM radio, then please review the solutions listed below and select the one that works best for you. SIRIUS will provide you the best solution at no cost.
  • If you use your SIRIUS radio only when docked in a boombox, or directly connected to your car radio or home stereo using audio cables or a cassette tape adapter, then no interference can occur and no further action is required, provided you have turned off your FM transmitter. To turn off the FM transmitter, first press the MENU button. Use the channel up/down buttons to highlight “FM Transmitter” and push the SELECT button. Use the channel up/down buttons to highlight the "FM On/Off" menu item and then press the SELECT button. Use the up/down buttons to highlight "FM Off" and press the SELECT button. To exit the "FM On/Off" menu, press the MENU button. Use the same procedure to turn off the FM transmitter if you use Solution 1 or Solution 2 below..
Solution 1 - Direct Wired Audio Connection: If your vehicle radio has a “LINE IN” or “AUX IN” jack, you can use a stereo cable to connect directly to your SIRIUS radio. This solution is the easiest to install and provides the best audio performance. Many newer vehicles provide the required audio input jack. It will normally be found on or near the front faceplate of your vehicle’s radio.
Solution 2 - Cassette Tape Adapter
: If your vehicle has a cassette tape player, you can use a cassette adapter that allows you to play your SIRIUS radio through the cassette portion of your vehicle radio. The adapter slips into your vehicle radio as easily as a cassette tape and provides better performance than a wireless connection. fcc_a_2.jpg
Solution 3 - FM Extender Cable Kit: An FM extender cable will provide a special transmitter antenna that allows you to obtain the best audio performance through your vehicle’s FM radio. This solution is easy to self-install, but does require that an easy-to-hide wire be run in your vehicle so the transmitter antenna can be placed in close proximity to your vehicle’s radio antenna. Using this FM Extender Cable Kit, you will continue to use your SIRIUS radio exactly the same way as you do currently. fcc_a_3.jpg
Solution 4 - FM Direct Adapter with Professional Installation: An FM Direct Adapter provides a wired connection between your SIRIUS radio and your vehicle’s radio. You will continue to listen to your SIRIUS radio through the FM tuner of your car radio, but the FM Direct Adapter eliminates the outside static and interference you sometimes experience when using a wireless FM connection. This solution usually requires professional installation. We will provide a certificate redeemable for installation at an installation center in your area.
Please go to www.sirius.com/optimize and select the solution that works best for you. If you have any questions, please call 1-(877) 635-5130. Detailed instructions will be included with your solution.
You will improve the performance of your SIRIUS radio and reduce the potential for interfering with adjacent radios if you properly tune your FM transmitter. Please see the FM Transmitter Set-Up Tips below for more information.
We are sorry for this inconvenience. We are confident these solutions will allow you to continue to enjoy the great music, news, sports and entertainment that only SIRIUS Satellite Radio can offer with no impact on your radio’s performance.
Sincerely,
SIRIUS SATELLITE RADIO
To tune your FM transmitter turn off your SIRIUS radio and tune through the FM channels on your vehicle’s radio to locate an FM channel (except 87.7/87.9) that is not broadcasting in your area. If you use an FM channel that is being used by a local broadcaster, it will interfere with the performance of your SIRIUS radio. Once you have located an FM channel that is not being used for broadcasting in your area, save it as a preset on your vehicle radio. This will become your SIRIUS preset. If you’re not sure which FM channels are not being used in your home or travel cities, you can go to www.sirius.com/fmchannel and search for an FM channel based on zip code.
Turn on your SIRIUS radio. In the SETTINGS or MENU on your SIRIUS radio, locate the “FM Frequency” adjustments. Set the channel number on your SIRIUS radio to match the SIRIUS preset on your vehicle radio. Refer to your user guide for detailed instructions on how to do this. The FM transmitter in your SIRIUS radio is automatically set to FM channel 88.1. This may not be the best channel in your area.
Jul 08, 2008 | Sirius Starmate ST2 Satellite Radio...
Vehicle Parts & Accessories Logo
37 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
