Question about Microwave Ovens
It makes ice but the gride it falls on is not comming on (heating) to cut the slab of ice. How do i check to see if its good? And when does it come on? what triggers it to heat up? the power looks like it comes from the transformer but im only getting like 5 volt on my meter. ghost voltage? shows good continuity across the grid, so its not broke. Thanks
  • 2 more comments
  • pool_player4 Feb 06, 2010
    I have a KitchenAid ice maker that is not cutting the ice on the wire grid. It appears that its not heating up. I checked continuity and thats good but still not comming on? Where does it get its power from, the transformer? what kina power supply should i be getting? and what is the sequence of operation? When does the power come on and how long? Can i check it by using my meter on the supply probe/connection? Model number kuia18nnjs4 serial number ep5021676
  • pool_player4 Feb 07, 2010
    My kitchenAid ice machine model # is kuia18nnjs4 serial # ep5021676. Where is the thermostate located?
    model # kuia18nnjs4 serial #ep5021676
    it ejects a solid sheet of ice and then the heater cuts the cubes but it doesnt get hot?hw can i check the heater? and is it worth replacing?
  • 619 Answers
The heater never gets hot but should always be warm to the touch. Remove the screws 1 on each side of the heater shield and then there should be 2 thumb screws at the back area of the heater. Slide the heater forward and disconnect. Check for broken heater cable by viewing and by ohm scale on any ohm setting. Should read continuity since this is solid wire. If broken replace with resrting kit.
Posted on Feb 07, 2010
    Novelist:
  • 101 Answers
Dear Pool Player4,
This posted as "Generic problem for all microwave Ovens" It sounds like you are having issues with a clear ice maker. If you can tell me the brand, model (and possibly the serial number) I will do my best to help you. If it is a Marvel or Viking, the the transformer getts power from the control board when it goes into harvest and stays powered for 35 minutes after returning to production mode. the control board makes the decision to go into harvest/production based on evaporator plate temperature as sensed by a thermistor located on the botton of the evaporator plate. The transformer receives 120v AC and puts out 12 volts AC. And yes, if the board is not trying to power the transformer wou will see a potential with a meter but no significant current to power the grid.
If this is a different brand I will have to do some research and get back to you.
Posted on Feb 10, 2010
  • 311 Answers
If this is a whirlpool icemaker then you can remove the front cover of the ice maker and place a jumper wire from T to H on the module for about 15 seconds (you will hear a click when the thermostat is bypassed). You can then remove the jumper wire and the unit should cycle by itself. This will bypass the thermostat and the unit will jump directly into a harvest mode. If it ejects the cubes then you have a bad thermostat in the ice maker. Of it as soon as you remove the jumper wire the rake stops turning then you also have a bad ice maker. Either way if you have cubes stuck you will be better off just replacing the unit rather than trying to piece it out. Its nearly the same cost and 1/4 of the time to swap the unit. You will just want to make sure you are getting 120v to the unit.
The only other thing I would check is to make sure your lever arm did not pop out of position.
Next time if you could post your make and model number it would make the diagnostics and component testing much more specific I can look up your model number and advise you directly on your specific unit. This is why most experts will tend to shy away from these type of generic questions because there are many possibilities.
Good luck hope this helps _MJ_
  • Microwave Ovens Master
  • 19,396 Answers
There is surely a thermostat that will cutoff when temperature is reached.
To test the thermostat, disconnect power, and read impedance on the thermostat after disconnecting its contacts. If it reads low or zero impedance, and not infinity, then the thermostat is good. If the thermostat is open at room , then it is faulty.
I can be more specific if you provide full model number.
Posted on Feb 04, 2010
    President:
  • 1,218 Answers
Good day,
I see it's posted in microwave ovens but you have to be talking about an ice machine.
To the best of my knowledge you should have approx. 9 volts to the grid. It's low voltage since it's exposed.
It is on all the time.
Ghost voltage ??? sounds possible since the 5 volts doesn't ring a bell with me.
The grid assembly's do go bad. Could be the wires or simply a lot of corrosion. Also check the plug carefully.
But I'd start with the voltage supply. If it's a commercial unit, most refrigeration supply houses can supply the correct info for you.
How everything works but does not heat?
There are some good tips on this website
http://www.ask.com/question/my-ge-microwave-runs-but-does-not-heat
Could be the thermal cut-off relay has tripped, thermostat is faulty or very remote chance the microwave generator itself is faulty. Will need the model number to make any further assessment of repair.
May 01, 2014 | General Electric Microwave Oven
I woke up this morning to my refrigerator humming and not working. It is 5 years old. The freezer seems to be just fine. Help! It is stainless steal model PFSS5NFWASS
Top of Form
If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge. If there is no ice formation we have a big issue as the compressor and gas must be checked out. If compressor is running check the pressure, get help to test gas pressure. If not you will need to fill up ,If gas pressure is good the possibility of the compressor being inefficient is high. In such a case you must take consensus to estimate and decide, if RPM of motor is low check capacitor.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test from the outside and make your observations so that we come to the solution.
