Question about Kenmore Elite Oasis 27052 Top Load Washer
F1 appears after you press the start button
Once you hit the start button, it will go for about 30 seconds, and then F1 appears on the screen. Then, you have to press the start button multiple times before it will operate. We called out a technician who said that it could either be a kinked hose (it wasn't) or the mother board was "gone". A replacement mother board is upwards of $400.00, and he recommend that we replace this 3 year old washer. He went on to say that this is a common error and that a replacement mother board could yield the same results. Is there another fix or work around to this problem?
  • 15,935 Answers
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 18, 2010
I ned help to remove bios password on my lenovo g40-30 laptop motherbord please
  • Turn the Lenovo computer off. Leave the computer off for at least five seconds.
  • 2 Press and hold down the "F1" key. Turn the computer on.
  • 3 Release the "F1" key when the BIOS screen appears.
  • 4 Type the current BIOS password into the password field.
  • 5 Click the "Password" button. Select the "Supervisor" icon.
  • 6 Type the current BIOS password into its field. Press the spacebar.
  • 7 Press "Enter" on the blank password box. Press "Enter" on the verification screen. The BIOS password is removed.
  • 8 Click the "Save and Exit" icon.
  • Read more : http://www.ehow.com/how_8577037_remove-bios-password-lenovo.html
    Apr 11, 2015 | Lenovo Computers & Internet
    How to set up bios on toshiba laptop tecra m1
    Hold down the Esc key and press and hold the power button until the on/off light on the system indicator panel illuminates (green) for approximately one second. When the following message appears on the screen: "Check system, Then press [F1] key," press F1. The System Setup screen appears.
    If that doesn't work, try powering on the laptop and when the Toshiba splash screen comes up, hit F2 or F12.
    One of these methods will get you in to the BIOS setup.
    Mar 10, 2015 | Toshiba Computers & Internet
    How to get to toshiba nb205 bios
    Jun 10, 2014 | Toshiba NB205-N210 Netbook
    Nexus 7 won't turn on
    Pop the back off, unplug the battery for about 30 seconds, plug the battery back in, put the back cover back on. You will find it will start no problem.
    May 19, 2014 | Google Nexus 7
    Instructions for oxo model 1061978
    To set clock:
    1. Press and hold clock/timer button for 3 seconds (clock icon will appear on left side of screen).
    2. Input time using keypad then quickly press clock/timer button to save.
    To set timer:
    1. Press and release clock/timer button.
    2. If necessary, press clear/memory so timer reads all zeroes.
    3. Enter desired time using keypad (to a maximum of 99hrs:99mins:99secs).
    4. Press stop/start to begin countdown.
    5. Pause countdown by pressing stop/start; resume by pressing button again.
    6. When countdown is complete, timer will beep continuously for 30 seconds and display will flash. Timer will then beep every 10 seconds for 10 minutes until the stop/start button is pressed.
    7. Press clock/timer button to return to clock function.
    To time activities:
    3. Press stop/start and plus (+) sign will appear on right side of screen as timer begins counting up.
    4. Pause count-up by pressing stop/start; resume by pressing button again.
    5. When you're finished timing, press stop/start to end timing function.
    6. Press clock/timer to return to clock function.
    Feb 17, 2013 | Oxo Hardware & Accessories
    As soon as I power on My Dell D610 in boot screen appear : '' MANUFACTURING MODE: LEVEL '67''' ''PRESS FN + X TO RETURN THE SYSTEM TO NORMAL MODE'. This does not appear...
    hi hope you are well, there could be a few issues that caused this, if you have another system where u can test that all components are working then try to do that, if you already did and nothing happened. Unplug the system and remove the battery. Hold the power button for 30 seconds. Then try powering up -- if it won't, the motherboard is faulty, and you'll need to replace it am really sorry could not be of further help..
    Jul 07, 2011 | Dell Latitude D610 Notebook
    How to enter bios on thinkcentre 8811-6cu
    Try hitting F2 when boot starts will normally take you to the bios.
    Jun 14, 2011 | Lenovo ThinkCentre® M55-8811 PC Desktop
    What does error Oxc05d0281 mean
    This error message means" ink system failure " and to resolve this issue please follow these troubleshooting steps:
    Unplug the printer and wait 30 seconds for power to discharge.
    2. Plug in the printer.
    3. Hold the CANCEL and OK buttons simultaneously, and keep them depressed while you hit the ON button. This resets the printer.
    4. When the printer turns on, if you still get the error message, it's OK. Then perform the steps listed
    1?Press and hold the “*” key
    2?Press the “#” key and release both keys,Display should say “Enter Special Key Combo”
    3?Press and release in sequence the “1”, “2” and “3” buttons
    4?Press and release the right arrow button until the display says “System Configuration Menu”.
    5?Press and release the “OK” button.
    6?Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure
    7?Press and release the “OK” button.
    8?Display should say “Hardware failure status: Clear. Press OK to clear”.
    9?Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
    10?Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
    11?Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
    12?Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
    13?Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
    After you perform the steps listed above, when you are at the step at the end where you are pressing the cancel button until you get to the WELCOME screen, if at some point you see a message, “Inproper shutdown, hit OK”, go ahead and hit OK and the Welcome screen should appear.
    One thing that is nice about this method is that it doesn't use up all your ink doing a recalibration.
    The error message should not pop up so try to print a self test Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
    all the best
    Jun 04, 2010 | HP Photosmart 3210 Printer
    Oven has error E1 F1 will not work
    F1 - E1
    EEPROM checksum error
    1. Disconnect power for at least 30 seconds.
    2. Re-apply power and observe for at least one minute.
    3. If code re-appears, replace control board (also called ERC or clock).
    Jan 11, 2009 | Whirlpool RBS275PD Electric Single Oven
    Setting Bench Watch
    Reset Instructions Bench. (BC0013BR)
    Time and Location
    If you hold in the light, start and the reset button for a few seconds a screen will appear with the 12h or 24 h clock setting and also the date and country.
    Once you have that screen if you press the mode button it will move over the date and clock etc then you just press the reset button and start button to choose the date and time.
    Once you have changed the date and time to the correct date press the light button, start button and reset button and it will save the settings.
    Alarm
    Hold in the light, start and the reset button for a few seconds a screen will appear
    press the mode button it will move over the date and clock etc then you just press the reset button and start button to choose the date and time. Use the light button to set the screen.
    Feb 27, 2008 | Watches
    Kenmore Elite Oasis 27052 Top Load Washer Logo
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
