Question about Dayton Heating & Cooling
I need a temp setting switch for my 2 mounth old electric garage heater. Where can I buy one?
The thermostat must have cost 2 cents. I replaced it with one from electric baseboard, real nice piece. Dayton should do the same.
Posted on Feb 08, 2010
Adjusting Apollo hot water tank
I am not sure what you are asking, But i am going to assume that you want to know about changing the Temp on the heater for inside the house.
If the floor heat was installed properly than it should have a temperture manifold or adjustable thermostat for seperate heating.
You need to find the thermostat or manifold for the garage heat and set it at what ever temp you want the garage to stay at.
Then you can change the A B C knob to a higher setting A is cold B is warm ac is hot. So Increase your temp setting on the heater and this will increase your house water temp for hotter showers and faucet temps. However, they recommend not setting the temp above 120 degrees to prevent severe burns.
If you have a newer home increasing the Hot water heater temp setting may not change the temp at the shower or faucets if you have scald guard faucets installed in the house. This will require adjusting the scald guard valves on each faucet.
I recommend using a candy thermometer or digital thermometer to check the faucet and shower Temp prior to using them and make sure that you inform everyone in the house after you change the temp so that no one gets scalded.
I hope this answers you question, feel free to contact me if you need more help!
DR Wilkins
Oct 15, 2013 | Water Heaters
Goodman ac/heater drain pan leaking since instillation 3 years
sounds like the unit needs to be elevated and leveled.
Aug 10, 2012 | Goodman Heating & Cooling
Fer211as heats but wont dry! heating element comes on but kicks off after gets to temp then element will not come back on unless stopped and restarted?
Runs but will not heat
1.loose wiring--check terminals & wiring
2. Defective thermostat--replace thermostat
3.defective centrifugal switch in motor--replace switch (check linkage to motor)
4. Defective timer--replace timer
5. Open heater element---replace heater element
6. Heat switch set to off----set switch for desired heat
Sep 22, 2011 | Frigidaire FER211A Electric Dryer
I have a two wire thermostat system. I switched the thermostat from a mercury one to the Honeywell CT3200 with dip switches set for my electric forced air furnace that is 31 years old. The white wire is...
If you look closely at the installation manual page 6&7 it tells you settings to use for your type of system. If I'm not mistaken you will need to back out screw "b" 360°. Hope this helps!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 17, 2017 | Honeywell CT3200 5-2 Day Electronic...
Mortor berrings
Grainger had a wide variety of bearings ... usually, they have a price spread for bearings depending on the quality of the bearing. I just ordered a $10.00 bearing for my $50.00 sander. They offered the same size bearing from another manaufacturer for $75.00. I didnt buy that one.
Good luck with your repair.
Mar 03, 2010 | Heating & Cooling
When I first turn my rf45 on in the morning,It fires fine and the blower takes to long to start.I think it times out then the blower will come on.After that is works fine. This bother me because the HE...
You need to find the fan switch and replace it. This switch closes the fan circuit when it gets to a pre-set temperature and allows the fan to come on. It looks like a small silver or black disc, usually about 1" in diameter and about 1/2 " thick. It should be mounted in a hole with 2 screws and is on the panel that separates the controls from the heat exchanger. It will have 2 wires going to it. There will be 2 discs that look similar, one is for the fan and the other is a hi-limit switch.Make sure you replace the right one. The fan switch is rated to close at a specific temp and open at a specific temp. The easiest way to get the right one is to take it with you to a dealer. Hope I was of help to you! Good luck!
Nov 28, 2009 | Sterling RF30 Natural Gas Garage Heater
GOODMAN GMS9 limit switch
check the temp on the switch.Any switch will work as long as it has the same temp setting.
Oct 30, 2009 | Goodman GMS90703BXA Heater
Looing 2 buy!!
This is a good application of this type of heater. There are many things to consider as you size the heater though. Insulation, 1,2,3-car garage, insulated garage door, average ambient temp. etc. In most cases of garage heaters, they are used to temper the air from cold to a workable temperature. If this is the case, I'm sure this would take care of most applications of garage heating.
Oct 02, 2009 | Dayton G73 Utility Heater
Electric furnace/heater pump/fan unit won't shut off
There are dip switches on the main board.. When you remove the lower panel on the air handler there are instructions to where the dip switches should be for your units fan control. if the switches are in the correct configuration.. The Thermostat may be malfunctioning or not wired properly. and last.. and most expensive.. the motherboard may also be failing.
Jan 09, 2009 | Heating & Cooling
Heating & Cooling Logo
99 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Tim Whalen
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
