Question about Hobart A200 Stand Mixer
Hobart A200T General Info / Back cover plate gasket
Just got a used A200T.
From the back plate:
SN 11-370-758
ML 33425
1/2 Hp 60 Hz
And with the switch plate off, inside the case, Motor info:
60-115 1
ML 17273A
SN B894232
1) I understand the Hp and Hz, and I'm guessing the 60 115 1 is 60Hz, 115 volts, single phase, but is there anything else encoded in the model/serial numbers? Is there someplace to look them up? I can't find a SN list for these machines anywhere. It would be nice at least to know what year this thing was made.
2) If I can locate a service manual, what years would apply to this mixer - have there been any big changes, so that a manual from, say, 1995, wouldn't cover my mixer, but some other range of years would?
3) I took the back cover plate off to replace the screws. One of the heads was sheared off, and the plate was bent. According to the parts manual, there should be a gasket. What I had was a thin piece of old paper. How thick is that gasket supposed to be? If I put the cover back on tight, it seems to hold the spacer/bearings/shaft too far forward, and the machine sounds rough. Not quite grinding, but rough. If I stand the cover plate off with a couple of thin washers, it sound smooth again. Is that normal?
That's all for now
Thanks for your help, and thanks for the website.
  • 640 Answers
I'm a service tech for hobart,I'll type your serial number into our database and see what it brings up.The changes that have been made---older units use a mechanical start switch on the motor,the new units use an electronic start switch.the old units center shaft and gears have changed.the older units dont have bowl guards and the new units do.(this is a cage that goes around the bowl).The gasket that your talking about is just that--a thin paper.The paper wears and you get that symptom you describe and its normal.I'll get back to you.
Posted on Feb 21, 2008
  • anthony james
    anthony james Feb 22, 2008
    I have the info on your mixer sanjuro.The original owner was value foods in sioux city south dakota.The year of the mixer is 1986.
I have a Hobart 60 qt mixer that has oil coming out the top around the shaft cover. What would cause this?
Do you really mean a 60 qt. mixer? That is industrial size and would be about 4' tall. Maybe a 6 qt. mixer? In either case, oil coming out around the shaft cover indicates that someone either over-lubricated the mixer or used the wrong viscosity lubrication. Has it been serviced recently? You might need to take it back to wherever it was serviced.
Feb 21, 2017 | Hobart Food Mixers
Hi, I have a used Hobart A200T and the bowl yoke piece moves up and down slightly, even under a light load. It makes an annoying clanking noise. It's as if a spring somewhere is looser than it should be....
You may be correct about a loose spring. Check this:
Carefully lay the mixer on its back side to access the bottom of the mixer. Remove the cover screen covering the opening in the bottom of the mixer. Using an extension and appropriate socket, be sure the nut of the bowl lift rod is snug, slightly compressing the spring of the bowl lift rod.
Jan 26, 2011 | Hobart A200 Stand Mixer
Change Hobart N-50 110 V / 60 Hz to 230 V / 50 Hz
You would need to provide the correct power to match the maching, or replace the rotor, stator, controls to match the higher voltage, and worm gears to correct the speed, from 60 to 50 Hz. Unless you don't mind it running slower. Cheaper to find one that matches your local spec..
Sep 25, 2009 | Hobart N50 Stand Mixer
Hobart N50 stator assembly replacement
You can go to www.hobartservice.com. select parts and type the machine ML number from the data plate. here are 5 different ML options, otherwise I would have given you the part number.
It will open an exploded view of YOUR machine's build, complete with part numbers.
You can then call your nearest Hobart dealer for a cost and availability. They are still a current model, and for their size, an excellent mixer worth repairing.
Aug 18, 2009 | Hobart N50 Stand Mixer
I need the manual for the Hobart 20 Quart Mixer A200T
Hobart doesn't release their service manuals to the general public,however i'm a hobart tech and repair these mixer's often.If you need any help let me know.
Mar 05, 2009 | Hobart A200 Stand Mixer
On and off switch for hobart stand up mixer a200
I'm a hobart tech---what is the ml number on the data plate?
Feb 23, 2009 | Hobart A200 Stand Mixer
A200 electronic start switch
Hi harry,the wires should be marked 1-2-3-4,if not i'll give you the diagram.Let me know.
Feb 09, 2009 | Hobart A200 Stand Mixer
Hobart model a200t not working propery. Just hums when turned on
take top front cover off see if motor is spinning when turned on? hum can come when motor is running or transmision jammed or motor has issue like capsitor bad or start switch inside motor bad.
Jan 03, 2009 | Hobart A200 Stand Mixer
I have a Hobart a200t industrial mixer which isn't running properly. When turned on, it just hums, and the gears don't move. I have been searching online and cannot find a free troubleshooting guide. I...
Hi, it is hard to determine exactly what the problem is without seeing it, however, that mixer usually uses a capacitor to help start the motor, and a switch, or relay, that are in the back of the unit. You probably will not find any troubleshooting guide, Hobart does not give up information easily. You can take it to an electric motor repair shop, and they will easily be able to tell which of those is the problem, and will be reasonable in price. Your other option is to contact Hobart locally for service assistance. Maybe one of the other Hobart techs here can help you out more.
Hobart A200 Stand Mixer Logo
338 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
