When usb device plugged into usb ports. XP OS freezes. The freeze occurs instantly, during bootup or after boot up.
  • 382 Answers
Search for a bios update for your model of computer. Failing that remove the USB driver from the device manager and re-install it. I had a similar problem with my HP (I hate HP laptops but that is another story).
Posted on Feb 04, 2010
Blue screen when usb plugged in to new board old xp home
1.) Ensure XP is updated with latest device drivers
2.) Ensure latest chipset & motherboard drivers are installed
3.) Check USB drive, and USB port
4.) Boot up with any Linux OS Boot up disk and check if USB is working
5.) Install Windows 7 in case new drivers not available on XP
Feb 26, 2013 | Computers & Internet
When i plug in device in to a usb port my computer freezes up
have you tried a different USB port because theres two types of usb port & one on the back has pin's inside it check that these arnt bent or touching you should use the side ports for your basic everyday external devices.
Aug 12, 2009 | Computers & Internet
My RCA TH1611 mp3 player freezes upon booting.
Sometimes the firmware or player files are garbaged and the player looks like it starts halfway then freezes. If this is your problem and you're sure the battery's fine (and in the right way) then you can try to reload the flash on the player and as a last resort reformat the file area as well.
Go the RCA support website and download the latest flash for the th1611 and run the program. You may be lucky off the bat, but if the first attempt fails review the troubleshooting procedures that will tell you to hold the play button while plugging the device into the usb port. If, after the program flash, the device still fails to start, you'll have to erase the file area to un freeze the device.
I had a weak battery that that I pulled out while the device was starting and it seemed to corrupt the player. Thisprocedure worked for me.
FYI, the flash program works on XP 32bit, but I don't know if it will work with Vista
Jul 07, 2009 | RCA TH1611 MP3 Player
Machine freeze up randomly. Must do a hard shutdown. Seems like a motherboard failure
Freezes and crashes are generally caused by some sort of instability in the computer system.
The following is a list of specific problems that can cause instability along with what to check when troubleshooting each.
Viruses can cause instability.
Run a virus check on the computer to look for a possible virus.
Conflicts can cause instability.
Check the Windows Device Manager to see if there are any yellow exclamation marks or red Xs beside the listings for device classifications. If there are, contact Tech Support.
Buggy or damaged software applications can cause instability.
If the system is less stable when certain software programs are running, shut down those programs and see if the problem continues to occur. If the problems stop, chances are that those software programs are causing the problems.
Buggy, outdated, or conflicting drivers can cause instability.
Check manufacturer web sites for updated device drivers for the various devices installed on the computer system, such as: printer drivers, modem drivers, video drivers, sound drivers, USB device drivers, etc.
Update one driver at a time and see if the system stabilizes. If this doesn't work, it may be a hardware problem, so contact Tech Support.
AC problems can cause instability.
Check to see if the computer system is plugged into an overloaded outlet.
Make sure the computer system is plugged into a surge suppressor.
The installation of new devices can cause instability.
There are three typical symptoms that point to this problem:
The computer system fails to boot, freezes during a boot, or freezes during an operation for no apparent reason.
The system fails to recognize the newly installed device.
One or more software applications fail to function as expected after an upgrade.
Hardware failure can cause freezes
Fan failure, cpu failure, memory failure, could be also a cause of freezing.
Keep track of the hardware and software that is added to a computer.
The addition of new hardware and software can often cause problems to occur.
Nov 07, 2008 | Computers & Internet
Antivirus 2008
Some Tips for Dealing with Freezes and Crashes
Research the compatibility of new hardware and software with the existing computer system before purchase and installation.
The older a PC, the more likely it is to crash.
When a computer freezes or crashes, chances are that changes made after the last save and when the freeze or crash occurred will be lost.
Oct 18, 2008 | HP Compaq Presario v3000z Notebook
Western Digital My Book freezes computer on boot up.
Mine boots fine if I unplug (better yet, hold the flat button down on the back for about 5 seconds, and it will turn off).
Aug 31, 2008 | Western Digital My Book Essential Edition...
MX 510 freezing
Same problem been getting worse. Figured out that the mouseware driver is outdated and not compatible with win xp. Use logitech's setpoint for mx518 or uninstall mouseware. Now no more freezes
Oct 11, 2007 | Logitech MX510 Performance Optical Mouse...
Computer freeze on saving files to USB 2.0 External Hard Drive (and USB2 flash drive)
Suggest you look at the motherboard book to check if or how many USB connections are in fact USB 2 compatible. Most modern Motherboards only have 2 USB 2.0 Compatible connections, most are 3.0 or 4.0 compatible. Hope this helps, Malcolm Campbell.
Mar 12, 2017 | Belkin Hi-speed USB 2.0 5-Port PCI Card [...
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
