Question about Whirlpool Duet GHW9150P Front Load Washer
Water coming out of the botton during spin cycle
Take the bottom panel off the waher, put water in the machine, and watch to see where it is leaking. If you don't see a leak during the regular cycle, put the machine in drain and spin mode, and watch for leaks there. You should find your leak during one of these cycles so you will know what part you need.
Posted on Feb 03, 2010
Ge toploadwasher that does not get water out of clothes after final spin
Could be that the spin cycle is not rotating at the required speed to wring out your clothes. Check that the cycle completes at a significant speed to generate centripetal acceleration forcing out the water. Perhaps the load is unbalanced which can trigger the spinning cycle to repeatedly stop during the spin cycle.
Jan 31, 2015 | GE Washing Machines
A knocking noise during agitation wash cycle
could be a bad counter balance , u can remove the front panel and run a spin or wash cycle and listen to where its coming from so u don't have to replace all the balancers. on some models theres a heavy ceramic weight at bottom that at times goes bad and throws it off balance, just run it and look where noise is coming from
Jul 25, 2014 | Maytag Performa PAV2200
Washer is leaking during rinse/spin cycle
What is the model number of your unit?
Nov 23, 2012 | Washing Machines
My mastermind 708 dosen't spin after wash cycle.It spins fine in the wash cycle but dosen't drain water or spin in the spin cycle.Pease help
Your empty pump filter is blocked with debris. If it can't evacuate all the water then it wont allow the spin cycle to start. Locate the filter (probably behind a little door at the botton of the front of the machine). Remove, clean and remove the debris, re-fit and all will be well
Jul 01, 2011 | Westinghouse Washing Machines
The water runs during the spin cycle. The clothes
Does the water run through the ENTIRE spin cycle? There is a period where the water will run during the spin; This is called, the "Final Rinse". But it usually only runs for about 10 seconds then stops.
Dec 22, 2009 | Washing Machines
Soap stays on botton of dishwasher
Either:
  1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, if you don't see any water at least once - check water valve, water level float and water pressure.
  2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
  3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Jul 13, 2009 | GE Nautilus 24" Built-in Dishwasher
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Water runs during spin cycle
I would suspect that you timer is shot, only during spin? During the day when water use is high does it leak then?
Sep 07, 2008 | Kenmore 24032\24036 Top Load Washer
Sounds like a loose screw/bolt/nut during the spin cycle
There is nothing wrong with your machine. Don'f bother with the sound , You said you threw 2 pair of jeans, so its bottons are causing the sound against the drum during cycle. Finished your laundry and worry no more. To make sure, throw some another clothing asides form jeans, like shirts, and feel the normal silent of your machine.
Good Luck,
Eriez
Jun 05, 2008 | Maytag Neptune MAH5500B Front Load Washer
Amana Washmachine (not all water removed during spin) ALW780QAW
you may have blockage in the drain pipe several feet from washer. if you can run spin cycle with hose in different location ex. tub,sink or outdoors. if this works run long snake down washer drain pipe to clean gypsum residual.
Jan 28, 2008 | Amana ALW780QA
Whirlpool Duet GHW9150P Front Load Washer Logo
603 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
