I require a new power lead for a Dm tech 12/24 volt tv dvd player. can you please sugest where i can purchase one. thank you Doug Porteous
  • 12,061 Answers
Try Radio Shack, Walmart, or Ebay...
Posted on Feb 04, 2010
I plugged in the tv and the green Timer light keeps flashing and tv won't go on. Help!
Hi
Thanks for using FixYa. Continuous blinking green LED on Mitsubishi's Projection which normally blinks after a power surge means that the microprocessors inside the unit are unable to communicate with each other. Usually Mitsubishi's Projection TV use 1000uF/16 in the DM MODULE (which is one of the two microprocessors), as these capacitors are too small for the load they get they usually fail usually after about 3-5 years. They might also fail due to voltage fluctuations. To resolve this issue these capacitors should be replaced with 1000uF/25 volt or 1000uF/35 volt capacitors, so that they can handle any voltage spikes that will occur. To do the repair you'll need to take the back off the TV apart in order to remove the faulty DM module and need to desolder the old capacitors on DM board and install new ones. All this is only recommended to be done by someone who has electrical expertise. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 26, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Can't get power to TV. The green light continues to blink. I have disconnected all the cables in the back of the TV and unplugged the TV overnight and the green light continues to blink once I put power to...
Hi
Thanks for using FixYa. The green LED on the front panel of the TV that normally blinks when turned on after a power failure or when unplugged: the green light is supposed to flash for about 1 minute while both microprocessors boot up: If it won't stop blinking it means that they aren't communicating with each other. This issue is due to 1000uF/16 volt power supply capacitors in the "DM module" (one of the two onboard microprocessors). These capacitors are apparently small as compared to load they get & due to this they will eventually fail (usually after about 3 years). Or else they fail when there are voltage fluctuations in the circuit above 16 volts. It is recommended to install either 1000uF/25 volt or 1000uF/35 volt capacitors as replacements, so that they will be more than ample to handle any voltage spikes that will occur. To do the repair you’ll need to take the back off the TV apart in order to remove the faulty DM module and need to desolder the old capacitors on DM board and install. Also check the grounding straps which are essential to the proper functioning of the DM module. All this is only recommended to be done by someone who has electrical expertise and know how to solder/re-solder components else contact a qualified repair tech and let them know what the exact issue is with your TV. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 11, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Can't turn tv on . timer blinking. shut on and off, and hit reset button
Hi
Thanks
Rylee
Jun 05, 2010 | Mitsubishi WS-65869 65" Rear Projection...
I have a Mitsubishi 62" DLP and all it does is blink fast green from the timer for 1 minute. I checked the lamp and ballast board and both are good.
Power supply board Look for vented or puffed up on top capacitors 1000uf16v.330uf 10v, 470uf 16v.
Also what is the model number printed on back of TV?
Feb 25, 2010 | Televison & Video
DM Tech LCD TV with built in DVD player - DVD fault
unfortunetly these sets are known for this problem... its the dvd drive itself
Feb 15, 2010 | Televison & Video
Car DVD player need lead free or not in PCB?
You're not required to give such information.
Jun 18, 2009 | Boss DVD-2000 Car DVD Player
Matsui TV/DVD MAT15LI618D DVD unlock
where can i get a power supply lead for my matsui 15in tv/dvd player
Jun 09, 2009 | Radio Shack Accurian APD-3955
USB CONNECTED NO FUNCTIONS ARE AVAILABLE
Try right clicking the USB port and selecting "Enable Device"
Jun 20, 2008 | DMTech DM-AV10 Digital Media Player
DMTECH DM-AV10
I would change the battey, if its not the battery i would place the media player on top
of some paper, stand back and admire your new paper weight.
Oct 27, 2007 | DMTech DM-AV10 Digital Media Player
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Electro Med Services...
