Question about Danby DWC283BLS Wine Cooler
Compressor is very hot to the touch and hums. The temperatures in the unit are much lower than the setting temperature
  • 52 Answers
Could be a defective thermostat, or you could have placed your cooler in a area without adequate ventilation.
Posted on Feb 04, 2010
Should my refigerator compressor be hot to the touch?
Hello friend, thanks for the post!
Based off the information you have provided your compressor can be hot to the touch because it is working to help cool down your refrigerator. I would allow it the opportunity to maintain proper temperature inside of your appliance before it stops running. I hope this is helpful. -Matt
Sep 23, 2014 | Frigidaire Refrigerators
Why is Unit not cooling?
Good Morning Friend,
I understand your Frigidaire air conditioner, model# FAS296R2A, is not cooling. I also see that, both the filter and condenser are clean. First, try setting the temperature lower. Secondly, the compressor could have shut off by changing modes. Set to the "COOL" setting and wait about 3 minutes for the compressor to restart. Lastly, check the temperature sensing element, located behind the air filter, to make sure it is not touching a cold coil. If it is, straighten the sensor away from the coil. I hope this is helpful.
-Best Regards-
WP
Jun 21, 2014 | Frigidaire FAS296R2A Air Conditioner
Frigidaire freezer compressor is hot to the touch and not cold inside
If the compressor is hot, then the temperature inside the unit may be compromised if there is a sealed system issue or a restriction in the unit. Call a professional to be safe.
Jul 26, 2012 | Frigidaire 14.1 cu. ft. Upright Freezer...
Current setting too hot
Hi, If your temperature setting is hot, just adjust it to lower temperature by using your remote commander. Unless you have problem with compressor, refrigerant, motor and controller, you should able set your temperature to meet your comfort. A small split type air conditioner commonly will able set the temperature from 16 - 30 deg. C.
Dec 16, 2010 | Heating & Cooling
This unit was purchased new 61 months ago. First instance of any problems, ever, today it seems food isn't being kept frozen solid. We suspect the compressor is having a problem. There was no sound...
Yes it is a very big concern.It sounds to me like your condenser is dirty and the compressor gets hot and goes off on overload.You can tell by putting your hand NEAR the compressor.Be careful as the compressor can be very hot
Sep 14, 2010 | Frigidaire Freezers
Compressor not turning on
check thermal protector on the compressor itself if that is not it then try the run start compasitor thats the silver tube shaped object that should do the trick
May 20, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Sears Kenmore Upright freezer is Making a loud humming sound
change the rubber washers on the compressor should work a treat...
Feb 05, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Fridge is running but the fridge and freeze are about room temperature and not getting any colder after running for about 48 hours after it was noticed that the unit spontaneously stopped cooling and all...
compressor has given up the ghost sounds as if the compressor has quit on you. Only way to tell is to pull the unit out from the wall plug the unit in and listen for a hum in the lower section of the fridge if it hums the clicks off or no hum at all compressor is bad
Jul 15, 2009 | Refrigerators
Humming sound unit does not cool
sounds like abad compressor, when it heats up its overheating and shutting off,i would check if the fan behind, next tot he compressor is blowing, and the lower coils are not cloggged
Jan 25, 2009 | Frigidaire Refrigerators
Whirlpool Side by Side Refridgerator
If the mullion heater around the doors is hot to the touch the inside temperatures are not being maintained. They should be warm but not hot. This usually indicates a problem in the internal temperatures. Check the back wall of the freezer section for frost buildup. Your defrost system may not be working and it had not gotten to the point of complete failure as far as you noticing the temperature differences yet.
Jun 15, 2008 | Whirlpool ED2FHSS Side by Side...
Danby DWC283BLS Wine Cooler Logo
385 people viewed this question
Top Danby Furniture Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Dennis Boxerman
Are you a Danby Furniture Expert? Answer questions, earn points and help others
