Question about Oreck XL2000 Bagged Upright Vacuum
The motor has a large electrical arch and burns when it is turned on. Is there anything I can do to fix this?
  • 4 Answers
Usually there is some dirt that has gotten into the motor compartment and is making the brushes arc. You can make sure your vacuum is unplugged and lay it on it's back so you can see the bottom part of the vacuum where the roller is. There are about six screws in the bottom that need to come out. They are all the same length so you don't need to keep track of where they came from. When the screw are out the bottom will easily separate from the top. Now you can get a better look at what is going on and clean out the sand etc. If there is a lot of dust and dirt than your fan housing is probably worn out and may even have holes in it. If cleaning it out doesn't help than it requires more service than you can probably do and usually it costs too much to fix it unless you are really attached to the machine.
Posted on Mar 26, 2010
How do i fix dyson DC41 Animal vacuum upright cleaner it has burning smell coming from motor and it blew the fuse box when i WENT TO VACUUM. the wire flex is a bit over twisted
You most certainly shorted this out and will need a new cord. Easy fix but you will have to take it apart and find where it failed. I doubt the motor fried but it is possible. When you take it apart look for the burn mark left by the electrical arc. That is the point you fix.
Dec 26, 2015 | Dyson DC41 Animal Bagless Upright Vacuum...
I brought a shark need to know if i can get it fix motor making loud buzzing noise it should be still under warrnty
Motor is jammed or burnt out,is there a burning electrical smell?,if there is,and the belt on the motor turns freely by hand , then the motor is burnt out.
Jan 11, 2015 | Shark Navigator Bagless Upright Vacuum
Beater bar motor quit, now the main motor quit. Replaced the on/off switch. still nothing
see this causes and fix it. God bless you
If the vacuum cleaner motor doesn't run the on - off switch might be turned off or defective. Test the switch with an Ohm meter or continuity checker.
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced.
Sep 27, 2012 | Vacuums
Bagged upright panasonic vacuum cleaner motor wavering & smelly
The motor is failing and this causes it to run very hot due to electrical arching, replace the motor.
Apr 05, 2012 | Vacuums
I purchased a Eureka C4910 last year and have a question that I am hoping you can answer. There are two motor actions with this vacuum, 1) the vacuum suction, and 2) the beater bar. The action of the...
Good day!
Normally when the motor is easily moved back and forth means that it have a proper lubrication,proper alignment and no clogs.
When the motor and the belt is OK the problem could be on electrical wiring and switch.
If found electrical switch burned out you need to replaced it because when the switch is burn the contact of that switch is open even you turn it ON.that's why the motor is not function because the voltage is not pass through the circuit because of open switch.You need to replaced it.
And check some fuses if any and other burned electrical wire.Replaced it also.
Thank you and don't forget to rate my answer.
May 28, 2011 | Eureka C4910 Bagged Upright Vacuum
The motor in the Kenmore canister started smelling like wire burning and then made terrible noise. I ordered the exact replacement motor and swapped them. Installed the same way the original came out, ran...
Actually there not supposed to burn up. I have read some reviews on that model Kenmore and it seems it is plagued by electrical problems.
I would definitely contact Sears customer service.
Sorry I couldn't be of more help.
Handie Andie
Mar 30, 2011 | Kenmore 25512/ 25513 Progressive Canister...
I have Hoover Widepath Bagless 12 Amp Windtunnel vacuum. Yesterday I was vacuuming and smelled smoke and it shut itself off. Today I cleaned out the filters (they weren't bad) made sure nothing was...
Hi There,
When a vacuum cleaner smokes, it is usually only one of two possible problems.
It could either be that your motor burned up, or that your belts burned. The belts on this particular model are notorious for breaking, but the fact that your machine doesn't come on at all after this happened, sounds like it may be the motor.
Both of these issues have a unique smelling smoke. If the smoke smelled like an electrical burning smell, this indicates it's your motor. If the smoke smelled more like burning rubber, then it's probably your belts.
If the smoke smelled like burning rubber, here's a video that we've recorded showing step by step how to inspect, trouble shoot, and replace the belts on your vacuum cleaner. If you open it up and the belts are still in tact, then this probably is a more serious problem of the motor burning out.
. I'd be more then happy to walk you through more advanced diagnosing if this doesn't fix your problem, please just use the comment box here on the Fixya repair page.
If this was helpful to you, please be so kind and rate my repair helpful, or leave some feedback for me. This is really appreciated by the Fixya community if the repair solution was able to fix your problem.
Thanks again,
Chris Jones
GoVacuum.com
Jun 14, 2010 | Hoover Self-Propelled WindTunnel Bagless...
My Model 2961 Eureka wont take power now?
Anytime that you smell that electrical burning smell on a vacuum cleaner, this is the motor going bad. There are two distinctive burning smells in fixing vacuum cleaners, the electrical burning smell which is the motor, and a rubber burning smell which is the belt.
The bagless vacuums cleaners in general, their motors last usually no more then 3-5 years. The motor in bagless vacuums work much harder then the motors in their bagged counterparts.
The motors in Eureka vacuums can range in price from $70-$120. If you can provide me with the exact model number on your vacuum cleaner (can be found on the bottom or the back of the machine on the sticker that also contains the serial number) I will be able to get you the part number, and price of the motor that's used in your vacuum.
It may be worth considering to just get a new vacuum cleaner at this point. If you'd like me to give you a personalized recommendation specifically for your unique cleaning needs, I'd be honored to do so. Please just let me know what types of floors you have mostly in the home and I'll be happy to share my knowledge of vacuum cleaners.
I hope this was helpful to you. If you found this helpful, please be sure to rate the repair helpful so other Fixya users that have this same problem can easily find the answer.
Thanks so much,
Chris J.
GoVacuum.com
Apr 11, 2010 | Eureka 2961AVZ Bagless Upright Vacuum
Vacuum smells like rubber burning. Replaced belt. same result
My vacuum's belt fell off, So I fixed it. Two days later my vacuum wouldn't turn on, so I opened it up again and took out a dust ball in between the electrical wires. I turned it on and sparks and snapping sounds came form the motor. Also burning rubber smell, What wrong? Is my vacuum fixable?, or should I buy a new vacuum?
Jan 15, 2010 | Oreck XL2000 Bagged Upright Vacuum
Won't turn on
If there was a smell like something plastic burning it may be that something just actually burned. It does not have to smoke like a chimney (sometimes it does though - depends what is burning)... If there were no strange noises and it did not seem to run any different than usually - most likely the motor is still fine. I would inspect the cord really carefully but to do any more than that you would have to open the unit and inspect everything else.
If you chose to do so – open the Rainbow and hook up the motor directly to a power supply (hold on to the unit as it will move while starting) – if it runs then problem is in wiring. Test the cord with a tester or bulb, then the switch (or 2 switches if this is e-series Rainbow). Make sure all wires are intact. There is not much to test so you will get it done and find the problem quick.
This is messing with electricity and subjecting you fingers to potential hazard by exposing working motor so do it at your own risk and be very careful and if anything goes wrong do not blame me :-)
Aug 31, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Oreck XL2000 Bagged Upright Vacuum Logo
64 people viewed this question
Top Oreck Vacuums Experts
xalint1
xalint1
Kory Ronning
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
