Question about Toto LPT972.8-01 Guinevere Pedestal Lavatory Sink with 8" Centers - Cotton
The stopper has come out and we do not know how to reattach it
  • mikenearman May 11, 2010
    does the stopper have a hole in the bottom of it?
    Scholar:
  • 84 Answers
It is actually a very easy fix but it is hard to explain to write out. The best solution it to go to your local home improvement store and bring the stopper along. Sometime they break and that is why the come out. They can show you how to replace it and get you the parts you need, if needed.
Posted on Feb 04, 2010
The toilet will not flush
Take the lid off the tank and see if the handle chain is connected to the stopper. If not, reattach.
Jun 09, 2018 | Home
Stopper no longer stays in up position on my bathroom sink
Solution to the most common design...
If you can pull the stopper completely out of the drain with no resistance, do this.
On the back side of the tailpiece that attaches to the bottom of the bowl, there is a rod coming out of the back side that has a nut holding it in. Unscrew that nut and pull the rod out part of the way. There usually is a loop molded into the plastic on the lower end of the stopper where that rod inserts into. Turn the stopper until that loop is aligned toward the faucet and insert back into the drain but not all the way (keep it held up about 1/4-1/2 inch from completely closed). Reach under the sink and feel for the rod while you are holding the stopper in place and push it back in while you "feel" for the loop. You will know it is inside the loop when you can't pull the stopper out with not resistance. Screw then nut back onto the threads and finger tighten it until it has enough friction to hold itself at any position.
Hope it helps...
Oct 02, 2013 | Price Pfister Plumbing
I have a lav sink where the stopper no longer comes up. The plunger shaft goes down. I have removed the stopper and can see that it has a female threaded "throat", but there's nothing to...
if you look under neath your vanity you will see where the plunger goes into the drain pipe. remove it and see if your activator rod is there, if so this is what screws into the plug end. if it is not there remove your U section and see if it is in there and reattach it. if it is broken you will have to get a repair kit at your local hardware store.
Aug 09, 2011 | Kohler 7129-A-CP Lavatory Grid Drain with...
Where can I buy a stopper for my Aladdin flask no. SB950H stopper has a piece broken off the side and will not seal regards Maureen Perry (Australia)
Hello, well over here in the US we have several places. You can rubber or cork stoppers stoppers at Lowes or at an Ace Hardware store. Not sure what you will be putting in the flask but if you are looking to purchase on line, then check out Fisher Scientific. Enter the search term flask stopper and a whole gaggle of selections come up for you to click on drill down and read the type you want. They have glass, rubber, silicone and all kinds of stoppers.
Feb 13, 2011 | Vacuums
The brake lights wont shut off when i turn off the car. i have a pack of rubber stopper to replace the missing stopper which i found crumbled up on the floor but i dont know where the hole is to put the...
weird but try this. at the top of you brake pedal you see a switch that the brake pedal touches when in the unpressed position see if that stopper you are talking about mounts on the pedal arm .
Apr 25, 2010 | Hyundai Motor 1999 Tiburon
Direct push-type Kohler bath drain won't drain.
Spring loaded chrome stopper will not stay down to fill tub with water.
Jan 12, 2010 | Kohler Plumbing
Slow water drain from Royal whirlpool tub. How to
under the decorative knob there is a screw,this is what holds the stopper in place.if not it should just unscrew.
Jul 29, 2009 | Home
Bathroom sink stopper came unhooked and out, not attached anymore
You will need to get under there and unscrew the popup rod located on the back of the drain. pull out the rod, drop the stopper in there and push the rod through the hole in the bottom of the stopper. screw the nut back on.
Mar 15, 2009 | Home
Woolpool Duet Washer fast clicking
If it does not start the clicking noise is coming from the water distribution lever on top of the soap dispenser assembly. Take the top off. On the left hand side you will see a teardrop shaped piece of plastic with an arm attached at one end an a motor attached to the other. There is a stopper that is supposed to stop it from going too far and it has likely jumped over the stopper. Gently remove the arm from the teardrop and reposition it over the stopper then reattach arm.
Feb 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
American standard bath drain problem
The stoper assembly has linkage and a plumb bob aparatus
Step 1 remove the 2 screws that hold the chrome overflow cover,
Step 2 you will see a wire connected to the up and sown handle
Step 3 you should be able to fish out the linkage which will have a bumb bob attached
mae sure this is all connected if not reattach if you do not see the blumb bob reach your fingers in and grab the wire
Step 4 inspect the linkage the first link is about 3 inches from chrome cove, second is about 8 inches down and final is at the bob itself bob is pointed and slides in by gravity
If this all looks ok then fish it down , put chrome cover on and move lever up and down ( you should see the stopper mve up and down
Step 5 If stopper is not in just insrt in drain hole and move the lver flow lever up and down and drain should work sometimes the stoper does not go up or down far enough there could be an adjustment on the linkage to reduce or increase the length of the linkage
Good Luck
Dec 28, 2008 | American Standard Evolution 1599.205.020...
Toto LPT972.8-01 Guinevere Pedestal Lavatory Sink with 8" Centers - Cotton Logo
125 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