Jun 13, 2011 | Microwave Ovens
Please could I have Ice cream recipes Thank you thank you
Ingredients:
5 egg yolks,
1 pint (500ml) milk,
1/2 pint (250ml) double/heavy cream,
2 oz (50g) sugar,
150g (6 oz) milk chocolate cut into small squares
Create a custard base and at the point where you remove the saucepan from the heat, carefully drop in the squares of real chocolate. Stir to allow to melt and then leave the custard to cool. Then chill the custard until it's really cold. Once chilled, mix until slushy. Add the cream (whipped) and make sure it mixes in well. Transfer the mixture in an ice cream maker and freeze according to the manufacturer's instructions.
Instead of using wafers, you can make your own chocolate chip cookies- they make great ice cream sandwiches.
Thank u and if u want more recipes contact me . (^ _^)
Apr 29, 2011 | Microwave Ovens
My GE Monogram ZDIS15CSS ice maker fills the bin with water but does not pump water over the plate to produce ice. We did drain and shut unit down for 2 weeks and it would not start on our return. Can...
I would check the ice level sensor... it is shown on page 9 of this manual...
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-60440.pdf
If the sensor thinks that the bin is full it will not do anything...
That is why that would be my first area of interest..
heatman101
Mar 24, 2011 | Microwave Ovens
At 17 minutes bread rises well but the bread is not done because the edges are only a little brown, but at 20 minutes the bread always falls!
Check the manual of your oven (ESPECIALLY FOR BREAD MAKING) you probably do not have the correct programming, when the bread FALLS it means that the heat (microwave) kick's in too abruptly (NOT LIKE IN AN CONVENTIONAL OVEN) graduated...
I'm not an expert just a suggestion...
Jan 18, 2011 | Microwave Ovens
My Panasonic refrigerator NR-B420T is not cooling, however the freezer part still cooling.
Top of Form
Since there is cooling on the freezer the fault can be the defrost timer. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Jan 05, 2011 | Panasonic Microwave Ovens
Not making ice. water is getting to the water dispenser but don't know why it is not getting to the ice maker itself. how do i check it/repair it.
Hia and wl;ecome to FixYa, I am Kelly.
We really need a make and model number to provide you with specific unit applicable information but.... in general, here goes:
1. Ice makers must have a freezer temp below 16 Deg F. If there is an airflow problem in the freezer caused by a fan or ice build up the ice maker will no longer make ice.
2. The ice maker has a thermostat that controls the harvest and fill cycle. If the thermostat fails it will stop making ice.
3. There is a water valve in the back of the unit that has TWO electric solenoids on it. One for water in door and one for ice. If a solenoid fails it will stop providing water to the applicable function. I.e water in door or ice. You can briefly remove the fiberboard back cover to gain access to the water valve. Then switch the installed terminal connection between solenoids. Left to right or front to back depending on how it is mounted. Then try the water in door. If water flows to the ice maker when water in door switch is actuated then the solenoid for making ice is good and the probem is with the icemaker. (Reconect wires in original positions.)
Note that anytime you remove power from the unit you must wait 10 - 15 mintues before re-applying power so the coolant system can stabilze. Other wise the compressor will not start.
Here is a web link that will help most people troubleshoot ice maker problems:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
The link above is pretty good.
There is a 48 page job aid also for whirlpool in door ice that is also a big help:
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
This should help you find out why it is not making ice.
Thanks for choosing FixYa,
Kelly
Oct 26, 2010 | Microwave Ovens
I have a CEM Global PS78121 ice maker that has quit making ice after one month of use. I don't have a manual to trouble shoot it and need help. The compressor won't keep running to freeze the ice. Then if...
The problem is that the tabs on your white plastic tray with the ice falls into our broken off. I have the same problem. I am looking for a source to buy the new ice tray. If you have any knowledge of where to get parts for this piece of junk please let me know.
Aug 31, 2010 | Microwave Ovens
After electricity cut not heating food Dimention4 C703BPPQ
When a microwave works normally but just doesn't heat, then this is a faulty magnetron. A replacement can be purchased at repairclinic.com or partselect.com which shows a picture of the magnetron, how to replace it and option to purchase it as well.
If the microwave is not getting power, then first remove the outside shell, then check the glass bus fuse. Make sure the thin wire inside the glass fuse reaches all the way across the fuse and is not broken. If fuse looks good, but still no power, Use a voltmeter and check the power from the power supply to the main circuitry board and make sure it is getting the correct amount of power. There is usually a label on the microwave that tells the DC voltage output.
Jan 18, 2010 | Microwave Ovens
My refrigerator stopped working and will not come back on. It is a Jenn-Air Side by side purchased 4 years ago.
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 24, 2009 | Microwave Ovens
Microwave Ovens Logo
65 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
