Question about Asko Washing Machines
Asko frontload quit spinning - Asko Washing Machines
  • 129 Answers
Check water pump,clean out call asko tech line may be motor or control board both expense
Posted on Feb 04, 2010
I have an asko w600 front load washer, seems to wash ok, but will not go into spin cycle, drain pump operates - slowly, but does not start spin cycle. saw somewhere on net that pump may be faulty
Hello Greg, welcome to FixYa.
To address your post of the washer not spinning and your curiosity of a faulty pump...the pump may simply be obstructed preventing a proper drain, thus a compromised spin, they are directly related. These frontloaders will not spin until they drain sufficiently. (though a faulty drain pump is possible, it woud be the exception, not the rule).
There is typically a drain filter in the pump as you may or may not know, based on your description it may be clogged. You'll need to access it, clean it out via draining it through the pump "emergency drain hose" before you can in the end open the door (though usually once drained to a safe level it will open under normal procedures) however there should be a door lock release on Asko built machines...including the W600 series.
This is the procedure for machines of the past 10yrs. or so...(this is only an example, it may not be exact but essentially the same as yours)
Hopefully this will help. Let me know if anything is unclear or If I can assist you going forward. Thank you for choosing FixYa and good luck going forward.
Regards,
Macmarkus :)
Nov 21, 2011 | Asko W600
Hi, I have the ASKO W6222 front load washer, my
if the valve was stuck open it would run all the time the washer was on i would say that there is a power short running to the valve turning it on when not selected
sonic boom electronics australia
Jan 04, 2011 | Asko W6222 Top Load Washer
My asko frontloader won't fully drain and I cannot get the whit plastic cap off the drain to see if the hoses or filter is clogged. The top piece pulls off but not the underlying piece. any ideas? Isn't...
yes you need to get the filter out it will be full of coins etc.you will have to break it to get it out.you can get a replacement pintrap from asko
Jun 02, 2010 | Asko Washing Machines
My asko frontloader squeeks when the drum turns
It may be the seal needs to be greased (waterproof grease) where the drum shaft goes into the support bearings in the outer drum case--major tear-down! Check the front bearing for looseness or roughness while you are there. Make sure the motor drive belt is not causing the squeak first. Good luck!
Dec 16, 2009 | Asko W660
Electric door release stopped working
does it not have a manual door release pull next to the filter
Aug 05, 2009 | Asko W600
My Asko W620 washer won't spin the first time through.
Try Googling (asko)(W620)(manual) without parens.
Jul 22, 2017 | Asko W620
Repair front load washer
wash machine not draining properly at end of wash. not fully spinning.
pls advise
Sep 11, 2008 | Washing Machines
Asko Frontload wont stop running water
you need a new inlet valve take off the top panel then you see the inlet valve follow the inlet hose
Mar 17, 2008 | Asko W6441 Front Load Washer
Washing Machines Logo
106 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
