Question about Exercise & Fitness
Jazfit 66a treadmill squeaking when running. does it need oil to lubricate ? and where do you oil it?
  • 40 Answers
SOURCE: what oil do you use to lubricate the parts on a
100% silicone, no petrolium.
Posted on Nov 01, 2009
SOURCE: with every step I get squeak / chirp while running on treadmill.
Check the knob used to hold it up in the folded position. While running, have someone pull it to the out position. That was the problem on mine. If it is, a little grease on the end of the rod should do it.
Posted on Nov 05, 2009
  • 15 Answers
SOURCE: Where can I purchase a teflon spray lubricant for treadmill?
Tunturi.com or accellfitnessna.com should have the lubricant you need. Order it online and they should be able to ship it directly to your house. I service tunturi treadmills, although I haven't come across a teflon lubricated machine, it is very important with these machines you stick with the manufacturer specified lubricants.
Posted on May 27, 2010
SOURCE: How do I oil my Reebok i-run treadmill?
I have a problem with my reebok i walk i run treadmill. The belt does not move on the lower speeds and after using it there is a burning smell even though it is working fine once I get past the first two speeds. I have had it 2 years but have never oiled it as I am not sure how and where.
Posted on Sep 24, 2010
SOURCE: horizon treadmill won't start running
power going to treadmill. it is beeping the whole time but wont start or move
Posted on Jun 14, 2011
Treadmill squeaks when running
have you lubricated under the running belt ?
Dec 31, 2014 | Sole Fitness F63 Treadmill
How do I lubricate the c 1800s nordictrack
the only lubrication that needs done is between the walking belt and the deck. if a roller is squeaking either front or rear you can try using wd40 on the bearings on either side
Oct 21, 2014 | Nordic Track Nordictrack C 1800s Treadmill...
Incline and decline wont move, so the belt wont move either. Have a jazfit treadmill
1)LUBE THE DECK BELT, INMEDIATELY.
2) tES THE MOTOR INPUT VOLTAGE, IF THER ARE THE MOTOR NEED REPAIR.
3) tEST THE OUTPUT VOLTAGE BOARD, FOR INPUT VOLTAGE MOTOR, IF THERE ARE NOT THE BOARD IS FAULTY.
4) tRY TO RUN THE SOFTWARE CALIBRITATION.
SINCERELY.GOD BLESS YOU
May 08, 2012 | Exercise & Fitness
Squeek in motor of 6110p treadmill
Dear Sir:
The motor you can be oiled . But see the next instruction.
RUN THE SOFTWARE CALIBRATION FOR Easy diagnose and troubleshooting , see the instruction under the Hood of Motor, and follow the step or user manuals. Inspect the 1) Potentiometer + gear of the same Pot ( lubricate very slight).
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Feb 13, 2012 | Schwinn Exercise & Fitness
Loud squeaking on my Reebok 9500 ES (three years old) from under the hood when the foot hits the treadmills - at various speeds and inclines.
HI,
Its time to lubricate your treadmill.
You must obtain the proper lubricant for your treadmill. There are several different types. Contact your manufacturer for what type is needed. Using the manufacturer provided allen wrench, loosen the walking belt approximately 10 full turns on each side of the rear roller. Apply approximately 1/2 ounce of lubricant directly in the middle of the walk area underneath the walking belt upon the deck. Retighten the rear roller 10 turns on each side. Run the treadmill at 6.0 mph for 2-3 minutes to spread the lubricant evenly. Wipe excess lube from the sides of the belt. Walk on treadmill to check for proper tension on belt.
for make it easy for you I have added a video. ok
Aug 27, 2011 | Reebok Exercise & Fitness
Need to oil
No, you don't need to oil or lube this treadmill. If the belt is squeaking get a bottle of treadmill lubricant and apply a small amount.
If the arms are squeaking a small shot of silicone spray will quiet them down.
Jan 06, 2011 | Proform CrossTrainer Treadmill
Squeaking noise from tread
usually when a treadmill begins to make a squeaking sound it means that the belt needs to be lubricated. Try Treadmill Belt Lubricant available at Canadian Tire for $10.99 and is good for Reebok treadmills.
Aug 06, 2010 | Reebok Exercise & Fitness
Making a squeaking noise from the tread
Usually when a treadmill begins to make a squeaking sound from the tread it means that the belt needs lubrication. Try Treadmill Belt Lubricant available at Canadian Tire for $10,99.
Aug 06, 2010 | Sport & Outdoor - Others
Treadmill squeaks
There's a special silicone-based treadmill lubricant that you put between the belt and rollers See this treadmill accessory kit
Jun 24, 2010 | Proform CrossWalk TreadSoft Treadmill
How do i lubricant my treadmill
it is an indicator that the belt needs lubricating. turn the power off, and lift up one side of the belt and spray a small amount of lubricant underneath the belt, onto the running board. repeat this step on the other side. turn the treadmill on and run it for a few minutes to spread the lubricant. the oil light should now go off.
this should be repeated every 5-6 months to keep the board lubricated and to reduce friction between the belt and board and will lengthen the life of your treadmill.
Dec 19, 2009 | Reebok New York Giants Eli Manning Jersey
Exercise & Fitness Logo
173 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
