Question about Kenmore 400 6942 Dryer
My kenmore elite 6942 won't power on. thoughts?
  • Kenmore Master
  • 2,696 Answers
Make sure your getting power to the dryer?also check that the motor is getting power,if it is and dryer won't start you could have a bad motor,you have to get in there with a meter and check it out,check the door switch,move the paddle you should here a click when you push it in and out,if not change it,also check the thermal fuse located on the blower wheel housing,you have to send more info,there's so many reasons why it doesn't start get a meter and read it out,send model number next time
Posted on Feb 03, 2010
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
My kenmore elite electric dryer wont get hot
The motor works on 120 volts the heater is what requires 240. I bet you have an electrical problem
Aug 12, 2012 | Kenmore 400 6942 Dryer
My Kenmore 400series 6942 electric dryer works, but doesn't get hot. Pulled the heating element had it tested. It shows good. Had three other relay/fuses tested. They show good. It has to be easy enough...
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. seth765.jpg if there is no heat then one of the thermal fuses is bad you will need to check the continuity on them and replace the one that does not have any continuity
Jan 20, 2011 | Kenmore 400 6942 Dryer
Still more of the same
The exhaust is clogged or restricted holding too much heat in the exhaust housing or the limit t-stat has gone bad. This is the t-stat sitting next to the thermal fuse. Good luck.
Feb 11, 2010 | Kenmore 400 6942 Dryer
Kenmore 400 6942 overheats and blows a fuse problem
bad high temp thermostat,remove the back and you will see it on the heater box to your right-mike
Serial number
1045-1208-8261-8319-6942-3707
Photoshop 7 serial
if this not working try these serials
Aug 21, 2009 | Adobe Photoshop 7.0 for PC
Kenmore 400 6942 Dryer Logo
105 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
